查看: 325|回复: 1
[求助] 有没有大佬看看这个是什么问题
Rank: 1
发表于 2024-4-1 22:12:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
信息列表创建者:     YYX
日期:               2024/4/1 22:06:12
当前工作部件:       C:\Users\YYX\Desktop\liangan_sim1.sim
节点名:             desktop-0gr2hbk
解算方案模型设置检查错误汇总
求解器是 NX NASTRAN
环境:NX NASTRAN - Structural
解算方案是 SOL 101 Linear Statics - Global Constraints
基于网格的错误汇总
总计:0 个错误和 0 个警告
基于材料的错误汇总
总计:0 个错误和 0 个警告
基于解算方案的错误汇总
ERROR
Step "Subcase - Contact Loads 1" has loads applied without any constraints.
操作:在“编辑解算方案”对话框中为此步骤定义约束或请求惯性释放。
ERROR
Step "Subcase -Max Compression Pressure  1" has loads applied without any constraints.
ERROR
Step "Subcase -Max Tensile Force 1" has loads applied without any constraints.
迭代求解器选项
More than 80 percent of the elements in this model are 3D elements.
It is therefore recommended that you turn ON the Element Iterative Solver in the "Edit
Solution" dialog.
总计:3 个错误和 0 个警告
基于载荷/BC 的错误汇总
总计:0 个错误和 0 个警告
NASTRAN 模型设置检查已完成
Rank: 4
发表于 2024-4-19 16:53:01 | 只看该作者
ERROR
ERROR
ERROR
检查求解方案里面的这三个边界条件
Powered by UG爱好者 X3.2  © 2001-2014 Comsenz Inc. GMT+8, 2024-5-23 01:38
