UID9123692
U币1
G币5815
技术0
主题16
精华0
阅读权限90
注册时间2018-12-15
最后登录2024-5-10
在线时间540 小时
手机13120019725
VBA可以
- Public Sub ConvertSplineToArcs()
- Dim spline As AcadSpline
- Dim i As Integer
- Dim points As Variant
- Dim startPoint As Variant
- Dim midPoint As Variant
- Dim endPoint As Variant
- Dim radius As Double
- Dim centerPoint As Variant
- ' 确保至少选中了一条样条线
- If ThisDrawing.SelectionSets.Count = 0 Then Exit Sub
- Set ss = ThisDrawing.SelectionSets.Item("WindowsSelectionSet")
- If Not ss.Count >= 1 Then Exit Sub
- Set ent = ss.Item(0).Entities.Item(0)
- If Not TypeOf ent Is AcadSpline Then Exit Sub
- Set spline = ent
- ' 获取样条线的控制点
- points = spline.GetControlPoints
- ' 循环遍历每个定点对,并创建圆弧
- For i = 0 To UBound(points) - 2 Step 3
- startPoint = points(i)
- midPoint = points(i + 1)
- endPoint = points(i + 2)
- ' 计算圆弧的半径和中心点
- radius = Distance(startPoint, midPoint)
- centerPoint = MidPoint(startPoint, midPoint)
- ' 创建圆弧
- Dim startAngle As Double
- Dim endAngle As Double
- ' 计算起始角度和结束角度
- ' 这里需要根据实际情况进行计算
- startAngle = AngleBetween(centerPoint, startPoint)
- endAngle = AngleBetween(centerPoint, endPoint)
- ' 创建圆弧
- Dim arc As AcadEntity
- Set arc = ThisDrawing.ModelSpace.AddArc(centerPoint(0), centerPoint(1), centerPoint(2), radius, radius, startAngle, endAngle)
- Next i
- End Sub
- ' 计算两点之间的距离
- Function Distance(pt1 As Variant, pt2 As Variant) As Double
- Distance = Sqr((pt1(0) - pt2(0)) ^ 2 + (pt1(1) - pt2(1)) ^ 2)
- End Function
- ' 计算两点之间的中点
- Function MidPoint(pt1 As Variant, pt2 As Variant) As Variant
- MidPoint = Array((pt1(0) + pt2(0)) / 2, (pt1(1) + pt2(1)) / 2, (pt1(2) + pt2(2)) / 2)
- End Function
- ' 计算两向量之间的角度
- Function AngleBetween(centerPoint As Variant, otherPoint As Variant) As Double
- Dim vecX As Double
- Dim vecY As Double
- vecX = otherPoint(0) - centerPoint(0)
- vecY = otherPoint(1) - centerPoint(1)
- ' 计算角度的代码需要根据实际情况进行编写
- ' 这里是一个简化的示例
- AngleBetween = Atn2(vecY, vecX) * 180 / 4.14159265358979
- End Function
复制代码 |
