查看: 4630|回复: 4
[原创] NX 8.5.0还是有32位版本的。
发表于 2012-10-23 20:34:24 | 显示全部楼层 |阅读模式
  Dear Siemens PLM Customer,
   We are pleased to inform you that NX 8.5.0 is now available for download
   from the Full Product Download page of the Siemens PLM FTP server.
   NX 8.5.0 is available for the following platforms; Windows 32-Bit, Windows
   64-Bit, Linux 64-Bit and Mac OS.  Please refer to the Release Notes for
   specific Operating System requirements.
发表于 2012-10-24 17:45:28 | 显示全部楼层
我搶沙發嗎?哈哈哈,32位元等待中~~~
发表于 2012-10-24 20:48:44 | 显示全部楼层
是个好消息,不过还要等。
 楼主| 发表于 2012-10-25 15:56:02 | 显示全部楼层
搞笑了,只支持32位 xp 和 Vista ,windows 7 32位不支持。装是肯定可以的,没认证吧了。
      NX                                               Version 8.5 Release
      Windows (32 Bit)                                Issued: October 2012
      Files on this media are intended for use on 32 Bit Windows XP and
      Vista platform only. The 32 bit version of Windows 7 is not supported.
      This software may also be used on 64 Bit Windows platforms. The 64 Bit
      versions of Windows XP, Vista and Windows 7 are all supported.
      ___________________________________________________________________
      INSTALLATIONS:
      To install the products on this media, run the 'launch' program at
      the top level, or change directory to the product directory and
      run the setup program contained within that directory.
      DOCUMENTATION:
      The 'docs' folder contains Installation documents and other related
      documents, which may be viewed or printed with your browser.
      Further information is contained in the README file located in
      the "docs" folder.
      NOTE:  Viewing Documentation directly from the media Launcher will
             require that the Adobe Acrobat plug-in is installed on your
             system.  No errors are given if the plug-in is not available.
             Download the plug-in from:  http://www.adobe.com/acrobat
      RELEASE INFORMATION:
      The What's New Guide and the Release Notes are contained in the
      REL_INFO kit.  This will be installed by default with the Typical
      installation option.  If you use the Custom installation option,
      it is recommended that you select the 'REL_INFO' kit.
      Once installed, both documents can be viewed from the start menu:
      Start -> Programs -> Siemens NX 8.5 -> Release Information ->
            *Whats New
            *Release Notes
      A copy of the Release Letter and What's New Guide are also provided
      in the "docs" folder.  These are viewable with your Web Browser.
      Begin browsing with the following initial file:
          docs\release_notes\english\index.html
          - or -
          docs\whatsnew\english\index.html
      Further information is contained in the docs\README file.
灌水王灌水王
发表于 2012-12-29 08:10:17 | 显示全部楼层
期待中。呵呵 !
GMT+8, 2025-12-16 16:37
