查看: 19768|回复: 37
[分享] UG8.5正式版(NX8.5)不再支持XP Vista等32位系统了!
站长优秀版主论坛技术员论坛元老论坛贡献推广达人
发表于 2012-10-22 19:30:34 | 显示全部楼层 |阅读模式
NX8.5正式版将不再支持32位WINDOWS XP系统和WINDOWS Vista系统
NX 8.5 Final Release
NX                                               Version 8.5 Release
      Windows (64 Bit)                                Issued: October 2012
      Files on this media are intended for use on 64 bit Windows XP, Vista
      and Windows 7 platform only.
      The software will not work on 32 bit machines.
      ___________________________________________________________________
      INSTALLATIONS:
      To install the products on this media, run the 'launch' program at
      the top level, or change directory to the product directory and
      run the setup program contained within that directory.
      DOCUMENTATION:
      The 'docs' folder contains Installation documents and other related
      documents, which may be viewed or printed with your browser.
      Further information is contained in the README file located in
      the "docs" folder.
      NOTE:  Viewing Documentation directly from the media Launcher will
             require that the Adobe Acrobat plug-in is installed on your
             system.  No errors are given if the plug-in is not available.
             Download the plug-in from:  http://www.adobe.com/acrobat
      RELEASE INFORMATION:
      The What's New Guide and the Release Notes are contained in the
      REL_INFO kit.  This will be installed by default with the Typical
      installation option.  If you use the Custom installation option,
      it is recommended that you select the 'REL_INFO' kit.
      Once installed, both documents can be viewed from the start menu:
      Start -> Programs -> Siemens NX 8.5 -> Release Information ->
            *Whats New
            *Release Notes
      A copy of the Release Letter and What's New Guide are also provided
      in the "docs" folder.  These are viewable with your Web Browser.
      Begin browsing with the following initial file:
          docs\release_notes\english\index.html
          - or -
          docs\whatsnew\english\index.html
      Further information is contained in the docs\README file.
85
优秀版主论坛贡献灌水王推广达人活跃会员
发表于 2012-10-22 19:34:04 | 显示全部楼层
顶起,看来这是趋势啊,逼着我们放弃XP。。SW2013是最先不支持XP的{:}
39
发表于 2012-10-22 19:36:54 | 显示全部楼层
原来如此哦,,更新太快了感觉不好
灌水王活跃会员
发表于 2012-10-22 19:38:24 | 显示全部楼层
好坑爹···为什么我们中国没有牛的3D软件··想抵制洋货都不行···{:mad:}
发表于 2012-10-22 19:38:37 | 显示全部楼层
果断用WIN7的
发表于 2012-10-22 19:50:23 | 显示全部楼层
哈哈,在看到solidedgeST5不支持XP的情况下,可以预想到NX8.5,也不会不支持!
4736
9万
优秀版主论坛技术员论坛贡献活跃会员可爱天使
发表于 2012-10-22 19:52:57 | 显示全部楼层
唉,我的电脑配置用不上8.5了,64的话,速度怎么样
发表于 2012-10-22 20:31:18 | 显示全部楼层
win7的32位支持吗 ?
42
优秀版主论坛技术员论坛元老
发表于 2012-10-22 20:35:26 | 显示全部楼层
哎~!郁闷啊,看来我这系统得重装了!~
发表于 2012-10-22 20:47:23 | 显示全部楼层
为了8.5正式版,已经把XP改成win7了。
GMT+8, 2026-9-20 00:04
