查看: 25488|回复: 10
[求助] 初学CAM求各英文含义解释
发表于 2011-12-20 23:48:56 | 显示全部楼层 |阅读模式
  1. 初学CAM,求热心大侠将UG8里的几何体类型/创建方法/创建工序几大类里的英文选择一一作解。
  2. (不知这个问题是否值得解答/如有心也可尽数讲解,能解释各方法区别更好)
  3. 创建几何体类型:
  4. MCS
  5. WORKPIECE
  6. MILL-AREA
  7. MILL-BND
  8. MILL-TEXT
  9. HOLE-BOSS-GEOM
  10. MILL-GEOM
  11. MULTI-BLADE-GEOM
  12. MULTI-BLADE-GEOM
  13. DRILL
  14. HOLE-BOSS-GEOM
  15. FBM-GEOM
  16. MANUAL-HOLE
  17. ALL-FEATURES
  18. MCS-WEDM
  19. SEQUENCE-INTERNAL-TRIM
  20. SEQUENG-EXTERNAL-TRIM
  21. WEDM-GEOM
  22. MCS-MILL
  23. Mill-plana
  24. MCS
  25. WORKPIECE
  26. MILL-AREA
  27. MILL-BND
  28. MILL-TEXT
  29. HOLE-BOSS-GEOM
  30. MILL-GEOM
  31. Mill-contour
  32. MCS
  33. WORKPIECE
  34. MILL-AREA
  35. MILL-BND
  36. MILL-TEXT
  37. MILL-GEOM
  38. Mill-multi-axis
  39. MCS
  40. WORKPIECE
  41. MILL-AREA
  42. MILL-BND
  43. MILL-GEOM
  44. Mill-multi-blade
  45. MCS
  46. WORKPIECE
  47. MULTI-BLADE-GEOM
  48. Drill
  49. MCS
  50. WORKPIECE
  51. DRILL
  52. HOLE-BOSS-GEOM
  53. Hole-making
  54. MCS
  55. WORKPIECE
  56. MILL-AREA
  57. FBM-GEOM
  58. MANUAL-HOLE
  59. ALL-FEATURES
  60. HOLE-BOSS-GEOM
  61. Turmimg
  62. MCS_SPINDLE
  63. WORKPIECE_1
  64. TURNING_WORKPIECE
  65. TURNING_PART
  66. CONTAINMENT
  67. AVOIDANCE
  68. Wire-edn
  69. MCS-WEDM
  70. SEQUENCE-INTERNAL-TRIM
  71. SEQUENG-EXTERNAL-TRIM
  72. WEDM-GEOM
  73. Probing
  74. MCS-MILL
  75. WORKPIECE
  76. Solid-Tool无模板
  77. Machining-knowledge
  78. MCS
  79. WORKPIECE
  80. MILL-AREA
  81. 创建方法类型
  82. Mill-planar
  83. MILL-METHOD
  84. Mill-contour
  85. MILL_METHOD
  86. MOLD_ROUGH_HSM_1
  87. MOLD_SEMI_FINISH_HSM
  88. MOLD_FINISH_HSM
  89. Mill-multi-axis
  90. MILL_METHOD
  91. Mill-multi-blade
  92. MILL_METHOD
  93. Drill
  94. DRILL_METHOD_1
  95. Hole-making
  96. DRILL_METHOD_1
  97. HOLE_MILL_METHOD
  98. Turmimg车床用
  99. Wire-edn
  100. WEDM_METHOD
  101. Probing
  102. MILL_METHOD
  103. Solid-Tool无模板
  104. Machining-knowledge
  105. PRE_DRILL_METHOD
  106. DEBURRING_METHOD
  107. CSINK_THD_METHOD
  108. TAP_METHOD
  109. STEP_DRILL_METHOD
  110. THREAD_MILL_METHOD
  111. MILL_CB_METHOD
  112. BREAKCHIP_DRILL_METHOD
  113. BORE_METHOD
  114. CENTER_DRILL_METHOD
  115. CORE_DRILL_METHOD
  116. CBORE_METHOD
  117. CSINK_METHOD
  118. DRILL_METHOD_1
  119. PECK_DRILL_METHOD
  120. REAMING_METHOD
  121. SPOT_DRILL_METHOD
  122. TAPPING_METHOD
  123. TAPPING_METHOD
  124. HOLE_MILL_METHOD
  125. MILL_METHOD_ROUGH
  126. 创建工序类型:
  127. Mill-planar
  128. FACE_MILLING_AREA_1“面铣削区域”有部件几何体、切削区域、壁几何体、检查几何体和自动壁面选择。
  129. FACE_MILLING基本的面切削操作,用于切削实体上的平面。
  130. FACE_MILLING_MANUAL混合切削模式,各个面上都不同。其中的一种切削模式是手动,它使您能够把刀具正好放在所需的位置,就像教学模式一样。
  131. PLANAR_MILL_2基本的平面铣操作,它采用多种切削模式加工二维边界,以及平底面。
  132. PLANAR_PROFILE_1特殊的二维轮廓铣切削类型,用于在不定义毛坯的情况下轮廓铣。常用于修边。
  133. ROUGH_FOLLOW_1使用跟随工件切削模式的平面铣。
  134. ROUGH_ZIGZAG使用往复切削模式的平面铣。
  135. ROUGH_ZIG使用单向轮廓铣切削模式的平面铣。
  136. CLEANUP_CORNERS使用来自于前一操作的二维 IPW,以跟随部件切削类型进行平面铣。常用于清除角,因为这些角中有前一刀具留下的材料。
  137. FINISH_WALLS将余量留在底面上的平面铣。
  138. FINISH_FLOOR将余量留在壁上的平面铣。
  139. HOLE_MILLING
  140. THREAD_MILLING使用螺旋切削铣削螺纹孔。
  141. PLANAR_TEXT切削制图注释中的文字,用于二维雕刻。
  142. MILL_CONTROL它只包含机床控制事件。
  143. MILL_USER此刀轨由您定制的 NX Open 程序生成。
  144. Mill-contour
  145. CAVITY_MILL_2基本的型腔铣操作,用于去除毛坯或 IPW 及部件所定义的一定量的材料,带有许多平面切削模式。型腔铣常用于粗加工。
  146. PLUNGE_MILLING
  147. CORNER_ROUGH切削拐角中的剩余材料,这些材料因前一刀具的直径和拐角半径关系而无法去除。
  148. REST_MILLING_1
  149. ZLEVEL_PROFILE基本的 Z 级铣削,用于以平面切削方式对部件或切削区域进行轮廓铣。
  150. ZLEVEL_CORNER精加工前一刀具因直径和拐角半径关系而无法到达的拐角区域。
  151. FIXED_CONTOUR基本的固定轴曲面轮廓铣操作,用于以各种驱动方式、包容和切削模式轮廓铣部件或切削区域。刀具轴是 +ZM。
  152. CONTOUR_AREA区域铣削驱动,用于以各种切削模式切削选定的面或切削区域。常用于半精加工和精加工。
  153. CONTOUR_SURFACE_AREA曲面区域驱动,它使用单一驱动曲面的 U-V 方向,或者是曲面的直角坐标网格
  154. STREAMLINE
  155. CONTOUR_AREA_NON_STEEP与 CONTOUR_AREA 相同,但只切削非陡峭区域。经常与 ZLEVEL_PROFILE_STEEP 一起使用,以便在精加工切削区域时控制残余波峰。
  156. CONTOUR_AREA_DIR_STEEP区域铣削驱动,用于以切削方向为基础,只切削非陡峭区域。与 CONTOUR_ZIGZAG 或 CONTOUR_AREA 一起使用,以便通过十字交叉前一往复切削来降低残余波峰
  157. FLOWCUT_SINGLE自动清根驱动方式,单刀路,用于精加工或减轻角及谷
  158. FLOWCUT_MULTIPLE自动清根驱动方式,多刀路,用于精加工或减轻角及谷。
  159. FLOWCUT_REF_TOOL自动清根驱动方式,以前一参考刀具直径为基础的多刀路,用于铣削剩下的角和谷
  160. SOLID_PROFILE_3D
  161. PROFILE_3D特殊的三维轮廓铣切削类型,其深度取决于边界中的边或曲线。常用于修边。
  162. CONTOUR_TEXT切削制图注释中的文字,用于三维雕刻。
  163. MILL_USER此刀轨由您定制的 NX Open 程序生成。
  164.          MILL_CONTROL它只包含机床控制事件
复制代码
 楼主| 发表于 2011-12-20 23:48:57 | 显示全部楼层
  1. Mill-multi-axis
  2. VARIABLE_CONTOUR基本的可变轴曲面轮廓铣操作。用于以各种驱动方式、包容和切削模式轮廓铣部件或切削区域。刀具轴控制有多种选项。
  3. VARIABLE_STREAMLINE
  4. CONTOUR_PROFILE使用轮廓铣驱动方式的可变轴曲面轮廓铣操作。通过选择底面,使用此操作可以使用刀具侧面来加工带有角的壁。
  5. VC_MULTI_DEPTH可变轴曲面轮廓铣操作,其多个刀路均偏离部件。
  6. VC_BOUNDARY_ZZ_LEAD_LAG可变轴曲面轮廓铣操作,具有曲面区域驱动方式、往复切削模式和刀具轴(由前/后角定义)。
  7. VC_SURF_AREA_ZZ_LEAD_LAG可变轴曲面轮廓铣操作,具有曲面区域驱动方式、往复切削模式和刀具轴(由前/后角定义)。
  8. FIXED_CONTOUR基本的固定轴曲面轮廓铣操作,用于以各种驱动方式、包容和切削模式轮廓铣部件或切削区域。刀具轴可以设为用户定义的矢量。
  9. ZLEVEL_5AXIS
  10. SEQUENTIAL_MILL
  11. GENERIC_MOTION
  12. MILL_USER
  13. 此刀轨由您定制的 NX Open 程序生成
  14. MILL_CONTROL
  15. 它只包含机床控制事件。
  16. Mill-multi-blade
  17. MULTI_BLADE_ROUGH
  18. HUB_FINISH
  19. BLADE_FINISH
  20. BLEND_FINISH
  21. GENERIC_MOTION
  22. MILL_USER
  23. MILL_CONTROL
  24. Drill
  25. SPOT_FACING
  26. SPOT_DRILLING
  27. DRILLING
  28. PECK_DRILLING
  29. BREAKCHIP_DRILLING
  30. BORING
  31. REAMING
  32. COUNTERBORING
  33. COUNTERSINKING
  34. TAPPING
  35. HOLE_MILLING
  36. THREAD_MILLING
  37. MILL_CONTROL
  38. MILL_USER
  39. Hole-making
  40. MILL_CONTROL
  41. HOLE_MAKING
  42. HOLE_MILL
  43. MANUAL_HOLE_MAKING
  44. HOLE_MILLING
  45. THREAD_MILLING
  46. Turmimg
  47.         CENTERLINE_SPOTDRILL
  48. CENTERLINE_DRILLING
  49. CENTERLINE_PECKDRILL
  50. CENTERLINE_BREAKCHIP
  51. CENTERLINE_REAMING
  52. CENTERLINE_TAPPING
  53. FACING
  54. ROUGH_TURN_OD
  55. ROUGH_BACK_TURN
  56. ROUGH_BORE_ID
  57. ROUGH_BACK_BORE
  58. FINISH_TURN_OD
  59. FINISH_BORE_ID
  60. FINISH_BACK_BORE
  61. TEACH_MODE
  62. GROOVE_OD
  63. GROOVE_ID
  64. GROOVE_FACE
  65. THREAD_OD
  66. THREAD_ID
  67. PARTOFF
  68. BAR_FEED_STOP
  69. LATHE_CONTROL
  70. LATHE_USER
  71. Wire-edn
  72. NOCORE
  73. INTERNAL_TRIM
  74. EXTERNAL_TRIM
  75. OPEN_PROFILE
  76. WEDM_CONTROL
  77. WEDM_USER
  78. Probing
  79. PROBING
  80. GENERIC_MOTION
  81. Solid-Tool无模板
  82. Machining-knowledge
  83. HOLE_MAKING
  84. HOLE_MAKING_DRILL_TEXT
  85. HOLE_MAKING_DRILL_DEEP
  86. HOLE_MAKING_DRILL_BORE_DRAG
  87. HOLE_MAKING_DRILL_BORE_NODRAG
  88. HOLE_MAKING_DRILL_BORE_BACK
  89. HOLE_MAKING_DRILL_BORE_MANUAL
  90. SPOT_DRILLING
  91. DRILLING
  92. PECK_DRILLING
  93. BREAKCHIP_DRILLING
  94. COUNTERSINKING
  95. COUNTERBORING
  96. REAMING
  97. BORING
  98. HOLE_MILL
  99. FACE_MILLING_AREA_1
  100. FACE_MILLING
  101. CAVITY_MILL_2
  102. TAPPING
  103. 创建刀具
  104. MILL
  105. CHAMFER_MILL
  106. BALL_MILL
  107. SPHERICAL_MILL
  108. T_CUTTER
  109. BARREL
  110. THREAD_MILL
  111. MILL_USER_DEFINED
  112. CARRIER
  113. MCT_POCKET
  114. HEAD
  115. MILL_7_PARAMETER(mill-multi-axis/mill-multi-blade)
  116. MILL_10_PARAMETER(mill-multi-axis/mill-multi-blade)
  117. Drill
  118. SPOTFACING_TOOL
  119. SPOTDRILLING_TOOL
  120. DRILLING_TOOL
  121. BORING_BAR
  122. REAMER
  123. COUNTERBORING_TOOL
  124. COUNTERSINKING_TOOL
  125. TAP
  126. THREAD_MILL
  127. Hole-making
  128. STD_DRILL
  129. CENTERDRILL
  130. COUNTER_SINK
  131. SPOT_DRILL
  132. BORE
  133. REAMER
  134. STEP_DRILL
  135. COUNTER_BORE
  136. TAP
  137. THREAD_MILL
  138. SPOT_FACING
  139. MILL
  140. Probing
  141. PROBE
  142. Solid-tool
  143. GENERIC
复制代码
发表于 2011-12-21 11:29:09 | 显示全部楼层
只要有意思就好  要是能出个补丁就更好了
论坛元老活跃会员论坛技术员论坛贡献
发表于 2011-12-21 12:21:11 | 显示全部楼层
我很多也不知道。只是知道用。都是记图标呢。兄弟。
 楼主| 发表于 2011-12-26 23:58:39 | 显示全部楼层
其实主题应该改改:谁能CAM科普一下?
点评
标题什么的都可以编辑的  发表于 2011-12-27 11:25
51
贵宾
论坛技术员论坛元老论坛贡献灌水王
发表于 2011-12-27 09:25:46 | 显示全部楼层
建议版主置顶或者加精
51
贵宾
论坛技术员论坛元老论坛贡献灌水王
发表于 2011-12-27 09:46:08 | 显示全部楼层
  1. 不搞编程的,非专业翻译
  2. MCS 加工坐标系
  3. workpiece 工件
  4. all features 所有特征
  5. sequence internal trim 顺序内部修剪
  6. sequeng external trim (这个打错了吧)顺序外部修剪
  7. mill-multi-axis 多轴铣削
  8. mill-multi-blade 多刀铣削
  9. mill-planar 平面铣削
  10. blade 刀具,刀刃
  11. drill 打孔
  12. turning workpiece 旋转工件
  13. turning part 旋转零件
  14. wire edn (这个打错了吧)线缆末端
  15. probing 探测
  16. machining knowledge 机加工知识
  17. drill 打孔
  18. pre-drill-method 预打孔方式
  19. step-drill-method 阶梯孔方式
复制代码
贵宾
论坛技术员论坛元老
发表于 2011-12-27 10:15:10 | 显示全部楼层
我路过~~不懂编程
29
发表于 2011-12-27 13:15:08 | 显示全部楼层
不懂编程,支持一下
发表于 2012-1-26 20:54:11 | 显示全部楼层
意思是自己悟的,英语可以看字典的嘛
GMT+8, 2025-4-25 18:57
