查看: 2565|回复: 1
[求助] nx10.0在win10下运行蓝屏的问题,求解
发表于 2015-8-14 17:03:57 | 显示全部楼层 |阅读模式
我升级win10后,装了老叶的NX10.0,软件安装成功,也可以运行,就是有时用着用着就蓝屏了。。。
这个是我找的部分蓝屏记录,不运行NX10.0没有出现过蓝屏现象
***    Your debugger is not using the correct symbols                 ***
***    In order for this command to work properly, your symbol path   ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: nt!_KPRCB                                     ***
Probably caused by : ntoskrnl.exe ( nt+14dd00 )
Followup: MachineOwner
求解!!!
发表于 2015-11-7 21:49:47 | 显示全部楼层
我也是,一点ug的保持存和x就蓝屏,大神来帮忙啊
GMT+8, 2025-4-26 07:22
