查看: 3682|回复: 4
[求助] 注塑模向导未能启动excel
发表于 2015-8-8 16:34:09 | 显示全部楼层 |阅读模式
看过网上的教材,安装了offie套装,打开后依然提示未能启动excel,求大神知道,小白菜一个
发表于 2015-8-8 21:38:58 | 显示全部楼层
同等!!!!
发表于 2015-8-9 08:55:47 | 显示全部楼层
不知道你的版本是不是8.5
如果是的话,请根据破解文件的要求,请一个与EXCEL相关的文件复制到相应的文件夹内。
另外,如果你安装了WPS,请恢复系统默认打开文件为EXCEL而非WPS的电子表格。{:smile:}
 楼主| 发表于 2015-8-16 11:20:36 | 显示全部楼层
fasvt 发表于 2015-8-9 08:55
不知道你的版本是不是8.5
如果是的话,请根据破解文件的要求,请一个与EXCEL相关的文件复制到相应的文件夹 ...
那是个怎样的文件和excel相关的,能给点提示么谢谢
发表于 2015-9-24 16:26:14 | 显示全部楼层
Installation Notice
This is the description of Mold Wizard NX 8.5 Engineering Data Base Installation.
1. Windows XP :
  a. Download and unzip mwnx8.5_data.zip to a folder, such as "d:\moldwizard_data".
  b. Set MOLDWIZARD_DIR environment variable to the above folder, for example "set MOLDWIZARD_DIR=d:\moldwizard_data".
PS:实际文件夹可能是:D:\MOLDWIZARD_DATA\MOLDWIZARD,无论名称改为什么,反正打开这个文件夹,必须是见到诸如cool、drafting、electrode等文件夹。
  c. In order for the Bill of Materials tool to work properly, copy \moldwizard\templates\moldwizard_add_in.xla to C:\Program Files\Microsoft Office\Office\XLStart directory
PS:根据提示拷贝相应的文件至对应的文件夹。
  d. For Win64 bit machine, you need to set MOLDWIZARD_DIR environment variable explicitly in .bat file or System Environment Variables.
2. Windows 7 :
     C:\apps\MSOffice\Office12\XLSTART directory ( For Microsoft Office 2007 ),
     or C:\apps\MSOffice\Office14\XLSTART directory ( For Microsoft Office 2010 )
PS:下面的一般都用不着了。
3. For All platforms:
Siemens PLM Software recommends that you install the engineering database in a location outside the default ...\UGII_BASE_DIR\moldwizard location. You can put the library in shared location on your network, and point to it with the environment variable MOLDWIZARD_DIR.
4. Easy Fill
  a. Easy Fill integration package is included in this data base.
  b. First time run flow analysis needs administrator permission.
  c. Set WCS to absolute CSYS before starting flow analysis.
Notice
1. For Wint64 bit machine,  If BOM Export to Excel can not work.
Solution: put cursor in bom list Title Field area, MB3 -> Export to Spreadsheet.
2. Reserved part attribute.
The part attribute name of Material (or MATERIAL) is reserved by NX8.5, before starting to use NX/Mold Wizard application, you have to:
a. Open Customer Defaults settings by File->Utilities->Customer Defaults.
b. Expand Gateway->Materials/Mass.
c. Go to Attirbutes tab and turn off Create Attribute for Part Material.
d. Click OK and restart NX.
Problems Solved in This Release
1. Standard parts: Updated DME, HASCO, PUNCH, MEUSBURGER, OMNI catalogs:
   a. Metric
        DME Locating Ring data.
        DME Spring Set data.
        HASCO Spring Set data.
        MEUSBURGER meusburger_mm registry.
        PUNCH guide_rail data.
   b. English
        OMNI cavity_rnd model.
        OMNI insulation data.
2. Mold base: Updated MEUSBURGER catalog:
   a. meus_d_eng_int.xls  (MEUSBURGER_DRILLED_INTERCH)
   b. meus_d_ger_int.xls  (MEUSBURGER_VERBOHRT_INTERCH)
   c. meus_eng_int.xls    (MEUSBURGER_PLAIN_INTERCH)
   d. meus_ger_int.xls    (MEUSBURGER_UNVERBOHRT_INTERCH)
3. PR#6589686 : DME Sprue returns Consistancy and Self Intersection failure when Timing is used.
4  PR#1883051 : Excel MW Add-In 'Export to Xess' stops at line 1501 and truncates file.
5. PR#6663803 : Progressive Ejector Pin English has wrong catalog info in spreadsheet.
6. PR#6663856 : shoulder ejector pin head type 3and 4 incorrect false body.
7. PR#1891994 : Moldwizard DME_M ejector bumper assembly has non sufficient assembly constraint.
8. PR#1889994 : MW FHCS Socket Head Countersunk screw has non-standard dimensions.
9. PR#1891947 : Moldwizard False Body of Hasco screws has a small flat at the tool tip.
10. PR#6692204 : Mixed Units in MW Standard Parts create incorrect screw sizes.
11. PR#1891857 : MW Hasco Z10/Z1000 has wrong criteria compared to Hasco specs.
12. PR#6692204 : Mixed Units in MW Standard Parts create incorrect screw sizes.
13. Fix the fit distance adjustment issue for MISUMI straight ejector pins.
New Database in This Release
1. DMS moldbase Library [Metric]
2. DMS Standard Library [Metric]
3. Universal Standard Library [Metric]
4. Fill Standard Library [metric]
5. Cool Standard Library [Metric]
6. Slide/Lifter Standard Library [Metric]
If there are any problems or feedbacks, please contact:
  Zhi Li
  Email: li.zhi@siemens.com
GMT+8, 2025-4-17 06:39
