查看: 4522|回复: 1
[求助] Ug java 版本问题
发表于 2015-7-22 21:47:06 | 显示全部楼层 |阅读模式
java 版本1.8._49升级到java  1.8.0_51 批量导图界面闪退
UGII_JAVA_HOME. C:\Program Files (x86)\Java\jre1.8.0_51\bin
106
 楼主| 发表于 2015-7-26 14:32:55 | 显示全部楼层
用“记事本”打开程序UGII文件夹下的“ugii_env_ug.dat”文件,关键字查找“JAVA”,你会阅读到这么一段话:
# As of NX 8.5, NX no longer provides a JRE in the installation., P4 K" I, g/ d- |4 o
# UGII_JAVA_HOME should point to the base directory of the JRE Installation.0 t, O/ P. m, R
# The value below is just an example that will be different on your system. ; [8 `% m5 L4 e9 I( V. f
# Changing this variable will cause all NX java based applications to use the specified JRE.
# This is an example of how this value can be set.
#if x64wnt
#if FILE c:\apps\Java\jre7x64
UGII_JAVA_HOME=c:\apps\Java\jre7x64
#endif: b0 F) G  s: L  d3 o7 {
#else
#if FILE c:\apps\Java\jre7+ t" m: J  F, {; p
修改了也没用
GMT+8, 2026-11-18 04:13
