查看: 5759|回复: 0
[分享] catia v5安装问题解决方法
发表于 2015-7-2 16:39:26 | 显示全部楼层 |阅读模式
由于微软件的KB3061518补丁的影响,catia V5出现服务器连接之后,软件仍不能使用,
这个补丁对以下版本的影响:如catia v5 6r2014 catia v5  r62013 ……等唯独没有对catia v5 6r2015(这个版本你如果安装不上,建议去好好看百度安装教程)版本的影响
解决方案有两种方法:方案一:直接删除补丁就能正常使用
                              方案二:把catia v5 6r2015安装服务器(DSLS_SSQ_V6R2015x_Installer_01042015记住这个服务器不要弄错了)用在atia v5 6r2014 catia v5  r62013 ……(都是通用的)上,把原来直接删除就可以了
安装方法:1. Install CATIA V5-6R2014 SP5 Update
2. Install DS License Server 01042015 (by SSQ)
ATTENTION! For more info about DSLS Administration see DSLS.pdf
2.1. Uninstall previous versions of DSLS (if exist)
2.2. Run "DSLS_SSQ_V6R2015x_Installer_01042015.exe" as Administrator
2.3. After end of setup run "DS License Server Administration" will start automatically. If not run Start > Programs > DS License
Server > DS License Server Administration
2.4. On "Server Definitions" tab double click default server "localhost"
2.5. In "Server Configuration" window copy to clipboard "Computer ID" value
2.6. Close "Server Configuration" window
2.7. Run "DSLS.LicGen.v1.5.SSQ.exe" as Administrator
2.8. Input your computer name to "Server Name" field (computer name mast be English letters, digits and - _ symbols only!)
2.9. Past from clipboard value of Computer ID to "Server ID" field
2.10. In drop-down field "Generate License For" select "CATIA_V5R21-V5R25.SSQ"
2.11. Change the number of licenses (optional) and/or deselect undesirable licenses (optional)
2.12. Click "Generate!" and confirm to save *.licz file. Wait for warning "All done! Enjoy!", click OK and close LicGen
2.12. Go to window of "License Administration Tool". On tub "Server Definitions" connect to existing server and click License > Enroll
2.13. Browse to saved *.licz file and click Open
2.14. In "License Enrollment" window wait for warning that all licenses to be received and click OK. Be sure that there are no warnings about not valid licenses!
2.15. Close "License Administration Tool"
2.16. Copy folder "Licenses" from crack to C:\ProgramData\DassaultSystemes\ and overwrite original one
2.17.
For CATIA V5-6R2014 32-bit copy file ..client\Win32\netapi32.dll to <CATIA B24 progdir>\intel_a\code\bin (by default C:\Program Files\Dassault Systemes\B24\intel_a\code\bin\ )
For CATIA V5-6R2014 64-bit copy file ..client\Win64\netapi32.dll to <CATIA B24 progdir>\win_b64\code\bin (by default C:\Program Files\Dassault Systemes\B24\win_b64\code\bin\ )
2.18. Start CATIA, run "Tools > Options > General > Licensing" and select licenses for desired configurations and products
2.19. Enjoy :)
这段英文就是catia V5安装方法,看不懂去百度,好了在出现问题找自身原因
GMT+8, 2025-3-13 11:47
