楼主: Yui*
3轴自用后处理3个手动换刀和自动换刀都带刀具信息
 火... [复制链接]
发表于 2018-11-2 23:11:59 | 显示全部楼层
感谢分享 下载
发表于 2018-11-5 15:37:11 | 显示全部楼层
后处理求
发表于 2018-11-5 20:01:45 | 显示全部楼层
0000000
发表于 2018-11-5 23:36:30 | 显示全部楼层
急需后处理
发表于 2018-11-10 10:22:08 | 显示全部楼层
来看下这个好用不,有许多不能用
发表于 2018-11-13 10:40:26 | 显示全部楼层
大幅度发生东方闪电
发表于 2018-11-13 10:53:55 | 显示全部楼层
下载看看学习一下
发表于 2018-11-15 21:51:37 | 显示全部楼层
不知道能不能用
发表于 2018-11-15 23:47:55 | 显示全部楼层
#  Place this custom command in either the start of program
#  or the end of program event marker to generate a tool list
#  in your NC file.
#  The Shop Doc template file "pb_post_tool_list.tpl" distributed with
#  Post Builder in "POSTBUILD/pblib/misc" directory can be copied
#  to the "mach/resource/postprocessor" or "mach/resource/shop_docs" directory,
#  in case that your UG runtime environment does not have access to the
#  Post Builder installation.
#  Accessing "pb_post_tool_list.tpl" in other location can also be accomplished
#  by changing the code below titled "Generate tool list data" in this proc.
#  The variable "mom_sys_tool_list_output_type" set in this proc allows you
#  to select the type of tool list to be generated.
#  The options are:
#   "ORDER_IN_USE"     - List tools used in the program in the order of operations.
#   "ALL_UNIQUE"       - List all unique tools once for each in the order of use.
#   "GROUP_BY_TYPE"    - List tools in groups of different tool types.
# The desired tool list type can be set by changing the code below.
# The default is set to "GROUP_BY_TYPE".
   global mom_sys_tool_list_initialized
   global mom_sys_tool_list_output_type
   if { ![info exists mom_sys_tool_list_initialized] || !$mom_sys_tool_list_initialized } {
      MOM_output_to_listing_device "proc PB_CMD_init_tool_list must be executed in the Start of Program before PB_CMD_create_tool_list is called."
return
  # Set mom_sys_tool_list_output_type to the desired output fashion.
  # set mom_sys_tool_list_output_type "ORDER_IN_USE"
  # set mom_sys_tool_list_output_type "ALL_UNIQUE"
   set mom_sys_tool_list_output_type "GROUP_BY_TYPE"
   global mom_sys_control_out mom_sys_control_in
   global current_program_name
   global mom_tool_number mom_tool_length_adjust_register mom_tool_name
  # Save info for the currently active tool in the program being post-prcessed
  # before starting Shop Doc mechanism for tool list generation.
   if [llength [info commands PB_CMD_save_active_oper_tool_data] ] {
  # Create tool list per selected top-level group.
  # Group name is set to blank if no group has been selected.
   global mom_parent_group_name
   if [info exists mom_parent_group_name] {
      set current_program_name $mom_parent_group_name
   } else {
      set current_program_name ""
   set ci " "
   set co " "
   if [info exists mom_sys_control_in] { set ci $mom_sys_control_in }
   if [info exists mom_sys_control_out] { set co $mom_sys_control_out }
  # Generate tool list data
   set template_file pb_post_tool_list.tpl
   global tcl_platform
   if [string match "windows" $tcl_platform(platform)] {
      set pb_lib_misc_dir [MOM_ask_env_var UGII_BASE_DIR]\\postbuild\\pblib\\misc\\
   } else {
      set pb_lib_misc_dir [MOM_ask_env_var UGII_BASE_DIR]/postbuild/pblib/misc/
   set cam_post_dir     [MOM_ask_env_var UGII_CAM_POST_DIR]
   set cam_shop_doc_dir [MOM_ask_env_var UGII_CAM_SHOP_DOC_DIR]
   if { [file exists ${pb_lib_misc_dir}${template_file}] } {
      MOM_do_template_file ${pb_lib_misc_dir}${template_file}
   } elseif { [file exists ${cam_post_dir}${template_file}] } {
      MOM_do_template_file ${cam_post_dir}${template_file}
   } elseif { [file exists ${cam_shop_doc_dir}${template_file}] } {
      MOM_do_template_file ${cam_shop_doc_dir}${template_file}
   } else {
      MOM_output_to_listing_device  "ERROR : Template file pb_post_tool_list.tpl is not found in the following directories: \n \n          $pb_lib_misc_dir \n          $cam_post_dir \n          $cam_shop_doc_dir \n \n        Tool list cannot be generated.\n"
return
  # Output tool list
   global tool_data_buffer
   global mom_sys_tool_stack
   switch $mom_sys_tool_list_output_type {
      "ORDER_IN_USE" {
         set tool_list $mom_sys_tool_stack(IN_USE)
      "GROUP_BY_TYPE" {
         set tool_list [concat $mom_sys_tool_stack(LATHE)  $mom_sys_tool_stack(DRILL)  $mom_sys_tool_stack(MILL)]
      default {
         set tool_list $mom_sys_tool_stack(ALL)
   set prev_tool_type ""
   foreach tool $tool_list {
      set tool_type $tool_data_buffer($tool,type)
     # Output tool type header if it changes.
      if { ![string match "$tool_type" $prev_tool_type] } {
         if { [info exists tool_data_buffer($tool_type,header)] &&  $tool_data_buffer($tool_type,header) != "" } {
            shop_doc_output_literal "$tool_data_buffer($tool_type,header)"
      if [info exists tool_data_buffer($tool,output)] {
         shop_doc_output_literal "$tool_data_buffer($tool,output)"
      set prev_tool_type $tool_type
  # Restore info for the currently active tool in the program being post-prcessed.
   if [llength [info commands PB_CMD_restore_active_oper_tool_data] ] {
发表于 2018-11-17 23:55:11 | 显示全部楼层
额发生大幅度萨芬的萨芬大事
GMT+8, 2026-9-14 16:24
