楼主: haoyuan366
UG软件后处理构造器文件中的加密txt文件解密
 火... [复制链接]
发表于 2019-4-8 15:45:33 | 显示全部楼层
学习学习交流交流
发表于 2019-4-14 16:51:41 | 显示全部楼层
都不会加密...........
发表于 2019-4-18 20:17:38 | 显示全部楼层
学习一下
29
发表于 2019-4-21 08:26:57 | 显示全部楼层
好好好好
发表于 2019-4-26 18:26:03 | 显示全部楼层
去玩企鹅我去我
发表于 2019-4-26 23:18:30 | 显示全部楼层
31321545121
发表于 2019-4-27 12:39:54 | 显示全部楼层
感谢分享啊楼主
发表于 2019-4-28 22:44:32 | 显示全部楼层
求教proc MOM_rapid_move { } {
  global rapid_spindle_inhibit rapid_traverse_inhibit
  global spindle_first is_from
  global mom_cycle_spindle_axis traverse_axis1 traverse_axis2
  global mom_motion_event
   ABORT_EVENT_CHECK
   set spindle_first NONE
   set aa(0) X ; set aa(1) Y ; set aa(2) Z
   RAPID_SET
   set rapid_spindle_blk {G_motion G_mode X Y Z Mcool}
   set rapid_spindle_x_blk {G_motion G_mode X Mcool}
   set rapid_spindle_y_blk {G_motion G_mode Y Mcool}
   set rapid_spindle_z_blk {G_motion G_mode Z Mcool}
   set rapid_traverse_blk {G_feed G_motion G_mode X Y Z Mcool}
   set rapid_traverse_xy_blk {G_feed G_motion G_mode X Y Mcool}
   set rapid_traverse_yz_blk {G_feed G_motion G_mode Y Z Mcool}
   set rapid_traverse_xz_blk {G_feed G_motion G_mode X Z Mcool}
   set rapid_traverse_mod {}
   set rapid_spindle_mod {}
   global mom_sys_control_out mom_sys_control_in
   set co "$mom_sys_control_out"
   set ci "$mom_sys_control_in"
   if { ![info exists mom_cycle_spindle_axis] } {
      set mom_cycle_spindle_axis 2
   if { ![info exists spindle_first] } {
   if { ![info exists rapid_spindle_inhibit] } {
      set rapid_spindle_inhibit FALSE
   if { ![info exists rapid_traverse_inhibit] } {
      set rapid_traverse_inhibit FALSE
   switch $mom_cycle_spindle_axis {
      0 {
         if [llength $rapid_spindle_x_blk] {
            set spindle_block  rapid_spindle_x
            PB_SET_RAPID_MOD $rapid_spindle_mod $rapid_spindle_x_blk aa mod_spindle
         } else {
            set spindle_block  ""
         if [llength $rapid_traverse_yz_blk] {
            set traverse_block rapid_traverse_yz
            PB_SET_RAPID_MOD $rapid_traverse_mod $rapid_traverse_yz_blk aa mod_traverse
         } else {
            set traverse_block  ""
      1 {
         if [llength $rapid_spindle_y_blk] {
            set spindle_block  rapid_spindle_y
            PB_SET_RAPID_MOD $rapid_spindle_mod $rapid_spindle_y_blk aa mod_spindle
         } else {
         if [llength $rapid_traverse_xz_blk] {
            set traverse_block rapid_traverse_xz
            PB_SET_RAPID_MOD $rapid_traverse_mod $rapid_traverse_xz_blk aa mod_traverse
         } else {
      2 {
         if [llength $rapid_spindle_z_blk] {
            set spindle_block  rapid_spindle_z
            PB_SET_RAPID_MOD $rapid_spindle_mod $rapid_spindle_z_blk aa mod_spindle
         } else {
         if [llength $rapid_traverse_xy_blk] {
            set traverse_block rapid_traverse_xy
            PB_SET_RAPID_MOD $rapid_traverse_mod $rapid_traverse_xy_blk aa mod_traverse
         } else {
      default {
         PB_SET_RAPID_MOD $rapid_spindle_mod $rapid_spindle_blk aa mod_spindle
         PB_SET_RAPID_MOD $rapid_traverse_mod $rapid_traverse_blk aa mod_traverse
   if { ![string compare $spindle_first "TRUE"] } {
      if { ![string compare $rapid_spindle_inhibit "FALSE"] } {
         if { [string compare $spindle_block ""] } {
            PB_FORCE Once $mod_spindle
            MOM_do_template $spindle_block
         } else {
            MOM_output_literal "$co Rapid Spindle Block is empty! $ci"
      if { ![string compare $rapid_traverse_inhibit "FALSE"] } {
         if { [string compare $traverse_block ""] } {
            PB_FORCE Once $mod_traverse
            MOM_do_template $traverse_block
         } else {
            MOM_output_literal "$co Rapid Traverse Block is empty! $ci"
   } elseif { ![string compare $spindle_first "FALSE"] } {
         } else {
         } else {
   } else {
      MOM_do_template rapid_traverse
发表于 2019-4-29 15:21:24 | 显示全部楼层
学习学习
发表于 2019-4-29 20:44:37 | 显示全部楼层
支持一下!~谢谢分享
GMT+8, 2026-9-20 13:04
