查看: 9062|回复: 23
[分享] UG NX10.0正式版软件发行信息
站长优秀版主论坛技术员论坛元老论坛贡献推广达人
发表于 2014-12-19 10:03:48 | 显示全部楼层 |阅读模式
      NX                                              Version 10.0 Release
      Windows (64 Bit)                              Issued:  December 2014
      Files on this media are intended for use on 64 bit Windows 7 and
      Windows 8 platform only.
      ___________________________________________________________________
      INSTALLATIONS:
      To install the products on this media, run the 'launch' program at
      the top level, or change directory to the product directory and
      run the setup program contained within that directory.
      DOCUMENTATION:
      The 'docs' folder contains Installation documents and other related
      documents, which may be viewed or printed with your browser.
      NOTE:  Viewing Documentation directly from the media Launcher will
             require that the Adobe Acrobat plug-in is installed on your
             system.  No errors are given if the plug-in is not available.
             Download the plug-in from:  http://www.adobe.com/acrobat
      RELEASE INFORMATION:
      The What's New Guide and the Release Notes are contained in the
      REL_INFO kit.  This will be installed by default with the Typical
      installation option.  If you use the Custom installation option,
      it is recommended that you select the 'REL_INFO' kit.
      Once installed, both documents can be viewed from the start menu:
      Start -> Programs -> Siemens NX 10.0 -> Release Information ->
            *What's New
            *Release Notes
      A PDF copies of the Release Letter and What's New Guide are also
      provided in the "docs" folder.
          docs\release_notes.pdf
          - or -
      Further information is contained in the docs\README file.
      HTML versions of both the Release Notes and What's New are also
      contained with the NX 10 Documentation install.
关于很多人最关注的NX10.0正式版(网友版)最新进程请看:
http://www.ugsnx.com/thread-38284-1-1.html
参与人数 1G币 +5 收起 理由
嘻灬嘻 + 5 赞一个!
版主
VIP会员论坛元老
发表于 2014-12-19 10:06:25 | 显示全部楼层
  哈啥 老叶 NX10.0正式版终于来了  支持顶 顶 顶{}{}{}
发表于 2014-12-19 10:09:32 | 显示全部楼层
沙发呀!叶老!
发表于 2014-12-19 10:09:36 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-12-19 10:10:17 | 显示全部楼层
以为软件来了,不过还是支持!
43
优秀版主论坛技术员论坛元老
发表于 2014-12-19 10:10:30 | 显示全部楼层
{:}期待10.0的到来!!!!!!
爱好者终身VIP
灌水王VIP会员论坛贡献
发表于 2014-12-19 10:10:35 | 显示全部楼层
VB75106 发表于 2014-12-19 10:09
没看到啊
支持UG爱好者论坛!{:smile:}
发表于 2014-12-19 10:10:50 | 显示全部楼层
撒时候支持下载啊
发表于 2014-12-19 10:14:01 | 显示全部楼层
老叶啥时候上传啊,正在等你这句话呢
发表于 2014-12-19 10:14:44 | 显示全部楼层
老叶,这也太吊人胃口了吧?
GMT+8, 2025-1-10 01:35
