1. Run GetNodeId on the PC where you want to "transfer" somebody's key file.
2. It should show you your Ethernet Address (AKA MAC) and Key (id E12 locks to)
3. Run adjuster and enter:
3.1. Current PC name
3.2. Current Ethernet Address (MAC)
3.3. Current Key value
3.4. Desired Key value (01eb1be541a6 this time)
4. Then you'll see one or two new values for PC name and/or MAC.
4.1. If you see AND then you have to change BOTH your PC name and MAC to the values generated.
4.2. If you see OR then you have to change either your PC name or MAC to the values generated.
4.3. If you see only Hostname or MAC then you got lucky.
NB: if you have a number of network adapters in your system then you need to find out which one of them E12 detects (most probably it's of wired type). Then change just that value to one from 4.x
1.运行GetNodeId要“转让”某人的密钥文件在PC机上。
2.它应该告诉你你的以太网地址(MAC AKA)和键(id E12锁)
3.运行调节器,然后输入:
3.1。目前的PC名称
3.2。当前的以太网地址(MAC)
3.3。当前键值
3.4。期望中的键值(01eb1be541a6这个时候)
4.然后你会看到PC的名称和/或MAC一个或两个新值。
4.1。如果你看到,然后你必须改变你的PC机名称和MAC来生成的值。
4.2。如果你看到或则你必须改变你的任何PC的名称或MAC来生成的值。
4.3。如果你只看到主机名或MAC,那么你很幸运。
注意:如果你的系统中有多个网络适配器,那么你需要找出其中之一E12检测(最有可能是有线型)。然后从4.x的只是价值一改变
e12 链接:http://pan.baidu.com/share/link? ... 0&uk=4163066139 密码:10pk
e12_401bis.rar(238.35KB)
01EB1BE541A6_E_12_2014_11_53407.rar
(11.72 KB, 下载次数: 126)
