查看: 40549|回复: 372
[分享] Siemens Tecnomatix Plant Simulation 11 TR3(Siemens NX机器手模块)
 火... [复制链接]
50
发表于 2014-10-19 14:15:42 | 显示全部楼层 |阅读模式
Tecnomatix Plant Simulation以前叫em_plant,在Siemens收购后改名为Plant Simulation,它是面向对象的、图形化的、集成的建模、仿真工具,系统结构和实施都满足面向对象的要求。eM-Plant可以对各种规模的工厂和生产线,包括大规模的跨国企业,建模、仿真和优化生产系统,分析和优化生产布局、资源利用率、产能和效率、物流和供需链等。
Plant Simulation是世界领先的离散事件仿真软件,用于物流规划和制造生产量分析,同时它也是一款在进行离散事件仿真和价值流图设计时面向对象的3D建模工具。
Siemens Tecnomatix Plant Simulation 11 TR3 | 1.6 Gb
Siemens, a global powerhouse in electronics and electrical engineering, operating in the industry, energy and healthcare sectors, has released an update for Tecnomatix Plant Simulation 11, is the world’s leading discrete event simulation software used for logistics planning and manufacturing throughput analysis. Plant Simulation is an object oriented and 3D modeling tool used to perform discrete event simulation and value stream mapping.
Siemens released the new version Plant Simulation 11. A key topic of this new release is energy simulation, due to the increasing importance energy consumption has gained in production processes.
Plant Simulation 11 provides you with a tool for modeling, analysing and optimising production while taking energy consumption into account. Analyses regarding stand-by-operation of machines and energy saving potentials in production are now easily possible. Apart from many smaller adjustments, 3D integration has been improved.
Plant Simulation enables users to develop their own simulation building blocks as well as entire individual libraries or building block kits. SimPlan continually expands its range of application- and industry-oriented building block kits and makes them available to customers.
Apart from the building block kits assembly and value stream offered by Siemens, SimPlan has developed solutions for the automotive industry, for warehouse/logistics (Logistics Suite), supply chain (SimChain), solar/photovoltaics and shipbuilding.
Bonus: Siemens Tecnomatix Quality 8.0 Suite
The Tecnomatix Quality Management solution provides the market’s only end-to-end, fully closed-loop quality solution built on an enterprise-scalable foundation for identifying, analyzing and sharing critical product quality data across your enterprise.
About Siemens PLM Software
Siemens PLM Software, a business unit of the Siemens Industry Automation Division, is a global provider of product life-cycle management (PLM) software. PLM is the platform for turning more ideas into successful products because only PLM can provide the application depth and breadth needed to digitally author, validate, and manage the detailed product and process data necessary to support continuous innovation. Headquartered in Plano, Texas, Siemens PLM has 51,000 customers worldwide.
Name: Siemens Tecnomatix Plant Simulation
Version: 11 Build TR3
Home: www.plm.automation.siemens.com
Interface: multilanguage
OS: Windows Seven / 8
Download uploaded
http://uploaded.net/file/vukpdfog/emeSTecQ80Su.rar
http://uploaded.net/file/6krqv9a6/emeSTePSi11T3.part1.rar
http://uploaded.net/file/qgs0nz6k/emeSTePSi11T3.part2.rar
http://uploaded.net/file/i2zvxrnm/emeSTePSi11T3.part3.rar
http://uploaded.net/file/qy8jsmm2/emeSTePSi11T3.part4.rar
Download rapidgator
http://rg.to/file/29a442f9768702df958d5424dda83ebd/emeSTecQ80Su.rar.html
http://rg.to/file/eedd5a2e60ecea863762298f13bce287/emeSTePSi11T3.part1.rar.html
http://rg.to/file/339e91b64feb4131a3373c968e9b392f/emeSTePSi11T3.part2.rar.html
http://rg.to/file/f5b0038f198f813182fd82c57c16caa0/emeSTePSi11T3.part3.rar.html
http://rg.to/file/9c648112b06916409f02b15b88f3843a/emeSTePSi11T3.part4.rar.html
Download nitroflare
http://www.nitroflare.com/view/0BC2E13FEA5AC8A/emestecq80su.rar
http://www.nitroflare.com/view/06AF6023DBFE472/emestepsi11t3.part1.rar
http://www.nitroflare.com/view/3E72F2E1D801965/emestepsi11t3.part2.rar
http://www.nitroflare.com/view/E9573D158007D89/emestepsi11t3.part3.rar
http://www.nitroflare.com/view/474618A7D59ACE2/emestepsi11t3.part4.rar
发表于 2014-10-19 14:25:20 | 显示全部楼层
谢谢谢谢谢谢
发表于 2014-10-19 14:28:01 | 显示全部楼层
不知道 怎么用
发表于 2014-10-19 14:30:04 | 显示全部楼层
这个很好
55
发表于 2014-10-19 14:31:39 | 显示全部楼层
是真的吗?确定吗?
发表于 2014-10-19 14:37:29 | 显示全部楼层
谢谢 谢谢
发表于 2014-10-19 15:33:54 | 显示全部楼层
这是神马= =求解
发表于 2014-10-19 15:41:40 | 显示全部楼层
可以用NX上哇    下载学习学习
发表于 2014-10-19 16:18:35 | 显示全部楼层
顶顶顶顶顶顶顶顶顶
发表于 2014-10-19 16:19:16 | 显示全部楼层
好好看看
GMT+8, 2025-2-20 04:51
