查看: 825|回复: 2
[分享] 大师看看这代码输出开头刀具信息
发表于 2025-4-10 16:15:47 | 显示全部楼层 |阅读模式
大师看看这代码输出开头刀具信息
只输出了这种格式,但是没有输出刀具的信息    是啥情况   代码如下,请大师修改
LIB_GE_command_buffer_edit_append MOM_start_of_program_LIB PROGRAMSTART {
   global mom_cutter_info tool_name_list
   array set tool_check {}
   set duplicates ""
   set tool_name_list [lsort -dictionary -unique $::lib_pretreatment(tool_name_list)]
   MOM_ask_cutter_info tool_name_list
   foreach tool_name $tool_name_list {
       set tn $mom_cutter_info($tool_name,tool_number)
       if {[info exists tool_check($tn)]} {
           lappend duplicates "T$tn"
       set tool_check($tn) 1
       set td [expr {[info exists mom_cutter_info($tool_name,diameter)] ? $mom_cutter_info($tool_name,diameter) : 0}]
       set tr [expr {[info exists mom_cutter_info($tool_name,corner_radius)] ? $mom_cutter_info($tool_name,corner_radius) : 0}]
       set fl [expr {[info exists mom_cutter_info($tool_name,flute_length)] ? $mom_cutter_info($tool_name,flute_length) : 0}]
       set tl [expr {[info exists mom_cutter_info($tool_name,total_length)] ? $mom_cutter_info($tool_name,total_length) : 0}]
       LIB_GE_message "T${tn}=$tool_name\
D=[format %.0f $td]\
R=[format %.2f $tr]\
FL=[format %.0f $fl]\
TL=[format %.2f $tl]"
   if {[llength $duplicates] > 0} {
       LIB_GE_abort "DUPLICATE TOOL NUMBERS: [join $duplicates ", "]"
} _CUSTOM_TOOL_LIST
发表于 2025-6-27 19:02:32 | 显示全部楼层
谢楼分享6666666666
发表于 2025-7-11 19:55:34 | 显示全部楼层
学习学习
GMT+8, 2026-10-3 19:05
