查看: 46|回复: 5
[求助] UG12.0.0.29的安装一头雾水
发表于 2 小时前 | 显示全部楼层 |阅读模式
0. Uninstall ANY SIEMENS SPLM License Server if one is installed:
   - If the original SPLM License Server is installed, use "Programs and Features"   to remove it;
   - If SSQ SPLM License Server is installed, run as Administrator the "server_remove.bat",from the SPLM License Server folder
1. DO NOT install original SPLM License Server from NX-12.0.0 setup media!!!
2. Install or update the SolidSQUAD Universal License Server
   If SolidSQUAD Universal License Server has never been installed   on the computer:
     - unzip the "SolidSQUAD_License_Servers" folder from   "SSQ_UniversalLicenseServer_Core_<release-date>.zip" to any DRIVE ROOT
     folder X:\ (like C:\, D:\, E:\ etc), so the path will be:        X:\SolidSQUAD_License_Servers
     - unzip the "Vendors" folder from  "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"   to the "SolidSQUAD_License_Servers" folder
     - As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers"    folder and wait until it completes
   -- OR --
   If SolidSQUAD Universal License Server is already installed,  but the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip"   is newer than the installed one, update the server installation:  - As administrator run "uninstall.bat" from "SolidSQUAD_License_Servers"   folder and wait until it completes
     - unzip the "SolidSQUAD_License_Servers" folder from   "SSQ_UniversalLicenseServer_Core_<release-date>.zip" to any DRIVE ROOT ,
   -- OR --
   If the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip" is not newer   than the installed one but the release-date of
   "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip" is newer than the installed one,   update SiemensPLM module only:
5. Install NX-12.0.0 Win64. At setup when asked for license server port and name input 27800@localhost
6. Replace original <NX 12.0 program folder> (by default C:\Program Files\Siemens\NX 12.0) with cracked one
7. Reboot computer
8. Enjoy!
Cracked by TeAM SolidSQUAD-SSQ
这些英语说明很简单,都能看懂,无非是已安装过原西门子许可协议的卸载,安装过SSQ破解许可协议的,根破解版本的新旧日期决定卸载或升级安装,按照说明将破解文件解压到X:\SolidSQUAD_License_Servers下,如果以前没安装过就运行install_or_update.bat;如果以前安装过就先uninstall.bat,再install_or_update.bat,可是这样执行后,根本就没安装许可协议,是不是应该在何阶段安装许可协议?安装许可协议是先执行还是在执行完上面的操作之后进行?
 楼主| 发表于 1 小时前 | 显示全部楼层
是新机安装,只运行那个安装批处理就安装好许可协议了?可许可服务协议在这之前没安装呀?是不是应该在哪个阶段先安装许可协议,然后在破解?与以前其他版本的安装过程不一样吗?
就没有一个清清楚楚的、像以前的版本安装时破解替换过程的安装说明?
UG12.0.027版本我安装使用正常
发表于 1 小时前 | 显示全部楼层
自动安装不好吗
自动安装什么意思?
GMT+8, 2025-1-13 16:47
