查看: 2296|回复: 1
[分享] 使之独立带工程图宏
发表于 2024-6-17 11:56:58 | 显示全部楼层 |阅读模式
Private Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Boolean
Private Type OPENFILENAME
  lStructSize As Long
  hwndOwner As LongPtr
  hInstance As LongPtr
  lpstrFilter As String
  lpstrCustomFilter As String
  nMaxCustFilter As Long
  nFilterIndex As Long
  lpstrFile As String
  nMaxFile As Long
  lpstrFileTitle As String
  nMaxFileTitle As Long
  lpstrInitialDir As String
  lpstrTitle As String
  Flags As LongPtr
  nFileOffset As Integer
  nFileExtension As Integer
  lpstrDefExt As String
  lCustData As Long
  lpfnHook As Long
  lpTemplateName As String
End Type
Dim swApp As SldWorks.SldWorks
Sub main()
    Set swApp = Application.SldWorks
try_:
    On Error GoTo catch_
    Dim swModel As SldWorks.ModelDoc2
    Set swModel = swApp.ActiveDoc
    If Not swModel Is Nothing Then
        If swModel.GetType() = swDocumentTypes_e.swDocASSEMBLY Then
            Dim swAssy As SldWorks.AssemblyDoc
            Set swAssy = swModel
            Dim vComps As Variant
            vComps = GetSelectedComponents(swModel.SelectionManager)
            If Not IsEmpty(vComps) Then
                Dim i As Integer
                Dim path As String
                path = vComps(0).GetPathName()
                For i = 1 To UBound(vComps)
                    If LCase(vComps(i).GetPathName()) <> LCase(path) Then
                        Err.Raise vbError, "", "Only identical components are supported"
                    End If
                Next
                Dim ext As String
                ext = Right(path, Len(path) - InStrRev(path, ".") + 1)
                Dim filter As String
                Dim fileType As String
                If LCase(ext) = ".sldprt" Then
                    fileType = "SOLIDWORKS Parts"
                ElseIf LCase(ext) = ".sldasm" Then
                    fileType = "SOLIDWORKS Assemblies"
                Else
                    Err.Raise vbError, "", "Unknown error"
                End If
                filter = fileType & " (*" & ext & ")|*" & ext & "|All Files (*.*)|*.*"
                Dim replaceFilePath As String
                replaceFilePath = BrowseForFileSave("Select replacement file path", filter, path)
                If replaceFilePath <> "" Then
                    If False = swAssy.MakeIndependent(replaceFilePath) Then
                        Err.Raise vbError, "", "Failed to make components independent"
                    End If
                    MakeDrawingIndependent path, replaceFilePath
                End If
            Else
                Err.Raise vbError, "", "Select components"
            End If
        Else
            Err.Raise vbError, "", "Only assembly documents are supported"
        End If
    Else
        Err.Raise vbError, "", "No model found"
    End If
    GoTo finally_
catch_:
    MsgBox Err.Description, vbCritical
finally_:
End Sub
Sub MakeDrawingIndependent(srcFilePath As String, destFilePath As String)
    Dim srcDrwFilePath As String
    srcDrwFilePath = Left(srcFilePath, InStrRev(srcFilePath, ".") - 1) & ".slddrw"
    Dim destDrwFilePath As String
    destDrwFilePath = Left(destFilePath, InStrRev(destFilePath, ".") - 1) & ".slddrw"
    Dim fso As Object
    Set fso = CreateObject("Scripting.FileSystemObject")
    If fso.FileExists(srcDrwFilePath) Then
        If fso.FileExists(destDrwFilePath) Then
            Err.Raise vbError, "", "Destination drawing already exists"
        End If
        fso.CopyFile srcDrwFilePath, destDrwFilePath, False
        Dim destDrwFilePathAttr As VbFileAttribute
        destDrwFilePathAttr = GetAttr(destDrwFilePath)
        If destDrwFilePathAttr And vbReadOnly Then
            Debug.Print "Removing the read-only flag from the destination drawing: " & destDrwFilePath
            SetAttr destDrwFilePath, destDrwFilePathAttr Xor vbReadOnly
        End If
        If False = swApp.ReplaceReferencedDocument(destDrwFilePath, srcFilePath, destFilePath) Then
            Err.Raise vbError, "", "Failed to replace referenced drawing document"
        End If
    End If
End Sub
Function GetSelectedComponents(selMgr As SldWorks.SelectionMgr) As Variant
    Dim isInit As Boolean
    isInit = False
    Dim swComps() As SldWorks.Component2
    Dim i As Integer
    For i = 1 To selMgr.GetSelectedObjectCount2(-1)
        Dim swComp As SldWorks.Component2
        Set swComp = selMgr.GetSelectedObjectsComponent4(i, -1)
        If Not swComp Is Nothing Then
            If Not isInit Then
                ReDim swComps(0)
                Set swComps(0) = swComp
                isInit = True
            Else
                If Not Contains(swComps, swComp) Then
                    ReDim Preserve swComps(UBound(swComps) + 1)
                    Set swComps(UBound(swComps)) = swComp
                End If
            End If
        End If
    Next
    If isInit Then
        GetSelectedComponents = swComps
    Else
        GetSelectedComponents = Empty
    End If
End Function
Function BrowseForFileSave(title As String, filters As String, initFilePath As String) As String
    Dim ofn As OPENFILENAME
    Const FILE_PATH_BUFFER_SIZE As Integer = 260
    Dim initFileName As String
    initFileName = Right(initFilePath, Len(initFilePath) - InStrRev(initFilePath, "\"))
    ofn.lpstrFilter = Replace(filters, "|", Chr(0)) & Chr(0)
    ofn.lpstrTitle = title
    ofn.nMaxFile = FILE_PATH_BUFFER_SIZE
    ofn.nMaxFileTitle = FILE_PATH_BUFFER_SIZE
    ofn.lpstrInitialDir = Left(initFilePath, InStrRev(initFilePath, "\") - 1)
    ofn.lpstrFile = initFileName & String(FILE_PATH_BUFFER_SIZE - Len(initFileName), Chr(0))
    ofn.lStructSize = LenB(ofn)
    Dim res As Boolean
    res = GetSaveFileName(ofn)
    If res Then
        Dim filePath As String
        filePath = Left(ofn.lpstrFile, InStr(ofn.lpstrFile, vbNullChar) - 1)
        Dim vFilters As Variant
        vFilters = Split(filters, "|")
        Dim ext As String
        ext = vFilters((ofn.nFilterIndex - 1) * 2 + 1)
        ext = Right(ext, Len(ext) - InStrRev(ext, ".") + 1)
        If LCase(Right(filePath, Len(ext))) <> LCase(ext) Then
            filePath = filePath & ext
        End If
        BrowseForFileSave = filePath
    Else
        BrowseForFileSave = ""
    End If
End Function
Function Contains(vArr As Variant, item As Object) As Boolean
    Dim i As Integer
    For i = 0 To UBound(vArr)
        If vArr(i) Is item Then
            Contains = True
            Exit Function
        End If
    Next
    Contains = False
End Function
发表于 2024-6-17 15:12:12 | 显示全部楼层
厉害厉害!!
发表于 2024-6-17 16:30:22 | 显示全部楼层
厉害厉害!!
GMT+8, 2026-9-18 01:13
