查看: 1078|回复: 2
[求助] UF_MODL_model_compare_3函数可否指导下
发表于 2023-11-8 08:46:49 | 显示全部楼层 |阅读模式
请教各位,有没有人用过UF_MODL_model_compare、UF_MODL_model_compare_2、UF_MODL_model_compare_3这三个函数中的一个,可否指导下或给个案例代码,谢谢
发表于 2023-11-8 14:35:18 | 显示全部楼层
  1. import NXOpen_UF
  2. import NXOpen
  3. theSession:NXOpen.Session=NXOpen.Session.GetSession()
  4. lw:NXOpen.ListingWindow=theSession.ListingWindow
  5. theUfSession: NXOpen_UF.UFSession = NXOpen_UF.UFSession.GetUFSession()
  6. modl:NXOpen_UF.Modl=theUfSession.Modl
  7. mtx4:NXOpen_UF.Mtx4=theUfSession.Mtx4
  8. part:NXOpen_UF.Part=theUfSession.Part
  9. tag1=part.OpenQuiet('D:\\1.prt')[0]
  10. tag2=part.OpenQuiet('D:\\2.prt')[0]
  11. options=modl.CompareOptions()
  12. options.Tolerance=0.001
  13. options.Accuracy=modl.CompareAccuracy.COMP_DEFAULT
  14. result=modl.ModelCompare2(tag1,0,mtx4.Identity(),tag2,0,mtx4.Identity(),options)
  15. lw.Open()
  16. lw.WriteLine(f"NumEntities:{result.Part1.Edges.NumEntities}")
  17. for x in result.Part1.Edges.EntityInfo:
  18.     lw.WriteLine(f"{x}")
  19. lw.WriteLine('==========================================')
  20. lw.WriteLine(f"NumEntities:{result.Part2.Edges.NumEntities}")
  21. for x in result.Part2.Edges.EntityInfo:
  22.     lw.WriteLine(f"{x}")
复制代码
 楼主| 发表于 2023-11-9 08:32:10 | 显示全部楼层
GMT+8, 2025-2-23 18:02
