查看: 3257|回复: 3
[2212系列] NX2212.6000(5月份补丁修复列表)
发表于 2023-5-12 16:17:53 | 显示全部楼层 |阅读模式
安装包不能发只能发更新内容 Release_Notes.rar (218.63 KB, 下载次数: 47)
DescriptionApplicationFunctionSub_Function
catiav5.exe run under Teamcenter 4 TierTRANSLATORCATIAV5USABILITY
TcX_Failed to Open in NX from Active  Workspace URL.NXMANAGERAUTOTESTAUTOTEST
About RigidGroup that can be selected in  BondMFG_FIXTURE_PLGENERALSUPPORT
Fehlermeldung, beim Save as ->  Revise...: Internal error memory access violatiARCHITECTUREUSER_ATTRIBUTESGENERAL
NX1980 uses much more memory than NX1953  while saving.ASSEMBLIESASSEMBLY_MODELFACET_JT_REPS
Error handling failed: General Fault  Exception if Save as from AssemblyARCHITECTUREUSER_ATTRIBUTESGENERAL
Columns Modification in Simulation  Navigator is not savedCAEADV_SIMULATIONNAVIGATOR
Configuration of columns in  "Simulation Navigator" will not be savedCAEADV_SIMULATIONNAVIGATOR
Code 943005 "Input for part  revision was invalid" when translating drawing to PDNXMANAGERTRANSLATORSINFRASTRUCTURE
Corrupt data found when loading an OM  fileNX_SHEET_METALALLALL
Display of Object column in NX ANT  incomplete if legacy multi-level assembly isNXMANAGERASSEMBLY_NAVTC_PROP_COL
Unable to open part with error - Corrupt  data found when loading an OM fileDESIGNFEATURE_MODELDATUM_CSYS
General Fault Exception in NXDieoutCAEADV_SIMULATIONNXOPEN
Class id error, opening a PID SheetP&ID_DESIGNERSHEETLOAD_SHEET
When we save the part file it is  consuming large memory size.ASSEMBLIESASSEMBLY_MODELFACET_JT_REPS
NX2023 design session fails to save on  2nd time saveDMUDESIGN_SESSIONALL
Probe evaluates at incorrect subcase for  MP Coupled solution inc ContactCAEADV_SIMULATIONPOST_PROBE
Poor NX software performance in assembly  context with changing current featureASSEMBLIESASSEMBLY_MODELPERFORMANCE
NX Drafting PRT File Will Not Open -  Corrupt Data Found When Opening An OM FileCORRUPTED_PARTSOPEN_PARTALL
Cannot load NX11-Routing-File - Corrupt  data found when loading an OM fileDESIGNFEATURE_MODELDATUM_CSYS
CMM Inspection Programming worked fine  in NX12, but takes 45 minutes for dialogCMM_INSPECTIONSIMULATIONALL
Remote Object in structure causes LW BOM  expansion to fail with internal errorSTRUCTURE_MGRLIGHTWEIGHTBOMSOA
Sync- Initialize Simulation  deactivate-unidentified channel name-internal errorCAMSYNCHRONIZATIONISV
Unable to mass edit the attributes of  FBM features in NX2007CAMFEATURE_BASEDUSER_INTERFACE
an abstract method was incorrectly  calledARCHITECTUREUSER_ATTRIBUTESGENERAL
The count value is not matching with  Older version.KDAMOLDWIZARDDESIGN_PROCESS
NX 2206 is not allowing the customer to  copy PMI down into a staged modelSTAGE_MODELPMI_REUSECORE
Ped Pro NCAP test points are not on  multiple layersKDAGENERAL_PACKAGEPEDPRO
Ped Pro results comparison of two filesKDAGENERAL_PACKAGEPEDPRO
Nodal force report not working with  results from an initial stepCAEADV_SIMULATIONPOST_OTHER
One Step - Mesh Quality Check dialog  doesn't popup after CalculationDESIGNINFO_ANALYSISONESTEP_ANALYSI
PMI Wave Linker fails with message  "dependent geometry is not in active referencPMIWAVECORE
NX: Part saved in 1953 cannot be loaded  in 2007DESIGNFEATURE_MODELDATUM_CSYS
Fatal error when switching assembly  windows or updating Mass Properties - InvaliASSEMBLIESWEIGHT_MANAGEALL
Object Selection performance in NXCAMFEATURE_BASEDUSER_INTERFACE
Ped Pro Child and adult zone incorrect  for this BRRL caseKDAGENERAL_PACKAGEPEDPRO
Feature2Cost Stamping Analyze Does not  detect Bending, Drawing, or Embossing AreKDAFEATURE2COSTSTAMPING_COST
NX is forced to close when saving a part  file with many bodies.ASSEMBLIESASSEMBLY_MODELFACET_JT_REPS
DMU Snapshots fail to load componentsDMUSNAPSHOTGENERAL
Ped Pro Improve Corner CRP to WAD1000  projection for this specific caseKDAGENERAL_PACKAGEPEDPRO
"Attribute Culumn Selector" in  ANT property cannot be executed.NXMANAGERATTRIBUTESATTR_GROUPS
Symbol designer snapping to geometry  rather than gridKDANX_DIAGRAMMINGDESIGN
Bad performance of part familiy editing  compared to NX 2027KDAREUSE_LIBRARYREUSE_TC_LIB
INTERNAL ERROR: Memory access violation  when PID Symbol is positionedP&ID_DESIGNERLIBRARYREUSE_LIBRARY
NXMGR: Fail to Save As New Item in  migrated environmentARCHITECTUREUSER_ATTRIBUTESGENERAL
NX DMU Replace raises an Internal Error.DMUSNAPSHOTGENERAL
Turning IPW Display ErrorCAMTURNINGIPW
SC2022.1-Probleme de moyennationCAEADV_SIMULATIONPOST_RESULT
drafting load data errorARCHITECTUREOMLOAD
Diagramming parts are opened twice in NXKDANX_DIAGRAMMINGDESIGN
DT:Move remote object pop up to summary  page or preference to suppress the popupNXMANAGERFILE_OPENALL
Symbolic Thread with pocket design  commandKDAMOLDWIZARDPOCKET_DESIGN
DMU Snapshots Load issues  "nullpointer"DMUSNAPSHOTGENERAL
NXMGR: NX duplicate dimensions in DMU  SnapshotsDMUDESIGN_SESSIONALL
No Way to Modify Attributes Value in the  new MFN Navigator for Multiple FeatureCAMFEATURE_BASEDUSER_INTERFACE
Wrong legend max value on hiding  elementsCAEADV_SIMULATIONPOST_RESULT
Filter for Routing Reuse Search is not  showing all membersROUTING_GENERALREUSE_LIBRARYSEARCH
Symbol fill causes a thicker symbol lineKDANX_DIAGRAMMINGDESIGN
Wrong averaged bending Von Mises on  shellsCAEADV_SIMULATIONPOST_RESULT
Subcase errors for stress linearizationCAEADV_SIMULATIONPOST_OTHER
Routing and unrouting of cable stock is  not working in NX2206ROUTING_ELECCONNECTION_LISTAUTO_ROUTE
发表于 2023-5-12 16:28:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
133
中将
发表于 2023-5-12 17:21:48 | 显示全部楼层
每個月的歡樂時光{}{}
133
中将
发表于 2023-5-12 17:22:20 | 显示全部楼层
每個月的歡樂時光{}{}
67
发表于 2023-5-13 09:46:21 | 显示全部楼层
试了一下,流畅度要好一些。
GMT+8, 2025-12-19 00:19
