[分享] PC后处理制作刀具列表
发表于 2024-6-23 16:12:14 | 显示全部楼层
topckey 发表于 2024-6-22 11:51
什么是PC,PB又是什么?
PC是POST配置器的缩写,PB是POST构造器的缩写。
发表于 2024-8-3 10:27:48 | 显示全部楼层
tombai691019 发表于 2023-5-5 18:19
大佬:按照你的方法,语句都一样,为什么只能取到刀具号,刀具名。其它参数:刀具直径,最短刀长,最长刀长 ...
楼主:请问能不能给我个代码,按照图片来的报警
发表于 2024-8-3 10:29:00 | 显示全部楼层
楼主:请问能不能给我个完整的代码,我按照图片整了个,报警用不了,谢谢!
发表于 2024-8-3 21:43:20 | 显示全部楼层
LIB_GE_command_buffer_edit_append LIB_SPF_program_header_comment HEADER_COMMENT {
  global format mom_cutter_info
set format ">3> | <15< | <5< | <8< |<8< |"
set e ""
set tool_list ""
LIB_GE_message "NEWLINE"
LIB_GE_message "****** TOOL LIST ******"
LIB_GE_message "=================================================="
LIB_GE_message "[LIB_DC_format_string $format [list "刀具号" "   刀具名称" "刀具半径" "刀长"]]"
set tool_name_list [lsort -dictionary -unique $::lib_pretreatment(tool_name_list)]
MOM_ask_cutter_info tool_name_list
  global mom_tool_extension_length
  foreach tool_name $tool_name_list {
  if {![info exist mom_cutter_info($tool_name,cutter_description)]} {set mom_cutter_info($tool_name,cutter_description) " ------ "}
    LIB_GE_message "[LIB_DC_format_string $format [list "T$mom_cutter_info($tool_name,tool_number)" " $tool_name" "$mom_cutter_info($tool_name,tool_diameter)" "$mom_cutter_info($tool_name,tool_length)"]]"
     foreach i [LIB_SPF_get_pretreatment operation_list] {
    #MOM_output_literal "(Z_min: [LIB_SPF_get_pretreatment limit,z,min 0 $i],Z_max: [LIB_SPF_get_pretreatment limit,z,max 0 $i)"
   MOM_output_literal "(T[LIB_SPF_get_pretreatment mom_tool_number 0 $i],   [LIB_SPF_get_pretreatment mom_tool_name 0 $i],   [format " D = %.2f" [LIB_SPF_get_pretreatment mom_tool_diameter 0 $i] ]   Z_min: [LIB_SPF_get_pretreatment limit,z,min 0 $i],   Z_max: [LIB_SPF_get_pretreatment limit,z,max 0 $i],   [format " Length = %.2f" [LIB_SPF_get_pretreatment mom_tool_length 0 $i] ])"
set zmin                 [LIB_SPF_get_pretreatment   limit,z,min    0 $i]
set zmax            [LIB_SPF_get_pretreatment   limit,z,max                0 $i]
set Tname                [LIB_SPF_get_pretreatment  mom_tool_name  0 $i]
set Tnumber                [LIB_SPF_get_pretreatment   mom_tool_number 0 $i]
set td                     [LIB_SPF_get_pretreatment    mom_tool_diameter        0 $i]
MOM_output_literal "[format "T%-1s D=%-4s %-7s name:%-1s" $Tnumber $td Z=$zmin $Tname]"
不知道怎么更改,钻头的深度是不对的
发表于 2025-3-16 16:35:55 | 显示全部楼层
复制进去报警啊  哪里的问题
发表于 2025-4-4 10:39:00 | 显示全部楼层
谢谢分享!谢谢分享!
发表于 2025-4-6 20:00:10 | 显示全部楼层
666版主真的厉害啊
发表于 前天 10:52 | 显示全部楼层
感谢楼主分享!很实用很好用的分享!点赞点赞点赞点赞点赞!
GMT+8, 2025-4-19 18:50
