查看: 4445|回复: 15
[已回复] UG高版本的攻丝,后处理怎么设置,攻丝循环用(钻,攻丝,深)后处理就处理不出来。
发表于 2023-1-14 18:55:57 | 显示全部楼层 |阅读模式
攻丝循环用(钻,攻丝,深)后处理就处理不出来了,用(钻,攻丝)就能处理。后处理加了Q也不行。
发表于 2023-1-15 20:17:46 | 显示全部楼层
手动添加的方式, 用记事本打开*.pui文件, 找到下以内容对应的地方,替换掉就行了.
第一个地方
  1. #Cycle Block Share Common Block Start
  2. { \
  3.   {Drill} \
  4.   {Drill Dwell} \
  5.   {Drill Deep} \
  6.   {Drill Break Chip} \
  7.   {Tap} \
  8.   {Tap Float} \
  9.   {Tap Deep} \
  10.   {Tap Break Chip} \
  11.   {Bore} \
  12.   {Bore Drag} \
  13.   {Bore No Drag} \
  14.   {Bore Dwell} \
  15.   {Bore Manual} \
  16.   {Bore Back} \
  17.   {Bore Manual Dwell} \
  18. }
复制代码
第二个地方
  1. #Cycles Start
  2. {Cycle Parameters}         {PB_CMD_set_cycle_plane post_cycle_set}  {$gPB(event,cycle,com_param,name)}
  3. {Cycle Off}                {cycle_off PB_CMD_remove_M29}  {$gPB(event,cycle,cycle_off,name)}
  4. {Cycle Plane Change}       {}  {$gPB(event,cycle,plane_chng,name)}
  5. {Drill}                    {cycle_drill}  {$gPB(event,cycle,drill,name)}
  6. {Drill Dwell}              {cycle_drill_dwell}  {$gPB(event,cycle,drill_dwell,name)}
  7. {Drill Text}               {}  {$gPB(event,cycle,drill_text,name)}
  8. {Drill Csink}              {}  {$gPB(event,cycle,drill_csink,name)}
  9. {Drill Deep}               {PB_CMD_remove_q0 PB_CMD_custom_force_once_x_y cycle_drill_deep}  {$gPB(event,cycle,drill_deep,name)}
  10. {Drill Break Chip}         {PB_CMD_remove_q0 PB_CMD_custom_force_once_x_y cycle_drill_break_chip}  {$gPB(event,cycle,drill_brk_chip,name)}
  11. {Tap}                      {PB_CMD_set_cycle_plane PB_CMD_tap_feed PB_CMD_tap_gcode tap_4 cycle_tap_3 tap_5}  {$gPB(event,cycle,tap,name)}
  12. {Tap Float}                {PB_CMD_set_cycle_plane PB_CMD_tap_feed PB_CMD_tap_gcode tap_float_1 cycle_tap_float tap_float_2}  {$gPB(event,cycle,tap_float,name)}
  13. {Tap Deep}                 {PB_CMD_set_cycle_plane PB_CMD_remove_q0 PB_CMD_tap_feed PB_CMD_tap_gcode tap_deep_2 cycle_tap_deep tap_deep_3}  {$gPB(event,cycle,tap_deep,name)}
  14. {Tap Break Chip}           {PB_CMD_set_cycle_plane PB_CMD_remove_q0 PB_CMD_tap_feed PB_CMD_tap_gcode tap_break_chip_1 cycle_tap_break_chip tap_break_chip_2}  {$gPB(event,cycle,tap_break_chip,name)}
  15. {Bore}                     {cycle_bore}  {$gPB(event,cycle,bore,name)}
  16. {Bore Drag}                {cycle_bore_drag}  {$gPB(event,cycle,bore_drag,name)}
  17. {Bore No Drag}             {cycle_bore_no_drag}  {$gPB(event,cycle,bore_no_drag,name)}
  18. {Bore Manual}              {cycle_bore_manual}  {$gPB(event,cycle,bore_manual,name)}
  19. {Bore Dwell}               {cycle_bore_dwell}  {$gPB(event,cycle,bore_dwell,name)}
  20. {Bore Back}                {cycle_bore_back}  {$gPB(event,cycle,bore_back,name)}
  21. {Bore Manual Dwell}        {cycle_bore_manual_dwell}  {$gPB(event,cycle,bore_manual_dwell,name)}
  22. {Peck Drill}               {}  {$gPB(event,cycle,peck_drill,name)}
  23. {Break Chip}               {}  {$gPB(event,cycle,break_chip,name)}
  24. #Cycles End
复制代码
 楼主| 发表于 2023-1-16 12:30:12 | 显示全部楼层
丿纯白丶 发表于 2023-1-16 10:33
还没用高版本的,这两个命令有什么区别?分别针对什么
模板不一样,高版本没有继续开发drill模块了。要是想用就得自己调用低版本的模板,高版本是用hole-making。
发表于 2023-1-14 22:31:51 | 显示全部楼层
你需要重写后处理选择fanuc30i,不要选fanuc6m
或者手动添加上面4种,不然是不支持的。
 楼主| 发表于 2023-1-14 18:57:38 | 显示全部楼层
有没有大佬指教一下,后处理改那里。试了好多方法都不行。
发表于 2023-1-15 02:10:43 | 显示全部楼层
我也想知道
 楼主| 发表于 2023-1-15 09:29:37 | 显示全部楼层
或者手动添加上面4种,不然是不支持的。
好的,感谢大佬指点。
 楼主| 发表于 2023-1-15 13:26:05 | 显示全部楼层
就是后处理的问题,我用的都是很多年前6.0时代的后处理,现在用的2206版本,后处理不支持高版本的一些功能,最简单的办法就是调出drill模块攻丝就没有问题。实在要用的就是有换个高级版本一些的后处理把。
我也试着重做一个后处理但是不行技术还没学到家,直接放弃了。
我现在就是用的drill的模块攻丝。
以后有时间在来深入研究学习后处理。
29
论坛贡献活跃会员可爱天使一等奖
发表于 2023-1-15 20:01:17 | 显示全部楼层
或者手动添加上面4种,不然是不支持的。
手动添加……可能不好添加吧,只有基于新的再重新做一个了
发表于 2023-1-16 10:33:29 | 显示全部楼层
GMT+8, 2025-3-14 09:47
