查看: 1779|回复: 1
[求助] 求各位二次开发大佬看看为啥咱uf5947报错
发表于 2023-1-7 13:44:48 | 显示全部楼层 |阅读模式
  1. UF_initialize();
  2.         //创建块
  3.         double origin[3]={0.0,0.0,0.0};
  4.         char* dimensions[3] = { "100","200","300" };
  5.         UF_FEATURE_SIGN sign = UF_NULLSIGN;
  6.         tag_t parttag = NULL_TAG;
  7.         UF_MODL_create_block1(sign, origin, dimensions, &parttag);
  8.         //创建平移或复制的矩阵
  9.         double tra[3] = { 500.0,500.0,500.0 };
  10.         double mix[16];
  11.         uf5943(tra, mix);
  12.         //测试平移或复制
  13.         int number_obj = 1;
  14.         int dest_layer = 0;
  15.         int move_or_copy = 1;
  16.         int trace_curvers = 2;
  17.         tag_t copies = NULL_TAG ;
  18.         tag_t trace_curve_group = NULL_TAG;
  19.         int status = NULL;
  20.         tag_t obj[] = { parttag };
  21.         uf5947(mix, obj, &number_obj, &move_or_copy, &dest_layer, &trace_curvers, &copies, &trace_curve_group, &status);
  22.         char message[256];
  23.         sprintf(message, " % d", status);
  24.         uc1601(message, 1);
  25.
  26.         UF_terminate();
复制代码
咱本来是想测试复制块的,但是会报错askusermessage( ) or askSyslogMessage,无法得到status状态码
于是我试试平移,发现这个代码无法成功,status状态码是3,即Invalid Object (Not Alive Or Not
Transformable)。求教各位大佬看看哪里错了
发表于 2023-1-18 14:04:03 | 显示全部楼层
uf5947操作的是object而不是Feature
GMT+8, 2026-9-19 23:20
