发表于 2022-12-13 09:04:04
显示全部楼层
proc PB_CMD_103 { } {
set outputthd 1
global toollist mom_tool_cutcom_register mom_cutcom_adjust_register mom_tool_name mom_tool_diameter mom_tool_corner1_radius mom_tool_adjust_register mom_tool_adj_reg_defined mom_tool_number
set tdi [ format "%.2f" $mom_tool_diameter]
set tr [ format "%.2f" $mom_tool_corner1_radius]
if [info exists mom_tool_number] {
set tt $mom_tool_number
} else {
set tt 0
if [info exists mom_tool_adj_reg_defined] {
set th $mom_tool_adjust_register
} else {
set th 0
set td $mom_tool_cutcom_register
} else {
set td 0
set tt [format "%02.0f" $tt]
set th [format "%02.0f" $th]
set td [format "%02.0f" $td]
if {$outputthd == 1 } {
#MOM_output_literal "(T$tt:$mom_tool_name D=$tdi R=$tr H$th D$td)"
} else {
#MOM_output_literal "(T00:$mom_tool_name D=$tdi R=$tr H00 D$00)"
global toollist max_z min_z mom_tool_number mom_tool_name
global toollist mom_tool_name mom_tool_diameter mom_tool_corner1_radius mom_tool_number
set zmax [ string trimright [ format %.2f $max_z ]mm 0 ]
set zmin [ string trimright [ format %.2f $min_z ]mm 0 ]
set mom_tool_number [format "%02.0f" $mom_tool_number]
set tool_mes [format "%-8s %-8s %-8s" T$mom_tool_number:$mom_tool_name D=[ format "%.2f" $mom_tool_diameter ] R=[ format "%.2f" $mom_tool_corner1_radius ]\ \ \H$th\ \ \D$td\ \ \MaxZ=[ format %.2f $max_z ]mm\ \ \MinZ=[ format %.2f $min_z ]mm ]
