查看: 2901|回复: 3
[求助] 求助PowerMill后处理器错误–Failed to get translator version from registry
发表于 2022-12-6 14:12:06 | 显示全部楼层 |阅读模式
新手一个   后处理错误不知道怎么解决后处理器错误–Failed to get translator version from registry
发表于 2023-4-1 11:07:24 | 显示全部楼层
zhangbo0372 发表于 2023-4-1 11:01
"Failed to get translator version from registry" when writing NC programs in PowerMill
Autodesk S ...
https://www.autodesk.com/support ... y-in-PowerMIll.html
下载DuctPost_1.zip;重新安装
发表于 2023-4-1 11:01:03 | 显示全部楼层
Autodesk Support
Jun 1, 2022
Issue:
PowerMill fails to write NC programs. Getting error: "Failed to get translator version from registry", after installing software on a new PC or removing legacy versions. Sometimes, PowerMill will close after the error message is populated.
One or both following error are displayed:
PowerMill Error:
Postprocessor Error - Failed to get translator version from registry.
PowerMill Error: Failed to get translator version from registry
PowerMill Error:
           Postprocessor Error - Failed to get translator version from registry. Please ensure that Autodesk                               Manufactoring Post Processor Utility is installed and that it has been registered correctly.
发表于 2023-4-1 11:05:00 | 显示全部楼层
Autodesk Support
Jun 1, 2022
Issue:
PowerMill Error:
PowerMill Error:
重新安装DuctPost就可以
GMT+8, 2025-12-16 03:28
