楼主: 阿兹莫丹
[2206系列] NX2206.7000无法导出CAD
4万
发表于 2022-11-27 12:12:24 | 显示全部楼层
127
中将
发表于 2022-11-28 08:25:26 | 显示全部楼层
我的導出沒問題
Unigraphics NX2206.7001 / 2D Exchange
Reading part: F:\cloudbox\2018_NX12\長伸\0918\0918-A.prt
Writing part: F:\UG-TMP\ej7m4AC8A49917nc.prt
Elapsed time   :    0 minutes,  3 seconds
Actual CPU Time:    0 minutes,  2 seconds
                  Annotation Summary
Dimensions in input Part
Linear                                         :        13
Total                                          :        13
Other annotations in input Part
Note                                           :        5
Total                                          :        5
Dimensions in output 2D Part
Linear                                         :        13
Total                                          :        13
Other annotations in output 2D Part
Note                                           :        5
Total                                          :        5
INFO-
INFO-                Unigraphics Version NX2206.7001 to AutoCAD 2004
INFO-
INFO-
INFO-                Running UGTODWG Translator .....
INFO-
INFO-                Start of Translation: Mon Nov 28 08:22:00 2022
INFO-
STATUS-                Converting F:\UG-TMP\ej7m4AC8A49917nc.prt
STATUS-
SUMMARY-
SUMMARY-        Summary of Unigraphics Input Entities
SUMMARY-        For Unigraphics File: F:\UG-TMP\ej7m4AC8A49917nc.prt
SUMMARY-        ------------------------------------------------------------------
SUMMARY-        Entity Type                                        Count
SUMMARY-        Line .....................................:        146
SUMMARY-        Point ....................................:        16
SUMMARY-        Conic ....................................:        20
SUMMARY-        Note .....................................:        5
SUMMARY-        Cross Hatch ..............................:        2
SUMMARY-        Dimension ................................:        13
SUMMARY-        Total ....................................:        202
SUMMARY-
STATUS-
INFO-
INFO-                Writing File: C:\RAM-TMP\0918-A.dwg
SUMMARY-        Summary of AutoCAD Output Entities
SUMMARY-        Line .....................................:        227
SUMMARY-        Ellipse ..................................:        20
SUMMARY-        Solid 2D .................................:        28
SUMMARY-        Hatch ....................................:        2
SUMMARY-        Multiline Text ...........................:        38
SUMMARY-        Layout ...................................:        6
SUMMARY-        Total ....................................:        350
SUMMARY-
INFO-
INFO-                End of Translation: Mon Nov 28 08:22:00 2022
INFO-                Translation CPU time: 0 m, 1 sINFO-
60
发表于 2022-12-2 18:42:41 | 显示全部楼层
你的不会报错吗?我的也可以导出,就是会报错。然后尝试过发现,prt文件的存放路径必须是全英文,导出路径必须全英文,这样就不会报错。
4万
发表于 2022-12-2 20:09:01 | 显示全部楼层
zwaiwo* 发表于 2022-12-2 18:42
你的不会报错吗?我的也可以导出,就是会报错。然后尝试过发现,prt文件的存放路径必须是全英文,导出路 ...
的确如此!不能用中文名及中文目录名,否则会报错,当然你也可以无视,因为导出是成功的。
发表于 2022-12-4 21:55:29 | 显示全部楼层
我的可以啊,Win11
发表于 2022-12-6 09:39:49 | 显示全部楼层
我也新买的电脑,win11家庭版,原来用1847可以正常导出CAD,换了2206就出错倒不出来,一直降级,从2007一直降到1926,各个版本都试了个遍,都是导不出CAD,后来只能又退回1847了,感觉会不会是Windows系统是家庭版的缘故,可能一定要专业版才行吧
 楼主| 发表于 2022-12-6 09:47:46 | 显示全部楼层
tq032lo 发表于 2022-12-6 09:39
我也新买的电脑,win11家庭版,原来用1847可以正常导出CAD,换了2206就出错倒不出来,一直降级,从2007一直 ...
这样吗?我刚更新了最新的NX2206.8060版本,依然是导不出{:cry:}
发表于 2022-12-6 10:00:40 | 显示全部楼层
我之前也是花了整整3天时间,网上各种方法都试过了,各种版本,各种设置,还有显卡驱动,都没有用。就差系统没换了,新电脑自带的系统比较稳定,优化的也比较好,就不想换了,就1847用用算了
 楼主| 发表于 2022-12-6 10:07:16 | 显示全部楼层
tq032lo 发表于 2022-12-6 10:00
我之前也是花了整整3天时间,网上各种方法都试过了,各种版本,各种设置,还有显卡驱动,都没有用。就差系 ...
看来想要用最新版只能重装win11专业版了,新电脑我也不想折腾,没想到家庭版win11对工业软件如此不友好{:sweat:}
发表于 2022-12-6 10:12:16 | 显示全部楼层
是的,我也放弃了,不想折腾了,白白浪费了这么多精力。其实我只想体验了一下新草图和同步建模中的一些新功能,觉得挺方便的,所以想用一下,但是不能导出的dwg是个大问题
GMT+8, 2024-12-25 08:58
© 2001-2024 Discuz! Team.
