查看: 16001|回复: 11
[分享] [原创] UG自动生成bom表源代码
发表于 2014-7-1 21:33:56 | 显示全部楼层 |阅读模式
源代码如下:
  1. 生成bom表ENTITY/obj(1000),ln1,ln2,ln3,pla(6),$
  2.                 ln4,ln5,ln6,ln7,ln8,ln9,ln10,ln(1000)
  3.       NUMBER/x(1000),y(1000),z(1000),p(6),h,w(50),I,J,N,lo,$
  4.               xmin,xmax,ymin,ymax,zmin,zmax,w1,distan(7),$
  5.                 x1,y1,z1,v,ans,m(100),u1,mindis(6),$
  6.                m1(1000),num(1000),num1(1000),l,p1,q1,r1
  7.       STRING/a(1000),b(1000),c(1000),d(1000),getname(1000,1000),$
  8.              name(1000,1000),t(10),stock(1000,1000),fix(1000),$
  9.              half(4,1000),part_name(132)
  10.       DATA/half,'罗鸣提示:选择的实体是哪侧镶件',$
  11.              '定模镶件',$
  12.              '动模镶件',$
  13.              '滑块镶件'
  14. l10:
  15.       mask/70
  16.       ident/'罗鸣提示:选择镶件实体,数目小于100',obj,CNT,N,rsp
  17.       jump/l10:,hal:,,,rsp
  18.       p1=0
  19. l20:
  20.       DO /l30:,J,1, N
  21.   l21:    getname(J)=&NAME(obj(J))
  22.          ifthen/lenf(getname(J))==0
  23.          r1=&COLOR(obj(J))
  24.           &COLOR(obj(J))=&RED
  25.          messg/'罗鸣提示:红色实体没有命名'
  26.
  27.     a7:
  28.         TEXT/'罗鸣提示:输入红色实体名称',part_name,RSP1
  29.        JUMP/a7:,hal:,,RSP1
  30.          &name(obj(J))=part_name
  31.         &COLOR(obj(J))=r1
  32.         jump/l21:
  33.         ELSE
  34.         endif
  35.
  36. l30:
  37.      J=1
  38.     m(J)=1
  39.     num(J)=0
  40. l40:
  41.       DO /L50:,I,1,N
  42.         ans=CMPSTR(getname(J),getname(I))
  43.          IFTHEN/ans==1
  44.               m(J)=m(J)+ans
  45.               num(J)=num(J)
  46.          ELSEIF/ans==0
  47.             m(J)=m(J)
  48.             num(J)=num(J)+1
  49.           ELSE
  50.              m(J)=m(J)
  51.              num(J)=num(J)
  52.           ENDIF
  53. L50:
  54.     IFTHEN/J>N
  55.          JUMP/l60:
  56.       ELSE
  57.          J=J+1
  58.          m(J)=1
  59.          num(J)=0
  60.          JUMP/l40:
  61.       ENDIF
  62. l60:
  63.        CHOOSE/half(1..4),DEFLT,1,RSP
  64.        JUMP/l60:,hal:,,,l70:,l80:,l90:,RSP
  65. l70:
  66.       fix='_fix_'
  67.        l=100
  68.       JUMP/l100:
  69. l80:
  70.        fix='_move_'
  71.         l=300
  72.        JUMP/l100:
  73. l90:
  74.        fix='_slide_'
  75.         l=500
  76. l100:
  77.       VIEW/1
  78.      GPOS/'罗鸣提示:选择备料单表格放置点',$
  79.          x1,y1,z1,rsp
  80.      JUMP/l100:,hal:,,,,rsp
  81.       w(1)=10
  82.       w(2)=30
  83.       w(3)=60
  84.       w(4)=10
  85.       h=6
  86.       ln1=LINE/x1,y1,x1+w(1)+w(2)+w(3)+w(4),y1
  87.       u1=0
  88. l110:
  89.       DO /l120:,I,1,N
  90.         IFTHEN/num(I)==1
  91.        u1=u1+num(I)
  92.        ELSE
  93.        u1=u1+1/num(I)
  94.         ENDIF
  95. l120:
  96.        K=1
  97.        J=1
  98. l130:
  99.       DO /l160:, K, 1, N
  100.         DO /l150: , I, 1, N
  101.          IFTHEN/m(I)==K
  102.            m1(J)=I
  103.            name(J)=ISTR(l+J)+fix+&NAME(obj(I))
  104.            num1(J)=num(I)
  105.            I=N
  106.            lo=1
  107.
  108.          ELSE
  109.             lo=0
  110.
  111.           ENDIF
  112. l150:
  113.      IFTHEN/lo==0
  114.           J=J
  115.
  116.        ELSE
  117.           J=J+1
  118.
  119.         ENDIF
  120. l160:
  121.      N=u1
  122.      NOTE/x1+w(1)/2,y1-(h/2),'NO.'
  123.               NOTE/x1+w(1)+w(2)/2,y1-(h/2),'NAME'
  124.               NOTE/x1+w(1)+w(2)+w(3)/2,y1-(h/2),'STOCK'
  125.               NOTE/x1+w(1)+w(2)+w(3)+w(4)/2,y1-(h/2),'QTY'
  126.     DO /l170:, I, 1, N
  127.               ln(I)=LINE/PARLEL,ln1,YSMALL,I*h
  128.
  129.                 p=solbox/obj(m1(I))
  130.                 xmin=minf(p(1),p(4))
  131.                 xmax=maxf(p(1),p(4))
  132.                 ymin=minf(p(2),p(5))
  133.                 ymax=maxf(p(2),p(5))
  134.                 zmin=minf(p(3),p(6))
  135.                 zmax=maxf(p(3),p(6))
  136. $print/xmin,xmax,ymin,ymax,zmin,zmax
  137. draw/off
  138.         pla(1)=PLANE/YZPLAN,(xmin-10)
  139.         pla(2)=PLANE/YZPLAN,(xmax+10)
  140.         pla(3)=PLANE/XZPLAN,(ymin-10)
  141.         pla(4)=PLANE/XZPLAN,(ymax+10)
  142.         pla(5)=PLANE/XYPLAN,(zmin-10)
  143.         pla(6)=PLANE/XYPLAN,(zmax+10)
  144.
  145.                 distan=reldst/pla(1),obj(m1(I))        $测量两个物体的距离
  146.
  147.                 mindis(1)=absf(distan(7))        $mindis(7)为距离
  148.
  149.
  150.                 distan=reldst/pla(2),obj(m1(I))
  151.
  152.                 mindis(2)=absf(distan(7))
  153.
  154.
  155.                 distan=reldst/pla(3),obj(m1(I))
  156.
  157.                 mindis(3)=absf(distan(7))
  158.
  159.
  160.                 distan=reldst/pla(4),obj(m1(I))
  161.
  162.                 mindis(4)=absf(distan(7))
  163.
  164.                 distan=reldst/pla(5),obj(m1(I))
  165.
  166.                 mindis(5)=absf(distan(7))
  167.
  168.                 distan=reldst/pla(6),obj(m1(I))
  169.
  170.                 mindis(6)=absf(distan(7))
  171. DELETE/pla
  172. draw/on
  173.
  174.                 xmin=(xmin-10)+mindis(1)
  175.                 xmax=(xmax+10)-mindis(2)
  176.                 ymin=(ymin-10)+mindis(3)
  177.                 ymax=(ymax+10)-mindis(4)
  178.                 zmin=(zmin-10)+mindis(5)
  179.                 zmax=(zmax+10)-mindis(6)
  180.
  181.         x(I)=absf(xmax-xmin)
  182.         y(I)=absf(ymax-ymin)
  183.         z(I)=absf(zmax-zmin)
  184.       &DECPL = 3
  185.        a=FSTRL(x(I))
  186.        b=FSTRL(y(I))
  187.        c=FSTRL(z(I))
  188.        stock(I)=a+'*'+b+'*'+c
  189.               t=ISTR(I)
  190.               NOTE/x1+w(1)/2,y1-(h/2)-I*h,t
  191.
  192.        NOTE/(x1+w(1)+w(2)/2),y1-(h/2)-I*h,name(I)
  193.        NOTE/x1+w(1)+w(2)+w(3)/2,y1-(h/2)-I*h,stock(I)
  194.        NOTE/x1+w(1)+w(2)+w(3)+w(4)/2,y1-(h/2)-I*h,ISTR(num1(I))
  195. l170:
  196.         ln2=LINE/x1,y1,x1,y1-(N+1)*h
  197.         ln3=LINE/PARLEL,ln2,XLARGE,w(1)
  198.         ln4=LINE/PARLEL,ln3,XLARGE,w(2)
  199.         ln5=LINE/PARLEL,ln4,XLARGE,w(3)
  200.         ln6=LINE/PARLEL,ln5,XLARGE,w(4)
  201.         ln7=LINE/PARLEL,ln1,YSMALL,(N+1)*h
  202. hal:
  203.     HALT
复制代码
发表于 2015-6-7 23:52:33 来自手机 | 显示全部楼层
你好啊,呵呵
25
发表于 2014-9-30 13:44:38 | 显示全部楼层
发表于 2015-11-23 21:50:59 | 显示全部楼层
这个是真的很历害的源代码,很实用
论坛贡献
发表于 2016-5-5 18:18:34 | 显示全部楼层
无法编译
发表于 2016-5-6 15:42:51 | 显示全部楼层
这是什么语言写的啊
发表于 2016-5-14 22:52:09 | 显示全部楼层
有谁知道这个怎么用的啊?!
发表于 2018-1-13 13:45:02 | 显示全部楼层
你好,{:smile:}{:smile:}感谢分享
发表于 2018-11-6 16:38:16 | 显示全部楼层
非厉害,怎么用?各位老大
发表于 2018-11-7 17:14:14 | 显示全部楼层
有使用方法吗?
GMT+8, 2026-10-4 18:31
