查看: 3968|回复: 2
[分享] UG8.0螺旋下刀G01改G02方法
发表于 2014-6-26 00:07:02 | 显示全部楼层 |阅读模式
有HELIX.TCL
有HELIX.TCL
添加到程序头
添加到程序头
保存后处理
保存后处理
选择此后处理
选择此后处理
结果不对
结果不对
在厂里编程,螺旋下刀走G01,程序容量很大,拷不到机床里,导致无法加工,哪位大哥版本我一下
发表于 2014-6-26 08:18:37 | 显示全部楼层
代码有些不一样
uplevel #0 {
# This ommand will be executed automatically at the start of program and
# anytime it is loaded as a slave post of a linked post.
# This procedure can be used to enable your post to output helix.
# You can choose from the following options to format the circle
# block template to output the helix parameters.
set mom_sys_helix_pitch_type    "none"
# The default setting for mom_sys_helix_pitch_type is "rise_radian".
# This is the most common.  Other choices are:
#    "rise_radian"              Measures the rise over one radian.
#    "rise_revolution"          Measures the rise over 360 degrees.
#    "none"                     Will suppress the output of pitch.
#    "other"                    Allows you to calculate the pitch
#                               using your own formula.
发表于 2014-8-27 21:30:43 | 显示全部楼层
解决了没有啊
等待
GMT+8, 2026-9-28 10:05
