查看: 13180|回复: 8
UG后处理F值后面的点怎么去掉
爱好者终身VIP
发表于 2014-6-7 18:13:10 | 显示全部楼层 |阅读模式
信息列表创建者:     Administrator
日期:               2014/6/7 星期六 18:02:36
当前工作部件:       D:\_model1.prt
节点名:             jtsm-20140330px
G40 G71 G17 G90
M1
N1
G30 G91 Z0.0
T1 M6
(Tool_Name:MILL-6.0-XD Tool_No:1  Planar Milling)
G54 G0 G90 X-20.591 Y102.154 S1500 M3 T2
G43 Z10. H01 M8
Z3.
G1 X-20.081 Y102.663 Z2.937 F1000.
X-17.203 Y104.919 Z2.617
X-14.073 Y106.811 Z2.297
X-10.739 Y108.312 Z1.977
X-7.247 Y109.4 Z1.657
X-3.65 Y110.059 Z1.337
X0.0 Y110.28 Z1.017
X3.65 Y110.059 Z.697
X7.247 Y109.4 Z.377
X10.739 Y108.312 Z.058
X14.073 Y106.811 Z-.262
X17.203 Y104.919 Z-.582
X20.081 Y102.663 Z-.902
X22.667 Y100.077 Z-1.222
X24.922 Y97.198 Z-1.542
X26.814 Y94.068 Z-1.862
X28.314 Y90.733 Z-2.182
X28.735 Y89.453 Z-2.3
X52.483 Y17.266
G2 Y-17.266 I-52.483 J-17.266
G1 X28.735 Y-89.453
G2 X-28.735 I-28.735 J9.453
G1 X-52.483 Y-17.266
G2 Y17.266 I52.483 J17.266
G1 X-28.735 Y89.453
G2 X28.735 I28.735 J-9.453
G1 Z.7
G0 Z10.
X-19.749 Y102.924
Z.7
G1 X-17.203 Y104.919 Z.417
X-14.073 Y106.811 Z.097
X-10.739 Y108.312 Z-.223
X-7.247 Y109.4 Z-.543
X-3.65 Y110.059 Z-.863
X0.0 Y110.28 Z-1.183
X3.65 Y110.059 Z-1.503
X7.247 Y109.4 Z-1.823
X10.739 Y108.312 Z-2.142
X14.073 Y106.811 Z-2.462
X17.203 Y104.919 Z-2.782
X20.081 Y102.663 Z-3.102
X22.667 Y100.077 Z-3.422
X24.922 Y97.198 Z-3.742
X26.814 Y94.068 Z-4.062
X28.314 Y90.733 Z-4.382
X28.735 Y89.453 Z-4.5
X52.483 Y17.266
G1 X28.735 Y-89.453
G1 X-28.735 Y89.453
G1 Z-1.5
G0 Z10.
M1
N2
G30 G91 Z0.0
T2 M6
(Tool_Name:MILL-6.0-XD Tool_No:2  Planar Milling)
G54 G0 G90 X29.435 Y89.656 S0 M3 T1
Z10. H02
Z-1.6
G1 Z-4.6 F250.
G41 X26.388 Y86.729 D2
X26.645 Y84.945
G3 X32.821 Y87.657 I2.712 J2.213
G1 X32.428 Y90.385
G3 X32.345 Y90.641 I-32.428 J-10.385
X-32.345 I-32.345 J-10.641
G1 X-56.093 Y18.453
G3 Y-18.453 I56.093 J-18.453
G1 X-32.345 Y-90.641
G3 X32.345 I32.345 J10.641
G1 X56.093 Y-18.453
G3 Y18.453 I-56.093 J18.453
G1 X32.345 Y90.641
G3 X25.607 Y90.322 I-3.325 J-1.094
G1 X26.17 Y88.609
G40
X30.202 Y87.344
X28.807 Y86.885
G41 X31.3 Y90.297
X30.736 Y92.009
G3 X25.125 Y88.266 I-2.286 J-2.65
G1 X48.873 Y16.078
G2 Y-16.078 I-48.873 J-16.078
G1 X25.125 Y-88.266
G2 X-25.125 I-25.125 J8.266
G1 X-48.873 Y-16.078
G2 Y16.078 I48.873 J16.078
G1 X-25.125 Y88.266
G2 X25.125 I25.125 J-8.266
G3 X31.863 Y88.584 I3.325 J1.094
G1 X31.3 Y90.297
G40
X27.268 Y91.562
Z-1.6
G0 Z10.
M5 M9
M30
(The total machine time: 5.88 min)
我发现有3个有问题的地方
1.N2后的 程序没有G43,,,我需要它再次出现
2.N2后的D当出现G40后不 再出现 ,,,我需要它再次出现
3.F后有小数点,我不想要 小数点
2258
站长优秀版主论坛技术员论坛元老论坛贡献推广达人
发表于 2014-6-7 18:33:37 | 显示全部楼层
F后面的小数点,可以将*.def文件中的 FORMAT Feed_MMPM "&__5.0_"5  改成 FORMAT  Feed_MMPM  "&__5_00" 看看。
爱好者终身VIP
 楼主| 发表于 2014-6-7 19:09:35 | 显示全部楼层
老叶 发表于 2014-6-7 18:33
F后面的小数点,可以将*.def文件中的 FORMAT Feed_MMPM "&__5.0_"5  改成 FORMAT  Feed_MMPM  "&__5_00" 看 ...
改了再用UG报警
2258
发表于 2014-6-7 21:37:58 | 显示全部楼层
pancheng86 发表于 2014-6-7 19:09
改了再用UG报警
打开系统菜单的UG菜单组里启动NX【后处理构造器】,然后打开你的后处理PUI文件,修改之,按如下设置,并保存: UG后处理F值后面的点去掉.jpg
爱好者终身VIP
 楼主| 发表于 2014-6-8 12:15:54 | 显示全部楼层
老叶 发表于 2014-6-7 21:37
打开开户菜单UG菜单组里启动NX后处理构造器,然后打开你的后处理PUI文件,修改之,按如下设置,并保存:
谢谢老叶F后去掉小数点的 问题已搞定,还有两个问题也能帮我 决绝吗 ?
发表于 2017-2-24 14:00:20 | 显示全部楼层
我也需要这样的解决办法
发表于 2017-4-11 00:26:03 | 显示全部楼层
为什么我的不行呢?
发表于 2018-12-18 14:28:49 | 显示全部楼层
小数点UG8.5版本好像去不掉至少保留一位,不知道各位是否一样
发表于 2019-8-22 14:17:52 | 显示全部楼层
帅哥,请教下怎么把UG后处理攻丝的F修改为 I 值?
兄弟机M3螺纹攻丝格式:G98 G77 Z-10. R2. Q3. I0.5 S2000
如题:G77我已修改,就是把F替换为I搞不定,真心求大神指点,不胜感激!
GMT+8, 2025-3-10 08:44
