查看: 1645|回复: 2
[求助] 谁能给个西门子840D螺旋输出TURN 的后处理吗
发表于 2022-6-23 10:29:38 | 显示全部楼层 |阅读模式
谁能给个西门子840D螺旋输出TURN 的后处理吗?万分感谢....
发表于 2022-6-24 22:46:53 来自手机 | 显示全部楼层
分享五轴联动和去掉多余角度后处理(3)http://www.ugsnx.com/thread-299948-1-1.html
29
发表于 2022-6-26 15:59:51 | 显示全部楼层
global mom_pos_arc_plane
   global mom_sys_cir_vector
   global mom_sys_helix_pitch_type
   global mom_helix_pitch
   global mom_prev_pos mom_pos_arc_center
   global PI
   switch $mom_pos_arc_plane {
      XY { MOM_suppress once K ; set cir_index 2 }
      YZ { MOM_suppress once I ; set cir_index 0 }
      ZX { MOM_suppress once J ; set cir_index 1 }
   switch $mom_sys_helix_pitch_type {
      none { }
      rise_revolution { set pitch $mom_helix_pitch }
      rise_radian { set pitch [expr $mom_helix_pitch / ($PI * 2.0)]}
      other {
#    Place your custom helix pitch code here
      default { set mom_sys_helix_pitch_type "none" }
   MOM_force once X Y Z
   if { [string compare "none" $mom_sys_helix_pitch_type] } {
      MOM_force once I J K
#<08-01-06 gsl>
      switch $mom_sys_cir_vector {
         "Vector - Arc Center to Start" {
            set mom_prev_pos($cir_index) $pitch
            set mom_pos_arc_center($cir_index) 0.0
         "Vector - Arc Start to Center" -
         "Unsigned Vector - Arc Start to Center" {
            set mom_prev_pos($cir_index) 0.0
            set mom_pos_arc_center($cir_index) $pitch
         "Vector - Absolute Arc Center" {
# You may need to edit this line if you output more than one block
# or if you have changed the name of your circular_move block template
   global mom_pos
   global mom_prev_pos
   global mom_helix_turn_number
   set pitch [expr abs($mom_helix_pitch)]
   set feed_distance [expr abs($mom_pos($cir_index) - $mom_prev_pos($cir_index))]
   if {[EQ_is_zero $pitch]} {
      set mom_helix_turn_number 0
   } else {
      set mom_helix_turn_number [expr floor($feed_distance/$pitch)]
      if { [EQ_is_equal $feed_distance [expr $mom_helix_turn_number * $pitch]] } {
         set mom_helix_turn_number [expr $mom_helix_turn_number - 1]
      XY { MOM_suppress once K ; MOM_force Once I J }
      YZ { MOM_suppress once I ; MOM_force Once J K }
      ZX { MOM_suppress once J ; MOM_force Once I K }
GMT+8, 2025-3-6 17:27
