查看: 4320|回复: 9
[求助] 请问下MASTERCAM五轴后处理C轴怎么控制在360度之类
发表于 2022-5-13 18:58:02 | 显示全部楼层 |阅读模式
发表于 2022-7-2 23:47:29 | 显示全部楼层
应该是c超过360°行程了,所以有抬刀。下面我用debug反推的,不一定对
p_nobrk_emul    #'nobrk' emulation option
      if abs(zinc)<brk_tol | not(abs(xinc)>brk_tol | abs(yinc)>brk_tol)
        | not(mtype = zero | mtype = three),
        if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
        #prapidout         ---------我是把这里注释掉了,不过下刀高度也没了
      else,
        nobrk_xa = vequ(xabs)
        nobrk_xi = vequ(xinc)
        nobrk_pa = vequ(p_abs)
        nobrk_pi = vequ(p_inc)
        #Z up, move Z, XY, PRI, SEC
N100 T1 M6
N110 M8 T1
N120 G0 G54 G90 X0. Y204.45 C87.205 A-90. S2000 M3
N130 G43 H1 Z-110.048
                                                  #下刀高度无了
N140 G1 Z-135.048 F600.
N150 C90. F240.
N160 C92.795
N170 C95.586
N180 C98.37
N190 C101.145
N200 C103.907
N210 C106.652
N220 C109.378
N230 C112.082
N240 C114.762
N250 C117.414
N260 C120.036
N270 C122.627
N280 X.001 C125.183
N290 C127.704
N300 C130.187
N310 X.002 C132.632
N320 C135.036
N330 C137.399
N340 X.003 C139.721
N350 C141.999
N360 C144.234
N370 X.004 C146.425
N380 C148.572
N390 X.005 C150.675
N400 C152.733
N410 C154.748
N420 X.006 C156.718
N430 C158.645
N440 C160.529
N450 C162.37
N460 X.007 C164.169
N470 C165.926
N480 C167.642
N490 C169.317
N500 X.006 C170.956
N510 X-.001 C172.571
N520 X-.006 C174.144
N530 X-.004 C175.662
N540 X-.003 C177.145
N550 X-.002 C178.591
N560 X0. C180.
N570 X.002 C181.409
N580 X.003 C182.855
N590 X.004 C184.338
N600 X.006 C185.856
N610 X.001 C187.429
N620 X-.006 C189.044
N630 X-.007 C190.683
N640 C192.358
N650 C194.074
N660 C195.831
N670 X-.006 C197.63
N680 C199.471
N690 C201.355
N700 C203.282
N710 X-.005 C205.252
N720 C207.267
N730 C209.325
N740 X-.004 C211.428
N750 C213.575
N760 X-.003 C215.766
N770 C218.001
N780 C220.279
N790 X-.002 C222.601
N800 C224.964
N810 C227.368
N820 X-.001 C229.813
N830 C232.296
N840 C234.817
N850 X0. C237.373
N860 C239.964
N870 C242.586
N880 C245.238
N890 C247.918
N900 C250.622
N910 C253.348
N920 C256.093
N930 C258.855
N940 C261.63
N950 C264.414
N960 C267.205
N970 C270.
N980 C272.795
N990 C275.586
N1000 C278.37
N1010 C281.145
N1020 C283.907
N1030 C286.652
N1040 C289.378
N1050 C292.082
N1060 C294.762
N1070 C297.414
N1080 C300.036
N1090 C302.627
N1100 X.001 C305.183
N1110 C307.704
N1120 C310.187
N1130 X.002 C312.632
N1140 C315.036
N1150 C317.399
N1160 X.003 C319.721
N1170 C321.999
N1180 C324.234
N1190 X.004 C326.425
N1200 C328.572
N1210 X.005 C330.675
N1220 C332.733
N1230 C334.748
N1240 X.006 C336.718
N1250 C338.645
N1260 C340.529
N1270 C342.37
N1280 X.007 C344.169
N1290 C345.926
N1300 C347.642
N1310 C349.317
N1320 X.006 C350.956
N1330 X-.001 C352.571
N1340 X-.006 C354.144
N1350 X-.005 C355.663
N1360 C357.148
N1370 X-.002 C358.591
N1380 X0. C360.                    #360°到0°
N1390 C0. F600.
N1400 X.002 C1.409 F240.
N1410 X.005 C2.852
N1420 C4.337
N1430 X.006 C5.856
N1440 X.001 C7.429
N1450 X-.006 C9.044
N1460 X-.007 C10.683
N1470 C12.358
N1480 C14.074
N1490 C15.831
N1500 X-.006 C17.63
N1510 C19.471
N1520 C21.355
N1530 C23.282
N1540 X-.005 C25.252
发表于 2022-6-10 16:38:10 | 显示全部楼层
#Rotary axis travel limits, always in terms of normal angle output
#Set the absolute angles for axis travel on primary
#主要轴(能转360的轴)
pri_limlo$   : -360
pri_limhi$   : 360
#Set intermediate angle, in limits, for post to reposition machine
pri_intlo$   : -360
pri_inthi$   : 360
#Set the absolute angles for axis travel on secondary
#次要轴
sec_limlo$   : -109
sec_limhi$   : 0
sec_intlo$   : -109
sec_inthi$   : 0
发表于 2022-6-9 18:52:07 | 显示全部楼层
你好 五轴 后处理 能分享么?
 楼主| 发表于 2022-7-2 10:24:27 | 显示全部楼层
564650752 发表于 2022-6-9 18:52
你好 五轴 后处理 能分享么?
软件自带的
 楼主| 发表于 2022-7-2 10:25:42 | 显示全部楼层
#Set the absolute angles for axi ...
这样设置程式模拟就不对  会抬刀   搞不懂
 楼主| 发表于 2022-7-2 10:37:10 | 显示全部楼层
wdej1314 发表于 2022-7-2 10:25
这样设置程式模拟就不对  会抬刀   搞不懂
这样设置程式模拟就不对  会抬刀
31
发表于 2022-7-2 21:01:51 | 显示全部楼层
把模拟刀轴关掉
 楼主| 发表于 2022-7-5 23:32:50 | 显示全部楼层
p_nobrk_emul    #'nobrk' emulat ...
兄弟强啊   搞定了
发表于 2022-7-21 19:44:14 | 显示全部楼层
非常感谢,我也有类似的问题,用您的方法解决了
GMT+8, 2025-3-14 10:23
