查看: 1668|回复: 0
[原创] NX开发_C++纯代码实现选择文件按点插入
发表于 2022-5-5 09:48:25 | 显示全部楼层 |阅读模式
        // TODO: add your code here
        char *cue = "请选择插入体的点位置.";
        double point[3] = {0.0, 0.0, 0.0};                        /*获得点坐标*/
        char promptString[133] = "选择即将导入的部件";
        char titleString[133] = "选择即将导入的部件";
        char filterString[133] = ".prt";/*输入文件类型*/
        char defaultName[256+1] = "";/*输入and 输出 默认文件名*/
        char filename[256+1] = "";/*输出完整的路径*/
        int response = 0;
        int err = UF_UI_create_filebox(promptString, titleString, filterString, defaultName, filename, &response);
        if( (err==0) && (response==2) )
                //uc1601(filename, 1);
                UF_UI_POINT_base_method_t base_method;
                base_method = UF_UI_POINT_INFERRED;                /*默认选择-自动判断点*/
                tag_t pt = NULL_TAG;
                tag_t view_tag = NULL_TAG;
                //int response = 0;
                UF_UI_point_construct(cue, &base_method, &view_tag, point, &response);
                if (response == 2)
                        /*导入prt 如导入图框(可以改变,导入点和比例)*/
                        UF_import_part_modes_t  modes;
                        double dest_csys[6] = {1.0, 0.0, 0.0, 0.0, 1.0, 0.0};
                        double scale = 1.0;
                        tag_t group=NULL_TAG;
                        modes.layer_mode = 0;
                        modes.group_mode = 1;
                        modes.view_mode = 0;
                        modes.cam_mode = FALSE;
                        UF_PART_import(filename, &modes, dest_csys, point, scale, &group);
                        uc1601("部件插成功", 1);
GMT+8, 2026-11-19 19:02
