查看: 4948|回复: 10
[分享] 孔铣宏程序制作方法
发表于 2022-3-30 08:39:25 | 显示全部楼层 |阅读模式
资料来源于闪光蜗牛
现在给大家分享一下,孔铣命令宏后处理制作方法,只说方法教程,请见谅!
1.新建一个后处理
2.在N/C数据定义模块 →文字  →找到“Z”
3.右键→创建“Z_1”
4.新建选择“文本”格式
5.在N/C数据定义模块 →块  →找到“circular_move”
6.右键→创建“circular_move_1”右键→创建→“circular_move_helix
7.删除“circular_move_1”中的“Z”并添加“Z-1”表达式“#26”
8.删除“circular_move_helix”中的“Z”并添加“Z-1”表达式“#18”
9.在   程序和刀轨 模块→定制命令→导入→在文件夹中选择“pb_cmd_helix.tcl
10.在   程序和刀轨 模块→程序→程序起始序列→添加块右侧选择“PB-CMD-init_helix”→添加块→“%”后即可
11.在   程序和刀轨 模块→定制命令→选择“pb_cmd_helix.tcl”用下面代码替换原代码
12.保存后处理文件,好了,来试一下你的宏程序后处理吧{:biggrin:}
uplevel #0 {
# This ommand will be executed automatically at the start of program and
# anytime it is loaded as a slave post of a linked post.
# This procedure can be used to enable your post to output helix.
# You can choose from the following options to format the circle
# block template to output the helix parameters.
   set mom_sys_helix_pitch_type    "rise_revolution"
# The default setting for mom_sys_helix_pitch_type is "rise_radian".
# This is the most common.  Other choices are:
#    "rise_radian"              Measures the rise over one radian.
#    "rise_revolution"          Measures the rise over 360 degrees.
#    "none"                     Will suppress the output of pitch.
#    "other"                    Allows you to calculate the pitch
#                               using your own formula.
# This custom command uses the block template circular_move to output
# the helix block.  If your post uses a block template with a different
# name, you must edit the line that outputs the helix block.
#  The following variable deines the output mode for helical records.
#  FULL_CIRCLE  -- This mode will output a helix record for each 360
#                  degrees of the helix.
#  QUADRANT  --    This mode will output a helix record for each 90
#  LINEAR  --      This mode will output the entire helix as linear gotos.
#  END_POINT --    This mode will assume the control can define an entire
#                  helix in a single block.
   set mom_kin_helical_arc_output_mode END_POINT
   MOM_reload_kinematics
proc MOM_helix_move { } {
   global mom_pos_arc_plane
   global mom_sys_cir_vector
   global mom_sys_helix_pitch_type
   global mom_helix_pitch
   global mom_prev_pos mom_pos_arc_center
   global PI
   switch $mom_pos_arc_plane {
      XY { MOM_suppress once K ; set cir_index 2 }
      YZ { MOM_suppress once I ; set cir_index 0 }
      ZX { MOM_suppress once J ; set cir_index 1 }
   switch $mom_sys_helix_pitch_type {
      none { }
      rise_revolution { set pitch $mom_helix_pitch }
      rise_radian { set pitch [expr $mom_helix_pitch / ($PI * 2.0)]}
      other {
#    Place your custom helix pitch code here
      default { set mom_sys_helix_pitch_type "none" }
   MOM_force once X Y Z
   if { [string compare "none" $mom_sys_helix_pitch_type] } {
      MOM_force once I J K
     #<08-01-06 gsl>
      switch $mom_sys_cir_vector {
         "Vector - Arc Center to Start" {
            set mom_prev_pos($cir_index) $pitch
            set mom_pos_arc_center($cir_index) 0.0
         "Vector - Arc Start to Center" -
         "Unsigned Vector - Arc Start to Center" {
            set mom_prev_pos($cir_index) 0.0
            set mom_pos_arc_center($cir_index) $pitch
         "Vector - Absolute Arc Center" {
# You may need to edit this line if you output more than one block
# or if you have changed the name of your circular_move block template
#   MOM_do_template circular_move
global mom_pos mom_last_pos
set dep [format "%0.3f" [expr $mom_pos($cir_index)-$mom_last_pos($cir_index)]]
set pit [format "%0.3f" $pitch]
set val [string trimright [expr $dep/$pit] .0]
set val_int [expr int($val)]
set z_rem [expr abs(int($dep/$pit)-$dep/$pit)]
if {$mom_pos($cir_index)<$mom_last_pos($cir_index)} {
    set sym GE
} else {
    set sym LE
if {$val<1} {
} else {
    MOM_output_literal "(R)#18=[format "%0.3f" [expr $mom_last_pos($cir_index)+$pitch]]
(Z)#26=[format "%0.3f" $mom_pos($cir_index)]
WHILE \[#18 $sym #26\] DO1"
    set last_cycle(0) $mom_pos(0)
    set last_cycle(1) $mom_pos(1)
    set mom_pos(0) $mom_last_pos(0)
    set mom_pos(1) $mom_last_pos(1)
    MOM_do_template circular_move_helix
    MOM_output_literal "#18=#18+\[[format "%0.3f" $pitch]\]
END1"
    if {[string compare $val $val_int]} {
    set mom_pos(0) $last_cycle(0)
    set mom_pos(1) $last_cycle(1)
        MOM_force once X Y Z  I J Z_1
        MOM_do_template circular_move_1
} ;# uplevel
新建后处理文件
新建后处理文件
第一步
第一步
第二步
第二步
第六步
第六步
第四步
第四步
第七步
第七步
第八步
第八步
发表于 2022-4-6 12:04:18 | 显示全部楼层
感谢大佬,解了我多年的困惑,如果面铣,深度铣也能用宏就好了
发表于 2022-3-30 10:04:35 | 显示全部楼层
非常详细,多谢楼主分享!
发表于 2022-3-30 10:12:56 | 显示全部楼层
发表于 2022-3-30 11:18:25 | 显示全部楼层
多谢楼主分享
发表于 2022-3-30 14:07:53 | 显示全部楼层
感谢分享 已经成功了
发表于 2022-4-6 12:08:27 | 显示全部楼层
发表于 2022-4-6 15:04:52 | 显示全部楼层
谢谢大神分享
发表于 2022-5-25 18:57:06 | 显示全部楼层
厉害,谢谢
发表于 2022-5-25 19:49:34 | 显示全部楼层
{:} 谢谢大师分享.......
GMT+8, 2025-3-6 18:11
