查看: 7156|回复: 17
[2007系列] NX2019发布了 马上就要超越今年的年份2022了
发表于 2022-3-24 18:12:38 | 显示全部楼层 |阅读模式
貌似论坛不让发链接了?俄罗斯都合法化那个啥网站了
修复的内容如下
ReleasePR NumberDescriptionApplicationFunctionSub_Function
2019
8484049
P&ID - TC Classification Key LOV - value unassigned - no symbol tag  updateP&ID_DESIGNERAUTHORINGSYMBOL
2019
8487549
Basic Design - Expansion Drawing view line style does not updateSHIP_DESIGNDRAFTINGEXPANSION_DRWG
2019
8487554
Shell Expansion Drawing, deleted stiffener subsystem is not removed from  viewSHIP_DESIGNDRAFTINGEXPANSION_DRWG
2019
8488536
import of .xdb - wrong results for SOL106 GPFsCAEADV_SIMULATIONPOST_RESULT
2019
10072957
Subtracting holes using Extrude in room wall cause floor in room to be  lostSHIP_DESIGNGENERAL_ARRANGEROOM_ATTR
2019
10085756
NX electrical routing: "invalid part tag" error when updating  formboardROUTING_ELECFORMBOARD_V2UPDATE_FMBD
2019
10174003
2019
10174113
2019
10176817
Sheet metal part NX 11 drawing cannot be updated after modificationASSEMBLIESASSEMBLY_MODELEXPLODED_VIEWS
2019
10177384
Error occurred when updating hidden line display.ASSEMBLIESASSEMBLY_MODELEXPLODED_VIEWS
2019
10178928
Expansion drawing view line type change is not reflected in graphicsSHIP_DESIGNDRAFTINGEXPANSION_DRWG
2019
10184086
Unexpected Toolpath when Using Extend at EdgesCAMSURFACE_CONTOURPERFORM_FASC
2019
10186556
RSD CableWay Export plugin throws c0000005 and puts NX into unusable  stateRSD_MECHANICALCABLEWAYSCABLEWAY_EXPORT
2019
10212131
Structure Weld Plate Preparation not working with Weld: Modeler error:  not withiSHIP_DESIGNMANUFACTURINGPLATE_PREP
2019
10212995
Saving CAM Setup under NX1973 creates additional objects in TCCAMTC_MFGOTHER
2019
10214674
Plate Preparatoin - Weld Preparation not working on MFG PartsSHIP_DESIGNMANUFACTURINGPLATE_PREP
2019
10217330
NX1953 (series) is very slow compared to NX12KDAMOLDWIZARDSTANDARD_PARTS
2019
10220710
Performance issue with NX-P&ID Create Specification and ConnectionP&ID_DESIGNERLIBRARYPIPE_STOCK
2019
10221621
NX-IFC Export Failed: Translate operation failed during part export.TRANSLATORIFCEXPORT
2019
10223699
Opening a specification part in NX1988.2201 lead to unwanted line style  change fSYSENGDISPLAYLINE_FONTS
2019
10223898
NX Datum surface locator size is incorrect in TcVis when loading from  TeamcenterKDAWELD_ASSISTANTFEATURE_PUBLISH
2019
10227533
NX 1876 assembly doesn't open in NX1984ASSEMBLIESASSEMBLY_MODELCOMP_PATTERN
2019
10231474
+++ Return code 46147 found in PDI interface function  PDI_add_cam_part_resourceCAMTC_MFGOTHER
2019
10233213
Ped Pro CRP to WAD1000 CurveKDAGENERAL_PACKAGEPEDPRO
2019
10233226
Ped Pro China vs. Europe zone point front of BLEKDAGENERAL_PACKAGEPEDPRO
2019
10233630
Hole_Making Toolpath Generate Performance / Gouge Check Performance IssueCAMDRILLINGOTHER
2019
10233726
Updating ship features time is taking too long TimeSHIP_DESIGNSTEEL_FEATURESSTIFFENER
2019
10233781
Saving Time for modified detail parts is taking too longDESIGNWAVENAVIGATORS
2019
10243143
NX will not create supports for a specific part modelADD_FIXED_PLANESUPPORTSOTHER
2019
10243391
export_ugdwgimages utility, the bom file output contains a % character.NXMANAGERTRANSLATORSINFRASTRUCTURE
2019
10244887
flex database file size changeCAEMOTIONFLEX_BODY_SC
2019
10245186
Enhancements to cutting plane symbols in PMI section viewPMISECTION_VIEWCUT_PLN_SYM
2019
10246571
Incorrect behavior of NXOpen.RigidBody when setting a position and  orientationMECHATRONICSBASIC_PHYSICSRIGID_BODY
2019
10248619
Convert Sketch Dimension with Expression to and from Reference changes  valueDESIGNSKETCHEREXPRESSIONS
2019
10251348
P&ID - Reference Geometry - Text supporting colors and transparencyKDADIAGRM_FRAMEWRKREF_GEOM
2019
10253392
check mate for broken links is taking so longDESIGNWAVENAVIGATORS
2019
10253821
NX Design Simulation : Probl鑝e sur adaptivit?CAEDES_SIMULATIONADAPTIVITY
发表于 2022-3-25 09:05:59 | 显示全部楼层
cuixuanfeng_hbn 发表于 2022-3-24 18:49
人家那个网站一直能打开,只不过最近被国内过多的关注了而已
哪个网站{:}
67
发表于 2022-3-30 12:49:16 | 显示全部楼层
草图已经重做过了,下一步该重做建模了吧。
发表于 2022-3-24 18:49:26 | 显示全部楼层
发表于 2022-3-24 21:24:19 | 显示全部楼层
中国的狗奴才还在给专利费
发表于 2022-3-25 00:58:13 | 显示全部楼层
楼主好人一生平安!
815692846@qq.com
发表于 2022-3-25 08:30:58 | 显示全部楼层
最近被国内过多的关注了而已
发表于 2022-3-26 14:13:00 | 显示全部楼层
我2007还没装上,2019都出来了,。。。。
发表于 2022-3-29 08:24:19 | 显示全部楼层
2019右键重命名修复了
发表于 2022-3-29 15:12:02 | 显示全部楼层
版本更新很快,有没有实际进展,才重要。有的功能特难用,有的功能没有。整天改版本,改图标。{:huffy:}{:huffy:}{:huffy:}
GMT+8, 2026-10-24 13:25
