查看: 4245|回复: 12
[已回复] NX2007结构系统型材库替换汉化失败 大佬们看看啥原因
Rank: 2
发表于 2022-1-3 16:40:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本人小白最近在学习NX结构设计模块,运用过程中型材标准中无国标无法进行工作,在论坛上查找相关资料进行学习,看到大神阿尔的无奈*分享的结构件库,喜出望外非常兴奋,在这里非常感谢阿尔的无奈*的无私奉献与分享,替换NXSTRUCTUREDESIGN\data\library原文件后进行尝试,进行型材选择的时候出现以下错误
选择构件出现错误
推荐
发表于 2022-1-3 22:47:43 | 只看该作者
2007跟以前的版本库文件有改动
感觉还是新建个国标库的好,不用改动原来的以防出错。
你按以下对照下应该能解决,
设置这两个文件后,首选项中就会出现GB选项
再改下对应文件
就可以显示如下图
下面附上西门子帮助文件中的介绍
                       You can build stock and structural feature libraries based on international industry                        standards.
                      NX provides the following categories of industry-standard parts and stock for structural                        members and features:
  •                             EN-DIN
  •                             AISC
  •                             JIS
                      You can use the sample parts and stock in these libraries as supplied, or customize                        them to build your own libraries.
                      After you designate a standard for your structure design, NX displays only the parts                        and stock for that standard's library when you create members and structural features.
                   Library definition file                                         The library definition file delineates the standards categories available in 结构设计:
                      <StructureDesignLibrary version="1">
<Libraries>
  <Library name = "EN-DIN"/>
  <Library name = "AISC"/>
  <Library name = "JIS"/>
</Libraries>
</StructureDesignLibrary>
                      These entries appear in the 结构设计 customer defaults and preferences.
                      By default, the library definition file is located at:
                      %NX_STRUCTUREDESIGN_DATA_DIR%\library\LibraryDef.xml
                      You can accept this default or provide your own file and location.
                      To add a standard to the library, insert a new entry for it in the library definition                        file:
<Libraries>
  <Library name = "[NEW ENTRY]"/>
</Libraries>
                     Library spreadsheets for standards                                         Each standard in the library definition file must have a corresponding data page set                        up for it in the library spreadsheet. Each page in the library spreadsheet registers                        the stock and structural features available in the standard, and points to a specific                        standards folder in the library.
                      By default, the library spreadsheet is located at:
                      %NX_STRUCTUREDESIGN_DATA_DIR%\library\SectionReg.xlsx
回复 支持 2 反对 0
推荐
发表于 2022-1-4 08:51:17 | 只看该作者
c100861 发表于 2022-1-3 22:47
2007跟以前的版本库文件有改动
将文件替换这个页面的两个文件(可以分别打开,搜下ARDWN就可以找到我修改的地方了,如不喜欢这个名字可以改)
我实在不会取名了(名字随便起一个,不知道支不支持中文)
再新那建个文件(AEDWN),
将原来阿尔发出的文件下到的文件放个这个文件夹中如上图示:
再重启NX
修改库,改LibraryDef.xml后这里会出现 AEDWN(附件中的文件已经改过了),选中后就可以用了
也可在用户默认设置中选这个库。
再次感谢 阿尔的无奈
附件只能1M,所以阿尔的无奈制作的库文件我就没有上传,如需要的话,论坛里面搜就行
不过个人感觉目前UG作钢构跟tekla差太远了,这个模块应付一个的铝型材框架或小的钢架子还是不错的,
感觉后面那比较大的型材应该都用不到,还是用那个改那个好点,要不工作量太大了。
替换.rar
72.61 KB, 下载次数: 140, 下载积分: G币 -1
参与人数 1G币 +20 收起 理由
3D世界网-零 + 20 分享加分!
回复 支持 1 反对 0
Rank: 2
 楼主| 发表于 2022-1-4 09:17:42 | 只看该作者
2007跟以前的版本库文件有改动
太感谢了 我试试 本人新手第一次发帖 觉的回帖采纳给积分 积分在上楼不知怎么给您太抱歉了
发表于 2022-1-4 09:28:01 来自手机 | 只看该作者
都是新人,相互学习
你可以设置好以后
打包上传附件
方便其它人就好
Rank: 2
 楼主| 发表于 2022-1-4 16:14:54 | 只看该作者
c100861 发表于 2022-1-4 09:28
都是新人,相互学习
你可以设置好以后
好的 通过您的指导调好了 想问一下名称里面可以带入长度属性吗 保存的时候合并相同零件和没合并前的保存 零件太多了 感觉是虚拟件最好  明细表出的也太多了只需要合并的那些 有什么好的办法
发表于 2022-1-4 21:33:29 来自手机 | 只看该作者
都是新人,相互学习
你可以设置好以后
里面有个割切长度的属性,
在明细表,通过设置关键列,系统会自动合并。
Rank: 4
发表于 2022-3-25 21:04:42 | 只看该作者
已经按照楼主的办法设置成功,谢谢楼主
发表于 2022-6-6 01:41:12 | 只看该作者
你可以设置好以后
打包上传附件
方便其它人就好
Powered by UG爱好者 X3.2  © 2001-2014 Comsenz Inc. GMT+8, 2024-11-23 20:55
