查看: 2372|回复: 9
[求助] 求UG后处理大神帮我解决这个问题,搞了好久还是不会
发表于 2021-12-11 15:38:25 | 显示全部楼层 |阅读模式
proc PB_CMD_Zmax_Zmin_start_of_program { } {
# This custom command may be used to check for the maximum
# travel for each axis.  A warning will be output for each
# GOTO that exceeds the limits.  It does not check for
# parallel axis such as Z and W.  It does not account for
# any modifications done by the user to mom_pos before the
# coordinates are output.
# Import and call this command in PB_CMD_before_motion.
   global mom_sys_max_travel
   global mom_sys_min_travel
   global mom_kin_x_axis_limit
   global mom_kin_y_axis_limit
   global mom_kin_z_axis_limit
   global mom_pos
   global mom_cycle_rapid_to_pos
   global mom_cycle_feed_to_pos
   global mom_cycle_retract_to_pos
   global mom_motion_type
   global mom_warning_info
   if {![info exists mom_sys_max_travel]} {
      for {set i 0} {$i < 3} {incr i} {
         set mom_sys_max_travel($i) $mom_pos($i)
         set mom_sys_min_travel($i) $mom_pos($i)
   } elseif { ![string compare "CYCLE" $mom_motion_type] } {
         if {$mom_cycle_rapid_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_rapid_to_pos($i)
         if {$mom_cycle_rapid_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_rapid_to_pos($i)
         if {$mom_cycle_feed_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_feed_to_pos($i)
         if {$mom_cycle_feed_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_feed_to_pos($i)
         if {$mom_cycle_retract_to_pos($i) < $mom_sys_min_travel($i)} {
            set mom_sys_min_travel($i) $mom_cycle_retract_to_pos($i)
         if {$mom_cycle_retract_to_pos($i) > $mom_sys_max_travel($i)} {
            set mom_sys_max_travel($i) $mom_cycle_retract_to_pos($i)
   } else {
         if {$mom_pos($i) < $mom_sys_min_travel($i)} {
         if {$mom_pos($i) > $mom_sys_max_travel($i)} {
   if {[expr $mom_sys_max_travel(0) - $mom_sys_min_travel(0)] > $mom_kin_x_axis_limit} {
      set mom_warning_info "Maximum X axis travel exceeded, did not alter output"
      MOM_catch_warning
   if {[expr $mom_sys_max_travel(1) - $mom_sys_min_travel(1)] > $mom_kin_y_axis_limit} {
      set mom_warning_info "Maximum Y axis travel exceeded, did not alter output"
      MOM_catch_warning
   if {[expr $mom_sys_max_travel(2) - $mom_sys_min_travel(2)] > $mom_kin_z_axis_limit} {
      set mom_warning_info "Maximum Z axis travel exceeded, did not alter output"
      MOM_catch_warning
proc PB_CMD_Zmax_Zmin_End_of_program { } {
MOM_output_literal "( Max Z = [format %.3f $mom_sys_max_travel(2)]   MIN Z = [format %.3f $mom_sys_min_travel(2)] )"
在网上看到加入了这两行代码 但是出来的后处理显示都是0 求高手帮忙解决一下  小弟在此感激不尽
点评
搞定了到时候买包烟答谢大神  发表于 2021-12-11 15:41
发表于 2021-12-11 15:45:12 | 显示全部楼层
此帖仅作者可见
发表于 2021-12-12 08:36:12 | 显示全部楼层
此帖仅作者可见
发表于 2021-12-12 11:49:50 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2021-12-13 09:18:49 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2021-12-13 09:22:08 | 显示全部楼层
此帖仅作者可见
发表于 2021-12-13 15:19:09 | 显示全部楼层
此帖仅作者可见
 楼主| 发表于 2021-12-13 16:56:58 | 显示全部楼层
此帖仅作者可见
发表于 2022-1-5 20:10:53 | 显示全部楼层
此帖仅作者可见
发表于 2022-4-20 12:11:44 | 显示全部楼层
此帖仅作者可见
GMT+8, 2026-9-22 22:34
