楼主: 唯爱许
[求助] 三菱m70系统 网线传输对应 电脑win10 系统 无法解析服务器的名称或地址
 楼主| 发表于 2021-5-13 09:05:53 | 显示全部楼层
1595763701 发表于 2021-5-13 08:49
c:\windows\system32\drivers\etc里面有个hosts文件,打开看看NCExplorer前面有没有#,有就删除
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample LMHOSTS file used by the Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to computernames
# (NetBIOS) names.  Each entry should be kept on an individual line.
# The IP address should be placed in the first column followed by the
# corresponding computername. The address and the computername
# should be separated by at least one space or tab. The "#" character
# is generally used to denote the start of a comment (see the exceptions
# below).
# This file is compatible with Microsoft LAN Manager 2.x TCP/IP lmhosts
# files and offers the following extensions:
#      #PRE
#      #DOM:<domain>
#      #INCLUDE <filename>
#      #BEGIN_ALTERNATE
#      #END_ALTERNATE
#      \0xnn (non-printing character support)
# Following any entry in the file with the characters "#PRE" will cause
# the entry to be preloaded into the name cache. By default, entries are
# not preloaded, but are parsed only after dynamic name resolution fails.
# Following an entry with the "#DOM:<domain>" tag will associate the
# entry with the domain specified by <domain>. This affects how the
# browser and logon services behave in TCP/IP environments. To preload
# the host name associated with #DOM entry, it is necessary to also add a
# #PRE to the line. The <domain> is always preloaded although it will not
# be shown when the name cache is viewed.
# Specifying "#INCLUDE <filename>" will force the RFC NetBIOS (NBT)
# software to seek the specified <filename> and parse it as if it were
# local. <filename> is generally a UNC-based name, allowing a
# centralized lmhosts file to be maintained on a server.
# It is ALWAYS necessary to provide a mapping for the IP address of the
# server prior to the #INCLUDE. This mapping must use the #PRE directive.
# In addtion the share "public" in the example below must be in the
# LanManServer list of "NullSessionShares" in order for client machines to
# be able to read the lmhosts file successfully. This key is under
# \machine\system\currentcontrolset\services\lanmanserver\parameters\nullsessionshares
# in the registry. Simply add "public" to the list found there.
# The #BEGIN_ and #END_ALTERNATE keywords allow multiple #INCLUDE
# statements to be grouped together. Any single successful include
# will cause the group to succeed.
# Finally, non-printing characters can be embedded in mappings by
# first surrounding the NetBIOS name in quotations, then using the
# \0xnn notation to specify a hex value for a non-printing character.
# The following example illustrates all of these extensions:
# 102.54.94.97     rhino         #PRE #DOM:networking  #net group's DC
# 102.54.94.102    "appname  \0x14"                    #special app server
# 102.54.94.123    popular            #PRE             #source server
# 102.54.94.117    localsrv           #PRE             #needed for the include
# #BEGIN_ALTERNATE
# #INCLUDE \\localsrv\public\lmhosts
# #INCLUDE \\rhino\public\lmhosts
# #END_ALTERNATE
# In the above example, the "appname" server contains a special
# character in its name, the "popular" and "localsrv" server names are
# preloaded, and the "rhino" server name is specified so it can be used
# to later #INCLUDE a centrally maintained lmhosts file if the "localsrv"
# system is unavailable.
# Note that the whole file is parsed including comments on each lookup,
# so keeping the number of comments to a minimum will improve performance.
# Therefore it is not advisable to simply add lmhosts file entries onto the
# end of this file.
没看到你说的呢?
发表于 2021-5-13 09:32:44 | 显示全部楼层
# This is a sample LMHOSTS file used by the Microsof ...
你看看是不是隐藏了,没有的话我发一个给你
 楼主| 发表于 2021-5-13 14:20:39 | 显示全部楼层
没找到有, 文档里的东西都复制出来了
发表于 2021-5-13 17:32:02 | 显示全部楼层
唯爱许 发表于 2021-5-13 14:20
没找到有, 文档里的东西都复制出来了
发表于 2021-5-13 22:16:21 | 显示全部楼层
把1934的ip改成192.168.0.1就行
 楼主| 发表于 2021-5-14 18:21:42 | 显示全部楼层
已改 重启 还是不行
 楼主| 发表于 2021-5-14 18:24:43 | 显示全部楼层
我的咋少两个文件
 楼主| 发表于 2021-5-14 18:27:19 | 显示全部楼层
发表于 2021-5-15 08:53:51 | 显示全部楼层
你先复制一个别人的hosts文件再重装软件试试
发表于 2021-5-15 13:33:38 来自手机 | 显示全部楼层
你机台上的网关设置错了,192.168.100.1
应该是192.168.1.1
GMT+8, 2025-3-6 23:01
