查看: 35232|回复: 7
[已回复] 未成功: VBA 7.1 (安装)在线解决方案
发表于 2021-5-3 18:31:58 | 显示全部楼层 |阅读模式
天啊 是什么意思啊,装了好久 崩 了心情{:cry:}
81
 楼主| 发表于 2021-5-3 19:28:28 | 显示全部楼层
人呢{:}{:}
28
发表于 2021-5-3 21:59:29 | 显示全部楼层
你管理员运行的吗?电脑配置?
28
发表于 2021-5-3 22:00:01 | 显示全部楼层
电脑系统????
81
 楼主| 发表于 2021-5-4 09:18:29 | 显示全部楼层
WIN10     I5  9400F
发表于 2021-12-5 12:05:19 | 显示全部楼层
This error appears when updating, modifying, or installing an older version of SOLIDWORKS® after installing SOLIDWORKS 2021 SP2 software. The issue occurs because of a change in the Visual Basic for Applications (VBA) version 7.1, introduced in the SOLIDWORKS 2021 SP2 software. Earlier versions of the SOLIDWORKS Installation Manager installer do not recognize the new VBA 7.1 components. Therefore, the installer starts a new installation of the older version of the program. The new VBA 7.1 installation then blocks the software installation.
You cannot correct this issue by using earlier versions of the installation manager. If you encounter this issue, perform the following steps:
1.        Uninstall the new version of VBA 7.1.
2.        Perform the installation steps that lead to the error. The installation should now succeed.
3.        Perform a repair of the recent SOLIDWORKS installation (SOLIDWORKS 2021 SP2 or later) to reinstall the updated VBA 7.1 components.
If required, a utility is available to assist with uninstalling VBA 7.1. To obtain this utility, access the Customer Portal and search for the Knowledge Base solution S-078838.
When this error occurs, the SOLIDWORKS Installation Manager log file typically shows the following entries:
‘{Time}        Info        Step        90        0        "{0: Installing} MSI: {1: {Location of installation files}\SOLIDWORKS 2020 SP05\PreReqs\VBA\vba71.msi}; command-line: {2: }
(ID {3: Microsoft_VBA}, lang {4: }, pcode {5: {90120064-0070-0000-0000-4000000FF1CE}}, mode {6: 7}, upg = {7: }, f{8: 0}, costKB {9: 0})"’
‘{Time}        Error        Status        149        0        "Product:CAM ErrorCode:0 Message:A newer version of this application is already installed. Installation stopped."’
发表于 2021-12-5 12:07:13 | 显示全部楼层
最根本原因是VBA太新了,你应该安装过新版本,所以旧版本安装不上了,首先是要卸载VBA7.1,不行的话按照上方方式操作,可解决。
发表于 2021-12-5 14:07:59 | 显示全部楼层
有可能你卸载了系统中的Excel表格软件,网上搜一下“Microsoft Visual Basic for Applications7.1(x64)”下载到电脑中安装一下,问题就可以解决了。
发表于 2022-12-20 14:47:27 | 显示全部楼层
GMT+8, 2025-4-28 11:58
