查看: 1296|回复: 2
[求助] KF可以实现零件的装配吗?
发表于 2021-4-22 10:36:08 | 显示全部楼层 |阅读模式
KF可以实现零件的装配吗??有大佬可以给举一个例子吗{:cry:}
 楼主| 发表于 2021-4-22 15:22:06 | 显示全部楼层
根据采用现有对象工具,得到了一段代码,但是这段代码无法复现装配操作
(Child) duiqi:
        Class, nx_component_constraint;
        arrangement_specific, FALSE;
        References, {
                {movable_object,ug_refObject("JIANGZHOU:O-134-73",""),geometry,ug_refObject("FACE:O-203-73",""),uses_axis,TRUE,
                is_indirect,FALSE,Help_Point,Point(0,3000,0),half_space,infer,use_port_rotate,FALSE},
                {movable_object,ug_refObject("DIANJIZHOU:O-365-73",""),geometry,ug_refObject("FACE:O-445-73",""),uses_axis,TRUE,
                is_indirect,FALSE,Help_Point,Point(0,2000,0),half_space,infer,use_port_rotate,FALSE}
        constraint_type, touch;
        constraint_alignment, co_align;
        suppressed, FALSE;
        expression, 0;
        persistent, TRUE;
        automatic, FALSE;
        spline_points_type, invalid;
        Name, "duiqi";
贵宾
论坛技术员论坛贡献
发表于 2021-4-22 14:41:25 | 显示全部楼层
可以装配
GMT+8, 2025-2-2 17:44
