查看: 6044|回复: 6
[已解决] UG宏录制
发表于 2021-3-11 09:36:44 | 显示全部楼层 |阅读模式
    我过去在别人那里拷贝了一个UG7.0的宏文件,点下就可以一次性改变选择了的体的颜色,每个体的颜色都不一样,对导入那些没有颜色属性的STEP文件很方便。但放到UG10里面就出问题,我想重新录制,但不知道是怎么录制的,这个谁会。
以下为宏用记事本打开:
NX 7.0.0.9
Macro File: D:\123.macro
Macro Version 7.50
Macro List Language and Codeset: simpl_chinese 13
Created by Administrator on Fri Nov 26 15:26:15 2010
Part Name Display Style: $FILENAME
Selection Parameters 1 2 0.344488 1
Display Parameters 1.000000 12.130906 7.591043 -1.000000 -0.625761 1.000000 0.625761
RESET
MENU, 0, UG_FILE_RUN_GRIP UG_GATEWAY_MAIN_MENUBAR !
FOCUS CHANGE IN 1
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FILE_BOX -2, D:\ug-template\ug-color\color.grx  D:\ug-template\ug-color\*.GRX  0 ! Execute GRIP
ASK_ITEM 2228225 (1 BOOL 0) = 1  !
ASK_ITEM 2228225 (1 BOOL 0) = 0  !
DIALOG_BEGIN "Class Selection" 0 ! DA2
BEG_ITEM 327680 (1 BOOL 0) = 0  ! Select Objects
BEG_ITEM 1835008 (1 STRN 0) = ""  ! Select by Name
BEG_ITEM 2228225 (0 BOOL 0) = 0  !
BEG_ITEM 3670016 (1 CTOL 0) = 1  !
BEG_ITEM 4849666 (1 BOOL 0) = 1  ! Preview
ASK_ITEM 327680 (1 BOOL 0) = 0  ! Select Objects
ASK_ITEM 327680 (1 BOOL 0) = 1  ! Select Objects
FOCUS CHANGE IN 1
MENU, 0, UG_MACRO_USER_ENTRY UG_GATEWAY_MAIN_MENUBAR !
USER_ENTRY_PROMPT -2 0
USE_ITEM 327680 (1 BOOL 0) = 1  ! Select Objects
USE_ITEM 1835008 (1 STRN 0) = ""  ! Select by Name
USE_ITEM 2228225 (0 BOOL 0) = 0  !
USE_ITEM 3670016 (1 CTOL 0) = 1  !
USE_ITEM 4849666 (1 BOOL 0) = 1  ! Preview
USER_ENTRY_BEGIN
CURSOR_EVENT 1001 60,120,0 ! wheel, mb8/0+70, U_None
CPOS -25.78962,-2.38430440000001,0
CPOS -25.78962,-2.63006440000002,0
CURSOR_EVENT 1001 7,1,205 ! begin_drag, mb1/0+0, U_Pre_sel_BD (N:0)
CPOS -49.34162,17.8499356,0
CPOS -24.66322,4.53793559999999,0
CURSOR_EVENT 1001 5,1,101 ! two_pt, mb1/0+0, U_Drag_rls (N:0)
CPOS_WV 1001,15.78478,-27.2060644,0
EVENT FOCUS_IN 0 0, 327680, 0, 0, 0! Select Objects
OK 0 0 ! OK Callback
END_ITEM 327680 (1 BOOL 0) = 0  ! Select Objects
END_ITEM 1835008 (1 STRN 0) = ""  ! Select by Name
END_ITEM 2228225 (0 BOOL 0) = 0  !
END_ITEM 3670016 (1 CTOL 0) = 1  !
END_ITEM 4849666 (1 BOOL 0) = 1  ! Preview
DIALOG_END -2, 0 ! Class Selection: OK
FOCUS CHANGE IN 1
USER_ENTRY_END
SUB_SELECT 1
To color into all part.zip
1 KB, 下载次数: 72, 下载积分: G币 -1
 楼主| 发表于 2021-3-11 13:24:06 | 显示全部楼层
已解决,原来里面有个二次开发程序.
发表于 2021-3-11 20:28:48 | 显示全部楼层
楼主能不能详细介绍一下怎么用
发表于 2024-1-4 17:52:21 | 显示全部楼层
楼主能不能详细介绍一下怎么用
发表于 2024-10-6 09:40:43 | 显示全部楼层
楼主能不能详细介绍一下怎么用
发表于 2024-10-6 16:36:55 | 显示全部楼层
搞半天这个怎么用
发表于 2024-11-4 10:49:31 | 显示全部楼层
多谢楼主分享,学习了6666
GMT+8, 2025-4-16 18:17
