查看: 9607|回复: 13
[1953系列] 1957更新内容!
4万
发表于 2021-1-29 12:05:16 | 显示全部楼层 |阅读模式
我来重新下序看看。
5万
发表于 2021-1-29 12:13:54 | 显示全部楼层
看不懂啊哥{:sweat:}
发表于 2021-1-29 13:11:52 | 显示全部楼层
看不懂,用了半天,也不知道更新了撒
47
4万
 楼主| 发表于 2021-1-29 14:29:15 | 显示全部楼层
版本号问题编号描   述应用模块功能子功能
19579812396Interoperability with SE 2020 doesn't work anymore for Hole MillingASSEMBLIESPART_FILE_OPSOPEN_SOLID_EDGE
195798615984GD load workset fail due to Encountered unexpected NULL pointerASSEMBLIESASSEMBLY_MODELCOMP_REPLACE
19579922962mqc_askObjectOfType hangs on dataASSEMBLIESPOSITIONINGCONSTRAINTS
19578456106Unable To Select Convergent Body For Process SimulationCAEADV_SIMULATIONADDITIVE_MAN
19578460891An error occurs when executing the model setup command on SOL153CAEADV_SIMULATIONCHK_MODEL_SETUP
19578462212incorrect export of RSPLINE element in Simcenter 3DCAEADV_SIMULATIONNASTRN_NX_EXPRT
19579866080Append .cdb does not read Physical Property label properlyCAEADV_SIMULATIONANSYS_IMPORT
19579901660Material data is not displayed properlyCAEADV_SIMULATIONMATERIALS
19579908013Bolt Mesh from Universal Connection incorrectly generatedCAEADV_SIMULATIONCONNECTIONS_UNI
19579912515computation is successful in 2020.1, fatal error - in 2020.2CAEADV_SIMULATIONSYSNOISE_SOLVER
19579913891IDs are different after importing CDBCAEADV_SIMULATIONANSYS_IMPORT
19579913892Under 3D collector, name of the collector imported is showing as  "shell"CAEADV_SIMULATIONANSYS_IMPORT
19579913895Label not consistent for Real ZeroesCAEADV_SIMULATIONANSYS_IMPORT
19579919715SpecDur - Only positive stress values allowed for "Surface Residual  Stress"CAEADV_SIMULATIONDUR_SPEC_SOLV
19579919746SpecDur - Surface Residual Stress causes error message in calculationCAEADV_SIMULATIONDUR_SPEC_SOLV
19579920277MLPP cannot deal with large CGNS filesCAEADV_SIMULATIONNVA_NVH_SOLV
19579924850Flex animation scaleCAEMOTIONANIMATION
19579926543Import ansys filesCAEADV_SIMULATIONANSYS_IMPORT
19579931774Fail to create select recipes for Bearing based on mres file in Simcenter  AcoustCAEMOTIONMOTION2ACOUSTIC
19579934518Selection recipe -name of the CMBLOCK written with FEM name in the ANSYS  deck foCAEADV_SIMULATIONANSYS_EXPORT
19579939373Incorrect Module Number A FATAL ERROR OCCURRED. PROGRAM STOPPEDCAEADV_SIMULATIONSYSNOISE_SOLVER
19577714122IPW on turning operation is brokenCAMTURNINGGEOMETRY
19578459766Internal error when doing Robotics simulation with collision checkingCAMISVROBOTICS
19578461341the new create feature process function doesn't find tools of non-leaf  classesCAMFEATURE_BASEDOPERATION_SELEC
19579789471Unable to generate tool path in turning operation - Offset Blank Geometry  FailedCAMTURNINGGEOMETRY
19579884953Error during Robotics simulation when collision checking is onCAMISVROBOTICS
19579892485Offset blank geometry failedCAMTURNINGGEOMETRY
19579902594Add-on rule is created in Japanese name automatically and returns a  syntax errorCAMFEATURE_BASEDFEATURE_TEACH
19579906244Tool Path Animation causing fatal error in managed modeCAMTC_MFGOTHER
19579906988Offset blank geometry failedCAMTURNINGGEOMETRY
19579933115Cut region not detectedCAMTURNINGGEOMETRY
19579905841Outer path cannot be generated with circumference with 5 axis ScanCMM_INSPECTIONPATHALL
19579906804The message "PAMEAS/ Scanning is not supported." is displayedCMM_INSPECTIONPOSTPROCESSINGMCOSMOS
19578458135Problem with update/status of composite curveDESIGNDESIGN_GROUPSUNDETERMINED
19579877724Incorrect behavior during unit and trigonometric calculationDESIGNEXPRESSIONALL
19579890359Calling NXOpen::MeasureBodies methods fail from Part Opened CallbackDESIGNINFO_ANALYSISMEASURE
19579904988Replacement Assistent does not work in NX1926DESIGNWAVELINKED_BODIES
19579918557NX hangs up while typing one of similar names into feature expression  blockDESIGNEXPRESSIONUSER_INTERFACE
19579919039Poor save performance (with mass calc on)DESIGNINFO_ANALYSISMASS_PROPERTIES
19579919683Graphics performance of dynamic preview during Extrude command extremely  in 1926DESIGNFEATURE_MODELEXTRUDE_GENERAL
19579920701Measure Minimum Perpendicular distance not correct in NX1926DESIGNEXPRESSIONMEASUREMENTS
19579944738Law defined spline created in NX11 is not updating properly in NX1872DESIGNCURVELAW_SPLINE
19579893683"Part is not a version of component part" alert appears for  each comGATEWAYOPEN_JTLOAD_FRAMEWORK
19578459853Number of templates in the  ‰\DESIGN_TOOLS\checkmate\customization\simpl_chineseKDAVALIDATIONHD3D_RESULTS
19579916426Tooling BOM - Sort Ascending disregards alphanumeric order since NX1899KDAMOLDWIZARDBOM
19579916450Welding Joint Maximum Face GapKDAWELD_ASSISTANTWELDING_JOINT
19579922009Progressive Die Wizard intermediate stages does not work with Teamcenter  with thKDAPROGRESSIVE_DIEALL
19579926365Check-Mate: The HTML template file for detail is not foundKDAVALIDATIONHD3D_RESULTS
19579848646SheetMetal.ExportFlatPatternBuilder Journal fails to create DXF file in  batchNX_SHEET_METALFLAT_PAT_EXPORTDXF
19579919008Broaden the display values for Customer Defaults Sheet Metal Material  StandardsNX_SHEET_METALDEFAULTSALL
19578459918Missing Tag for P&IDNXMANAGERDEAPALL
19579904400Changed behavior for NXOpen.PrintPDFBuilderNXMANAGERTRANSLATORSINFRASTRUCTURE
19579920402NX P&ID Mechanical Routing, Run and Run Item Attribute Prefix String  (CD) failNXMANAGERDEAPALL
19579923374P&ID EQUIPMENT TYPE and RELATIONSHIP not workingNXMANAGERDEAPALL
47
4万
 楼主| 发表于 2021-1-29 14:30:18 | 显示全部楼层
版本号问题编号描   述应用模块功能子功能
19579777084Customization of the XML intermediate file to export the symbol  attributesP&ID_DESIGNER2D_TO_3DEXPORT_RUN
19579931998Allow HVAC as a supported discipline (routing) for NX P&IDP&ID_DESIGNERMISCELLANEOUSALL
19579925673P&ID Library Install tool does not complete the installationPLMXMLIMPORT_EXPORTALL
19579923311Electrical Routing PLMXML gives internal error when imported into NXROUTING_ELECCONNECTION_LISTIMPORT_ALL
19579945708Place component command does not work when part_name equals Item IDROUTING_ELECCOMPONENT_LISTCREATE_COMP
19579881483Material attribute on overstock is changed or removed with associatived  partROUTING_GENERALSTOCK_AS_COMPOVERSTOCK
19578457647Simplify Path with tolerance exceeded is refused (OK) without alert  (WRONG)RSD_GENERALPATHEDIT
19578457674Simplify Path to be refused if fixed angle corners are used on end(s) of  segmentRSD_GENERALPATHSIMPLIFY
19578457248Default Value for attributes in GARoomDefinition.xml not workingSHIP_DESIGNGENERAL_ARRANGEROOM_ATTR
19578462956Manufacturing Preparation missing Feature NameSHIP_DESIGNMANUFACTURINGMFG_PREP
19578463175Plate Chamfer does not workSHIP_DESIGNSTEEL_FEATURESPLATE_CHAMFER
19578463769EndCut_Parameter_Rules does not work as in NX12SHIP_DESIGNSTEEL_FEATURESEND_CUT
19578464145Endcut with Preview forces an internal error messageSHIP_DESIGNSTEEL_FEATURESPROFILE_CUTOUT
19579549944Enhancement Request: unique part IDs for all plates and profilesSHIP_DESIGNSTEEL_FEATURESPLATE
19579905619Profile Sketch: wrong values for shear angle/distance on edge  reinforcement platSHIP_DESIGNDRAWING_AUTOINVRS_BEND_LINE
19579920408Ship design with NX1926, ability to change the profile cutout and bracket  colourSHIP_DESIGNMODELINGALL
19579924787Ship Structure XML Export to custom item typeSHIP_DESIGNBASIC_DESIGNSTRUCTURE_XML
19579933832EndCut need to have a Shear Angle" inputSHIP_DESIGNSTEEL_FEATURESEND_CUT
19578464206Create Linear Path with Dynamic Axis and Slope value gives uncontrolled  XC-YC PtSYSENGUI_COMPONENTSOTHER_BLOCK
19571997591Import of Creo 2.0 PTC piece part failsTRANSLATORPROE_INTERFACEALL
19577252445Cannot translate new PROE filesTRANSLATORPROE_INTERFACEALL
19579256485NX is not able to import ProE fileTRANSLATORPROE_INTERFACEALL
19579833030ERROR 1250 run_ugtopv.bat on a list of parts causes remainder of listTRANSLATORNX_JTTC_INTEGRATION
19579856305Pro-E files are not translatingTRANSLATORPROE_INTERFACEALL
19579859732NXPROE Translator issuesTRANSLATORPROE_INTERFACEALL
19579882671Using "LIST" option on_ugtopv.bat, will not continue if failure  occurredTRANSLATORNX_JTTC_INTEGRATION
19579917348Dimension values are changed performing Export 2D Exchange (Output to  Drafting)TRANSLATORUGTO2DEXPORT_DRAFTING
47
4万
 楼主| 发表于 2021-1-29 14:35:57 | 显示全部楼层
不懂的就谷歌翻译下网页。按应用模块分类排序了。
常用的应用模块:
ASSEMBLIES             装配
CAM                         加工
DESIGN                    建模
NX_SHEET_METAL   钣金
TRANSLATOR          导入导出
29
发表于 2021-1-29 17:03:58 | 显示全部楼层
1957 7714122车削操作中的IPW损坏CAM TURNING GEOMETRY
1957 8459766使用碰撞检查进行机械模拟时的内部错误CAM ISV ROBOTICS
1957 8461341新的创建要素处理函数找不到非叶类的工具CAM FEATURE_BASED OPERATION_SELEC
1957 9789471车削操作中无法生成刀具路径-偏移空白几何失败CAM车削几何
1957 9884953在CAM ISV ROBOTICS上进行碰撞检查时,在机器人仿真过程中出错
1957 9892485偏移毛坯几何体失败CAM TURNING GEOMETRY
1957 9902594自动用日语名称创建附加规则,并返回语法错误CAM FEATURE_BASED FEATURE_TEACH
1957 9906244工具路径动画在托管模式下导致致命错误CAM TC_MFG OTHER
1957 9906988偏移毛坯几何失败CAM TURNING GEOMETRY
1957 9933115未检测到切割区域CAM车削几何
发表于 2021-1-29 18:23:47 | 显示全部楼层
链接:https://pan.baidu.com/s/1AqM_LqO-lyZDK8JtwlrlMQ
提取码:9wc0
复制这段内容后打开百度网盘手机App,操作更方便哦
发表于 2021-1-30 00:55:04 | 显示全部楼层
提取码:9wc0
复制这段内容后打开百度网盘手 ...
大佬,这个里面有安装教程吗?
我电脑里已经安装了10.0 和12两个版本的再装这个1957的会有冲突吗‘
发表于 2021-1-30 07:40:49 来自手机 | 显示全部楼层
提取码:9wc0
复制这段内容后打开百度网盘手 ...
GMT+8, 2025-4-28 23:22
