发表于 2020-12-21 15:46:40
显示全部楼层
后处理直接修改C:/ProgramData/WorkNC/2021.0/pospro/下的文件,用记事本打开,类似下面的内容。
1 APT : 1 Character at beginning of file
0 : 2 Character at end of file
1 : 3 Commentary: 0=no,1=yes,2=yes,with block nos
0 : 4 Spindle speed command
1 3 : 5 Output format : 1=whole units,2=1/100,3=1/1000
0 : 6 Condensed mode: 0=no,1=yes
0 30000 : 7 Maximum block number per file: 0=n/a
1 5 : 8 Initial block number: 0=no block numbers
1 1 : 9 Incrementation between blocks
0 : 10 Start up command
0 : 11 Stop command
1 G00 5000 : 12 Fast speed: 1=1st point feeding speed,2=fast
0 : 13 Feeding speed: 2=code F.. with 1st point only
0 : 14 Point directed: 0=centre,1=tip
0 : 15 No of free-format lines, each file (20*75 max)
1 .apt : 16 Output file extension: 0='.blc'
0 : 17 Characters to add at the end of each line: 0=n/a
0 : 18 Maximum size in characters per file: 0=n/a
0 : 19 Maximum distance machined per file: 0=n/a
0 : 20 No of lines between blocks: 0=n/a
0 : 21 First point: 0=XYZ,1=Z only, 2=XY only;
0 : 22 Transformation to the machine axes: 0=n/a
0 : 23 No of free-format lines, first file only
0 : 24 Break the file at each z-level?
0 : 25 Coordinate mode: 0=absolute,1=incremental
0 : 26 Speed change rapid -> feed: 1=before, 2=after
0 : 27 Speed change feed -> rapid: " "
1 1 : 28 Commentaries required : header,distances
0 : 29 Axis labels : 0=n/a
0 : 30 Format of speed commands : 0=n/a
0 : 31 Tool axis rotation : 0=n/a
0 : 32 Tool correction : 0=n/a
0 : 33 Supplementary block
#44 1 : Changes the output file name format
@(#)apt.ang 1.6 1/7/98 WORKNC
