查看: 8041|回复: 9
[分享] 自己收集的UG后处理定制命令
发表于 2020-11-1 11:46:16 | 显示全部楼层 |阅读模式
刀名字
global mom_tool_name
global mom_tool_diameter
global mom_tool_corner1_radius
MOM_output_literal "(NAME:$mom_tool_name )"
MOM_output_literal "(D : [ format  "%.2f" $mom_tool_diameter]  )"
MOM_output_literal "(R : [ format  "%.2f" $mom_tool_corner1_radius]  )"
global mom_tool_name mom_tool_type
global mom_tool_diametermom_tool_corner1_radius mom_tool_flute_length
global mom_tool_length
MOM_output_literal"(ToolName=$mom_tool_name)"
MOM_output_literal "(D=[format"%.2f" $mom_tool_diameter])"
MOM_output_literal "(R=[format"%.2f" $mom_tool_corner1_radius])""
MOM_output_literal "( F=[format"%.2f" $mom_tool_flute_length] )"
MOM_output_literal "(L=[format"%.2f" $mom_tool_length])"
MOM_output_literal"($mom_tool_name--> D=[format "%.2f" $mom_tool_diameter]R=[format "%.2f" $mom_tool_corner1_radius])"
刀前加段号
MOM_set_seq_on
   MOM_output_literal "  "
    MOM_set_seq_off
刀具结尾加时间
global mom_machine_time
MOM_output_literal "(Total OperationMachine Time : [format "%.2f" $mom_machine_time] min )
坐标支持G54.1P1
global mom_fixture_offset_value
set c [expr $mom_fixture_offset_value+53]
set d [expr 0-$mom_fixture_offset_value]
global e
if {$mom_fixture_offset_value >="0"} {
set e $c
} else {
set e 54.1\ P[format "%02.0f" $d]
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image003.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png
发表于 2020-11-1 16:49:23 | 显示全部楼层
太感谢了
发表于 2020-11-1 17:46:24 | 显示全部楼层
谢谢分享!谢谢分享!
33
发表于 2020-11-2 08:34:31 | 显示全部楼层
发表于 2020-11-2 09:10:48 | 显示全部楼层
发表于 2020-11-9 21:52:45 | 显示全部楼层
谢谢分享!
发表于 2021-6-2 14:06:54 | 显示全部楼层
发表于 2021-9-10 10:00:13 | 显示全部楼层
感谢楼主分享
发表于 2021-10-8 23:56:07 来自手机 | 显示全部楼层
怎么制定  恒定余量 你的这里有侧面和底面 恒定余量 是什么代码
发表于 2024-7-22 23:01:38 | 显示全部楼层
{:smile:}好东西啊
GMT+8, 2025-2-23 15:17
