查看: 1382|回复: 0
[求助] 有没有哪位大神帮忙看一下,下面代码为什么编译不成功
发表于 2020-9-13 09:55:18 | 显示全部楼层 |阅读模式
string/str(99),A1(132),WPN(132),LYR(132)
STRING/DIR(132),NA(132),TN(30),AA(132) ,CCJ(132),OP(30),BA(132)$$字符变量声明
NUMBER/ZL,ZL1,ORG_ZL $$
entity/obj   $$实体变量声明
FTERM/TXT,1$$关闭临时文件1#
&ENTCLR=44 $$实体颜色设置
&ENSITE=&TOPL  $$设置字符对齐方式
&DLWID=1
&CSIZE=3.3   $$设置字符尺寸方式
C1:
OBJ=LINE/2,272,0,208,272,0
OBJ=LINE/2,264,0,208,264,0
OBJ=LINE/2,256,0,208,256,0
OBJ=LINE/2,167,0,208,167,0
OBJ=LINE/169,159,0,208,159,0
OBJ=LINE/169,151,0,208,151,0
OBJ=LINE/169,143,0,208,143,0
OBJ=LINE/169,135,0,208,135,0
OBJ=LINE/169,127,0,208,127,0
OBJ=LINE/169,126,0,208,126,0
OBJ=LINE/169,118,0,208,118,0
OBJ=LINE/169,110,0,208,110,0
OBJ=LINE/169,102,0,208,102,0
OBJ=LINE/169,94,0,208,94,0
OBJ=LINE/169,86,0,208,86,0
OBJ=LINE/169,85,0,208,85,0
OBJ=LINE/169,77,0,208,77,0
OBJ=LINE/169,69,0,208,69,0
OBJ=LINE/169,61,0,208,61,0
OBJ=LINE/169,53,0,208,53,0
OBJ=LINE/169,52,0,208,52,0
OBJ=LINE/169,44,0,208,44,0
OBJ=LINE/169,36,0,208,36,0
OBJ=LINE/169,28,0,208,28,0
OBJ=LINE/169,20,0,208,20,0
OBJ=LINE/2,2,0,208,2,0
OBJ=LINE/208,272,0,208,2,0
OBJ=LINE/2,175,0,208,175,0
obj=LINE/2,272,0,2,2,0
obj=LINE/14,272,0,14,256,0
obj=LINE/40,272,0,40,264,0
obj=LINE/58,272,0,58,264,0
obj=LINE/77,272,0,77,264,0
obj=LINE/95,272,0,95,264,0
obj=LINE/125,272,0,125,256,0
obj=LINE/138,272,0,138,256,0
obj=LINE/158,272,0,158,256,0
obj=LINE/178,272,0,178,264,0
obj=LINE/168,264,0,168,256,0
obj=LINE/13,175,0,13,167,0
obj=LINE/52,175,0,52,167,0
obj=LINE/68,175,0,68,167,0
obj=LINE/86,175,0,86,167,0
obj=LINE/104,175,0,104,167,0
obj=LINE/127,175,0,127,167,0
obj=LINE/151,175,0,151,167,0
obj=LINE/169,175,0,169,2,0
obj=LINE/196,159,0,196,127,0
obj=LINE/188,118,0,188,86,0
obj=LINE/182,77,0,182,53,0
obj=LINE/195,85,0,195,53,0
obj=LINE/188,52,0,188,28,0
C2:
&CSIZE=10   $$设置字符尺寸方式
note/38,290,'######塑料有限公司'
C3:
&CSIZE=4   $$设置字符尺寸方式
note/3,269,'模号'
note/3,261,'路径'
note/40,269,'工件名称'
note/77,269,'工件编号'
note/125,269,'编程员'
note/125,261,'材 质'
note/142,269,'###'
note/159,269,'编程日期'
note/159,261,'尺寸'
note/3,173,'序号'
note/23,173,'刀具名称'
note/53,173,'刀具号'
note/70,173,'刀补号'
note/93,173,'类型'
note/110,173,'余 量'
note/134,173,'Z深度'
note/154,173,'刀具号'
note/177,173,'加工参数如下'
note/180,165,'工件坐标'
note/170,157,'XY四面分中'
note/170,149,'XY单边基准'
note/170,141,'Z碰顶取数'
note/170,133,'Z碰底取数'
note/180,124,'装夹方式'
note/172,116,'压码仔'
note/172,108,'虎 钳'
note/172,100,'收 板'
note/172,92,'机 床'
note/172,82,'放电间隙'
note/197,82,'数量'
note/171.5,75,'粗公'
note/171.5,67,'中公'
note/171.5,59,'幼公'
note/170,50,'上机时间'
note/170,42,'下机时间'
note/170,33,'下机检查'
note/180,25,'备  注'
C4:
NA='d:\ccjccj\nc\'  $$数组,定义它的默认值路径
DIR=&NAME   $$取得UG当前部件的文件名并赋值
TN=SUBSTR(DIR,1,LENF(DIR)-3)$$截取字符串
OP='XL'  $$字符串赋值
CCJ=NA+TN+OP   $$ 路径名加上文件名,字符串相加
FETCH/TXT,1,CCJ  $$寻找文件
RESET/1 $$重新设置文件指针把光标放到顶端
ZL=0
ORG_ZL=0
L1:
READ/1 ,IFEND,L3:,AA $$读取文本
ZL=ZL+1
JUMP/L1:
L3:
READ/1,BA $$读取文本
DO/L4:,ZL1,0,ZL
READ/1,IFEND,L4:,IFERR,L4:,BA $$读取文本
&ENTCLR=44 $$实体颜色设置
&DLWID=1
obj=line/2,161,0,169,161,0
obj=line/2,155-ORG_ZL,0,169,155-ORG_ZL,0
obj=line/13,161-ORG_ZL,0,13,155-ORG_ZL,0
obj=line/52,161-ORG_ZL,0,52,155-ORG_ZL,0
obj=line/68,161-ORG_ZL,0,68,155-ORG_ZL,0
obj=line/86,161-ORG_ZL,0,86,155-ORG_ZL,0
obj=line/104,161-ORG_ZL,0,104,155-ORG_ZL,0
obj=line/127,161-ORG_ZL,0,127,155-ORG_ZL,0
obj=line/151,161-ORG_ZL,0,151,155-ORG_ZL,0
note/6,165-ORG_ZL,'<C1.000>'+BA+'<C>'
ORG_ZL=ORG_ZL+6
L4:
WPN=&NAME   $$取得UG当前部件的文件名并赋值
&FULLDT=2   $$时间输出格式2
LYR=DATE   $$变量名赋值
            $$字符串的输入。
T10:
text/'请输入模号*默认为1234567',str,resp
jump/T10:,TXT:,,resp
IF/LENF(str)==0,str='1234567'
TXT:
   A10:
choose/'请选择工件名称','前模仁','后模仁','前模行位','后模行位',$
                                              '斜 顶',$
                                             '前模电极',$
                                            '后模电极',$
                                            '行位电极',$
                                             '斜顶电极',$
                                                        resp
jump/A10:,B10:,,,A20:,resp
jump/A10:,B20:,,,A30:,resp
jump/A10:,B30:,,,A40:,resp
jump/A10:,B40:,,,A50:,resp
jump/A10:,B50:,,,A60:,resp
jump/A10:,B60:,,,A70:,resp
jump/A10:,B70:,,,A80:,resp
jump/A10:,B80:,,,A90:,resp
jump/A10:,B90:,,,A100:,resp
jump/A10:,TTT:,,,B10:,B20:,B30:,B40:,B50:,B60:,B70:,B80:,B90:,resp
A20:
jump/B10:
A30:
jump/B20:
A40:
jump/B30:
A50:
jump/B40:
A60:
jump/B50:
A70:
jump/B60:
A80:
jump/B70:
A90:
jump/B80:
A100:
jump/B90:
B10:
note/60,269,'前模仁'
jump/TTT:
B20:
note/60,269,'后模仁'
jump/TTT:
B30:
note/60,269,'前模行位'
jump/TTT:
B40:
note/60,269,'后模行位'
jump/TTT:
B50:
note/60,269,'斜 顶'
jump/TTT:
B60:
note/60,269,'前模电极'
jump/TTT:
B70:
note/60,269,'后模电极'
jump/TTT:
B80:
note/60,269,'行位电极'
jump/TTT:
B90:
note/60,269,'斜顶电极'
jump/TTT:
TTT:
note/95,269,'<C0.6>'+WPN+'<C>'
note/180,269,'<C0.6>'+LYR+'<C>'
l10:
choose/'请选择加工材料的类型','钢 料','铜 料','石 墨','其 他',resp
jump/l10:,ccj1:,,,l20:,resp
jump/l10:,ccj2:,,,l30:,resp
jump/l10:,ccj3:,,,l40:,resp
jump/l10:,ccj4:,,,l50:,resp
jump/l10:,trm:,,,ccj1:,ccj2:,ccj3:,ccj4:,resp
$$选择加工材料的类型。
l20:
jump/ccj1:
l30:
jump/ccj2:
l40:
jump/ccj3:
l50:
jump/ccj4:
ccj1:
note/142,261,'钢 料'
jump/trm:
ccj2:
note/142,261,'铜 料'
jump/trm:
ccj3:
note/142,261,'石 墨'
jump/trm:
ccj4:
note/142,261,'其 他'
jump/trm:
trm:
$$将输入的字符串输出。
T20:
note/16,269,str
halt  $$程序结束。
里面的这段代码编译不成功C4:
OP='XL'  $$字符串赋值
ZL=0
ORG_ZL=0
L1:
ZL=ZL+1
JUMP/L1:
L3:
READ/1,BA $$读取文本
DO/L4:,ZL1,0,ZL
&ENTCLR=44 $$实体颜色设置
&DLWID=1
ORG_ZL=ORG_ZL+6
L4:
&FULLDT=2   $$时间输出格式2
LYR=DATE   $$变量名赋值
请大神指点迷津
相关帖子
GMT+8, 2025-1-23 06:16
