查看: 3495|回复: 8
[求助] 关于1934更新
发表于 2020-8-24 15:06:41 | 显示全部楼层 |阅读模式
1934更新了什么,有更新过的大神能发下更新表吗
发表于 2020-8-24 15:56:25 | 显示全部楼层
坐等2021
发表于 2020-8-24 16:44:37 | 显示全部楼层
NX 1934 Series Release Notes - Date: August 2020  1934 Enhancements
- Automation Designer: Support for EPLAN Version 2.9 You can import macros from the EPLAN application to generate electrical schematics of the production equipment or devices that are used in your production system or machines.
- CAE: Universal Spot Weld Connections for LS-DYNA This release adds the ability to realize (mesh) universal spot weld connections in the LS-DYNA solver environment through the combination of an ELEMENT_SOLID(8) to represent the connection with a CONTACT_SPOTWELD card to model the interaction between the connected components and spot weld element.
- Simcenter 3D: Auto BIW Meshing for Crash, Phase II This project is a continuation of “Auto BIW Meshing for Crash” project that was completed for version 1926 of Simcenter 3D. The current project aims in further improving the meshes on automotive panels to meet the requirements of Crash analyses
- Simcenter 3D: Penetration Check Tool The Penetration Check tool help find and remove initial penetrations and intersections between elements (meshes) and contact definitions. Penetrations occur when there is an overlap in the thickness of shell elements. Intersections occur when elements cross one other.
NX 1934系列发行说明-日期:2020年8-1934年增强功能
-自动化设计器:支持EPLAN版本2.9您可以从EPLAN应用程序导入宏以生成生产设备或生产系统或机器中使用的设备的电气原理图。
-CAE:LS-DYNA的通用点焊连接此版本增加了通过结合ELEMENT SOLID(8)来表示与CONTACT SPOTWELD的连接,从而在LS-DYNA求解器环境中实现(网格化)通用点焊连接的功能。卡以模拟连接的零部件和点焊元素之间的相互作用。
-Simcenter 3D:用于崩溃的自动BIW网格划分,第二阶段该项目是“ Auto BIW网格的崩溃”项目的延续,该项目已在1926版的Simcenter 3D中完成。当前项目旨在进一步改进汽车面板上的网格,以满足碰撞分析的要求
-Simcenter 3D:渗透检查工具渗透检查工具可帮助查找和删除元素(网格)和接触定义之间的初始渗透和相交。当壳单元的厚度重叠时会发生渗透。元素相互交叉时会发生交叉。
34
发表于 2020-8-24 18:07:24 | 显示全部楼层
看论坛关于1934讨论热度就可以看出它更新的力度了
4万
发表于 2020-8-24 21:46:34 | 显示全部楼层
Fixed_Problem_Reports_1934.zip (6.75 KB, 下载次数: 164)
发表于 2020-8-27 08:27:16 | 显示全部楼层
你这是下载地址吗。
4万
发表于 2020-8-27 14:09:40 | 显示全部楼层
A574599095 发表于 2020-8-27 08:27
你这是下载地址吗。
更新列表。解决的问题列表。
发表于 2020-8-27 16:17:12 | 显示全部楼层
等高跳刀问题已经解决~~
发表于 2020-8-27 17:41:27 | 显示全部楼层
现在你们新版本,都在哪里下载啊
GMT+8, 2025-3-7 05:11
