楼主: jsqsz
[分享] 后处理制作
发表于 2020-5-21 17:56:51 | 显示全部楼层
楼主帮个忙可以吗,我做后处理老是报警
发表于 2020-5-21 21:53:38 | 显示全部楼层
看看,休息一下吧
发表于 2020-5-27 19:31:34 | 显示全部楼层
MOM_force once D global mom_spindle_speed global mom_operation_name if { $mom_spindle_speed == 0 } { set errmes " WARNING:$mom_operation_name S=0 PLEASE CHECK" MOM_abort "$errmes" } global mom_feed_cut_value global mom_operation_name if { $mom_feed_cut_value == 250 } { set errmes " WARNING:$mom_operation_name F=250 PLEASE CHECK" MOM_abort "$errmes" } global mom_tool_name mom_tool_type global mom_tool_diameter mom_tool_corner1_radius mom_tool_flute_length global mom_tool_length tip_angle mom_tool_point_angle RAD2DEG if ![ info exists mom_tool_cornerl_radius ] { set mom_tool_cornerl_radius 0 } if { $mom_tool_type=="Drilling Tool"} { set tip_angle [ expr $mom_tool_point_angle * $RAD2DEG ] MOM_output_literal "(D=[ format "%.2f" $mom_tool_diameter] tip_angle=[ format "%.2f" $tip_angle])" } else { MOM_output_literal "(D=[ format "%.2f" $mom_tool_diameter] R=[ format "%.2f" $mom_tool_corner1_radius])" } ################################################################################ global mom_tool_number mom_tool_name global mom_operation_name if { $mom_tool_number == 0 } { set errmes " warning:$mom_operation_name  T=0 PLEASE CHECK" MOM_abort "$errmes" } global mom_next_oper_has_tool_change if {[info exists mom_next_oper_has_tool_change]} { if { $mom_next_oper_has_tool_change=="YES"} { MOM_output_literal "M9" MOM_output_literal "M5" MOM_output_literal "/G91 G28 Z0." MOM_output_literal "M01"   } } global mom_machine_time MOM_output_literal " (Total Operation Machine Time : [format "%.2f" $mom_machine_time] min )"
发表于 2020-5-28 21:44:40 | 显示全部楼层
下来看看,谢谢分享。。。。
发表于 2020-5-28 22:43:42 | 显示全部楼层
谢谢!楼主,学习学习
发表于 2020-6-2 21:20:41 | 显示全部楼层
谢谢!楼主,学习学习
24
发表于 2020-6-3 08:45:20 | 显示全部楼层
感谢分享!
发表于 2022-6-27 12:56:37 | 显示全部楼层
谢谢!楼主,学习学习
发表于 2022-6-28 12:55:59 | 显示全部楼层
感谢楼主 学习一下
GMT+8, 2025-3-6 17:51
