查看: 3352|回复: 2
[求助] 我创建一个圆柱体想用UF_FACET_facet_solid离散,在UG里运行的时候不行啊
发表于 2020-3-10 16:17:12 | 显示全部楼层 |阅读模式
我创建一个圆柱体想用UF_FACET_facet_solid离散,在UG里运行的时候不行啊,图里那样
UF_CALL(UF_MODL_create_cyl1(UF_NULLSIGN,origin1,height1,diam1,direction1,&cyl_obj_id1));
UF_CALL(UF_MODL_ask_feat_body(cyl_obj_id1,&cylinder_obj_id1));
UF_FACET_INIT_PARAMETERS(parameters);
   UF_FACET_ask_default_parameters(parameters);//参数查询
UF_FACET_facet_solid(cylinder_obj_id1,parameters,&facet_model1);//离散实体
    UF_FACET_cycle_facets(facet_model1,&facet_id);//遍历离散的实体并获取其顶点
while ( facet_id!= UF_FACET_NULL_FACET_ID )
       UF_FACET_ask_num_verts_in_facet(facet_model1, facet_id,&num_vertices_in_facet);
    UF_FACET_ask_vertices_of_facet(facet_model1, facet_id,&num_verts,facet_vertices);
    for (i=0;i<num_vertices_in_facet;i++ )
    UF_UI_open_listing_window();
          sprintf(msg," %g, %g, %g\n", facet_vertices[0], facet_vertices[1], facet_vertices[2] );
    UF_UI_write_listing_window(msg);
我创建完圆柱体只要加一句UF_FACET函数就在UG里运行不了
发表于 2020-3-11 09:11:30 | 显示全部楼层
帮助文档有例子,
/* This example is referenced for several of the other UF_FACET
   functions.
#include <stdio.h>
#include <uf.h>
#include <uf_modl.h>
#include <uf_assem.h>
#include <uf_facet.h>
static int example1( tag_t *new_faceted_model);
/*ARGSUSED*/
extern void ufusr( char *param, int *retcod, int param_len )
   tag_t faceted_model;
   UF_initialize();
   *retcod = example1(&faceted_model);
   UF_terminate();
static int example1( tag_t * new_faceted_model )
   int          ifail;
   tag_t        part_tag;
   double       corner_point[3];
   char       * edge_lengths[] = { "10", "30", "40" };
   tag_t        block_feature_tag;
   tag_t        block_tag;
   logical      up_to_date = true;
   tag_t        blend_feature;
   uf_list_p_t  edge_list = NULL;
   tag_t        tag_of_solid;
   int          i;
   tag_t      * facet_models;
   int          n_facet_models;
   UF_FACET_parameters_t faceting_params;
   *new_faceted_model = NULL_TAG;
       First create a part in which we will initially create a
       block.
   ifail = UF_PART_new( "uf_facet_exp1_test_part",
                        1 /* MM */,
                        &part_tag );    /* 1 = mm */
   if ( ifail != 0 )
       printf( "**ERR: Failed to create new part ifail %d\n",
               ifail );
       return 1;
   ifail = UF_ASSEM_set_work_part( part_tag );
   corner_point[0] = 0.0;
   corner_point[1] = 0.0;
   corner_point[2] = 0.0;
   UF_MODL_create_block1( UF_NULLSIGN,
                          corner_point,
                          edge_lengths,
                          &block_feature_tag );
   UF_MODL_ask_feat_body( block_feature_tag, &block_tag );
   UF_FACET_INIT_PARAMETERS( &faceting_params);
   UF_FACET_ask_default_parameters( &faceting_params) ;
   UF_FACET_facet_solid( block_tag,
                         &faceting_params,
                         &faceted_model );
   if ( faceted_model != NULL_TAG )
       UF_FACET_ask_solid_of_model( faceted_model, &tag_of_solid );
       if ( block_tag != tag_of_solid )
           printf( "**ERR: Failed find solid from facet model\n" );
           return 1;
       UF_FACET_ask_models_of_solid( block_tag,
                                     &n_facet_models,
                                     &facet_models );
          Just check that the association between the solid and
          the new faceted model has been established.
       for ( i=0 ; i < n_facet_models ; i++ )
           if ( facet_models[i] == faceted_model )
               printf( "Faceted model is attached to solid\n" );
       UF_free( facet_models );
           Now blend all of the edges of the block.
       UF_MODL_ask_body_edges( block_tag, &edge_list );
       UF_MODL_create_blend( "2.0", edge_list,
                             0, 0, 0, 0.0,
                             &blend_feature );
       UF_MODL_delete_list( &edge_list );
       UF_MODL_update();
       ifail = UF_FACET_is_model_up_to_date( faceted_model,
                                             &up_to_date );
       if ( up_to_date )
           printf( "**ERR: Faceted model is up to date\n" );
           return 1;
       ifail = UF_FACET_ask_model_parameters( faceted_model,
                                          &faceting_params );
          Set the number of sides for facets to four and use that
          when refaceting the solid.
       faceting_params.max_facet_edges = 4;
       ifail = UF_FACET_update_model( faceted_model,
                                      &faceting_params );
       if ( ifail != 0 )
           printf( "**ERR: Failed to refacet model\n" );
           return 1;
                                             &up_to_date );
       if (!up_to_date)
           printf( "**ERR: Model is not up to date\n" );
           return 1;
           Finally, disassociate the faceted model from
           the generating solid.
       UF_FACET_disassoc_from_solid( faceted_model );
       *new_faceted_model = faceted_model;
   else
       return 1;
   return 0;
int ufusr_ask_unload(void)
    return (UF_UNLOAD_IMMEDIATELY);
发表于 2023-11-17 09:09:25 | 显示全部楼层
蓝摩羯 发表于 2020-3-11 09:11
帮助文档有例子,
   functions.
UFUN帮助文档有例子还是?
GMT+8, 2026-7-4 18:17
