查看: 27535|回复: 36
[分享] UG后处理常用定制命令
发表于 2020-2-22 12:48:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序名称:
global mom_operation_name
               MOM_output_literal " (NANE:$mom_operation_name)"
创建时间:
global mom_date
               MOM_output_literal "(CREATE DATE: format $mom_date)"
刀具名称:
global mom_tool_name
               MOM_output_literal ";(TOOL NAME: format $mom_tool_name)"
加工时间:
global mom_machine_time
               MOM_output_literal ";(time:[format "%.2f" $mom_machine_time] H )"
刀具信息
           global mom_tool_name mom_tool_type
            global mom_tool_diameter mom_tool_corner1_radius mom_tool_flute_length
            global mom_tool_length
            MOM_output_literal "(ToolName=$mom_tool_name)"
             MOM_output_literal "(D=[format "%.2f" $mom_tool_diameter] R=[format "%.2f"                    $mom_tool_corner1_radius] F=[format "%.2f" $mom_tool_flute_length] L=[format                     "%.2f" $mom_tool_length])"
进给速度为250时报警:
global mom_feed_cut_value
if { $mom_feed_cut_value == 250 } {
set errmes " WARNING:$mom_operation_name F=250 PLEASE CHECK"
MOM_abort "  \n\n\n S=0 \n\n Yang Bao Feng提示:\n\n操作: $mom_operation_name 的进给速度未设定,请设定\n\n\n "
主轴转速为0时报警:
global mom_spindle_speed
if { $mom_spindle_speed == 0 } {
set errmes " WARNING:$mom_operation_name S=0 PLEASE CHECK"
MOM_abort "  \n\n\n S=0 \n\n Yang Bao Feng提示:\n\n操作: $mom_operation_name 的主轴转速未设定,请设定\n\n\n "
参与人数 5G币 +38 收起 理由
万里长城* + 3 楼主是大神!膜拜!
a12345678123 + 6 分享加分!
a123411227 + 16 不错,支持你!
心随行动* + 10 分享加分!
zb1997* + 3 不错,支持你!
推荐
 楼主| 发表于 2020-2-23 12:52:53 | 只看该作者
NC文件生成日期时间:
set a [clock format [clock seconds] -format "%Y/%m/%d"]
set b [clock format [clock seconds] -format "%H:%M"]
set c [clock format [clock seconds] -format "%A"]
if {$c == "Monday"} {set c 一}
if {$c == "Tuesday"} {set c 二}
if {$c == "Wednesday"} {set c 三}
if {$c == "Thursday"} {set c 四}
if {$c == "Friday"} {set c 五}
if {$c == "Saturday"} {set c 六}
if {$c == "Sunday"} {set c 日}
MOM_output_literal "(Date:$a  Time:$b  Day:$c)"
#global mom_date
#MOM_output_literal "(Date: $mom_date )"
global mom_part_name
MOM_output_literal "(TASK : $mom_part_name )"
加工余量:
global mom_stock_floor mom_stock_part
global mom_wall_stock mom_stock_part_use
global sidestock floorstock
if {[info exists mom_stock_part]} {
set sidestock $mom_stock_part
} elseif {[info exists mom_wall_stock]} {
set sidestock $mom_wall_stock
} else {
set sidestock 0
if {[info exists mom_stock_floor]} {
    if {[info exists mom_stock_part_use] && $mom_stock_part_use == 1} {
            set floorstock $mom_stock_part
    } else {
    set floorstock $mom_stock_floor
} else {
set floorstock 0
MOM_output_literal "(XY =[format "%.3f" $sidestock]  Z =[format "%.3f" $floorstock])"
刀具号相同提醒:
将此定制命令放在 刀轨开始 处
global mom_tool_number mom_tool_name tool_seq tool_name_array tool_num_array
if {![info exists tool_seq]} {
set tool_seq 0
set tool_name_array($tool_seq) $mom_tool_name
set tool_num_array($tool_seq) T[format "%.2d" $mom_tool_number]
set i 0
while {$i<$tool_seq} {
if {$tool_num_array($i)=="T[format "%.2d" $mom_tool_number]"} {
incr tool_seq -1
if {![string equal $tool_name_array($i) $mom_tool_name]} {
set msg [MOM_display_message "刀具名称 $mom_tool_name 与 $tool_name_array($i) 使用了相同刀具号" QQ同步微信:758917784 I 继续输出 中止后处理]
switch $msg {
1 {set offset_flag 1}
2 {MOM_abort \n\n已中止后处理程序\n\n}
incr i
incr tool_seq
参与人数 1G币 +10 收起 理由
心随行动* + 10 分享加分!
回复 支持 2 反对 0
Rank: 3Rank: 3
推荐
发表于 2020-6-6 19:48:02 | 只看该作者
C:\Users\Administrator\Desktop\888 大佬,怎么删除重复的X、Y,设置I、J为0时省略,跪求方法。。。
回复 支持 1 反对 0
Rank: 8Rank: 8
发表于 2020-2-22 17:00:41 | 只看该作者
学习学习谢谢
发表于 2020-2-22 18:48:18 | 只看该作者
好东西学习,收藏起来
发表于 2020-2-23 19:59:06 | 只看该作者
学习,谢谢分享
Rank: 7Rank: 7Rank: 7
7#
发表于 2020-2-24 22:41:58 | 只看该作者
加工余量命令添加进后处理报警
 楼主| 发表于 2020-2-25 09:55:12 | 只看该作者
qq758917784 发表于 2020-2-24 22:41
加工余量命令添加进后处理报警
请问你把加工余量块放在哪儿了,位置不对可能是要报警,
Rank: 3Rank: 3
发表于 2020-2-25 20:06:14 | 只看该作者
好东西 学习了
Powered by UG爱好者 X3.2  © 2001-2014 Comsenz Inc. GMT+8, 2024-11-23 19:28
