用户名  找回密码
查看: 3312|回复: 5
[求助] UG后处理如何设置出R1~R3
发表于 2020-2-7 11:53:13 | 显示全部楼层 |阅读模式
请问各位大神如何将下面的指令设定进UG后处理
并可以转出进给 F=R1  F=R2  F=R3
N39 R1= 1200 ; PLUNGE FEEDRATE
N40 R2= 1200 ; CUTTING FEEDRATE
N41 R3= 3000 ; RAPID SKIM FEEDRATE
发表于 2020-2-7 12:33:13 | 显示全部楼层
实在不行手动编辑记事本吧   大哥行家呀~  这是5轴手编宏程序还是五轴的机床系统程序?
29
发表于 2020-2-7 17:28:43 | 显示全部楼层
后处理发过来我帮你 改
发表于 2020-2-21 12:24:01 | 显示全部楼层
   global mom_kin_rapid_feed_rate
   global mom_feed_approach_value
   global mom_feed_cut_value
   global mom_feed_departure_value
   global mom_feed_engage_value
   global mom_feed_first_cut_value
   global mom_feed_rapid_value
   global mom_feed_retract_value
   global mom_feed_return_value
   global mom_feed_stepover_value
   global mom_feed_traversal_value
   global mom_feed_rate
   global controller
   global dim mom_operation_type
   global initial_approach
   global initial_cut
   global initial_departure
   global initial_engage
   global initial_first_cut
   global initial_rapid
   global initial_retract
   global initial_return
   global initial_stepover
   global initial_traversal
   global initial_sys_rapid
   MOM_set_seq_off
   if {[info exists mom_feed_approach_value]} {
      set mom_feed_approach_value  [format "%.${dim}f" $mom_feed_approach_value]
      if {![EQ_is_zero $mom_feed_approach_value] } {
         if { [string match "heidenhain" $controller] } {
            MOM_output_literal "   FN 0: Q1=[format "%-25s %-0s" $mom_feed_approach_value ";approach_value"]"
         } elseif {[string match "sinumerik" $controller] } {
            MOM_output_literal "   R1=[format "%-25s %-0s" $mom_feed_approach_value ";approach_value"]"
         } elseif {[string match "fanuc" $controller] } {
            MOM_output_literal "   #1=[format "%-25s %-0s" $mom_feed_approach_value "(approach_value)"]"
         set initial_approach $mom_feed_approach_value
   if {[info exists mom_feed_cut_value]} {
      set mom_feed_cut_value       [format "%.${dim}f" $mom_feed_cut_value]
      if {![EQ_is_zero $mom_feed_cut_value] } {
            MOM_output_literal "   FN 0: Q2=[format "%-25s %-0s" $mom_feed_cut_value ";cut_value"]"
            MOM_output_literal "   R2=[format "%-25s %-0s" $mom_feed_cut_value ";cut_value"]"
            MOM_output_literal "   #2=[format "%-25s %-0s" $mom_feed_cut_value "(cut_value)"]"
         set initial_cut $mom_feed_cut_value
   if {[info exists mom_feed_departure_value]} {
      set mom_feed_departure_value [format "%.${dim}f" $mom_feed_departure_value]
      if {![EQ_is_zero $mom_feed_departure_value] } {
            MOM_output_literal "   FN 0: Q3=[format "%-25s %-0s" $mom_feed_departure_value ";departure_value"]"
            MOM_output_literal "   R3=[format "%-25s %-0s" $mom_feed_departure_value ";departure_value"]"
            MOM_output_literal "   #3=[format "%-25s %-0s" $mom_feed_departure_value "(departure_value)"]"
         set initial_departure $mom_feed_departure_value
    if {[info exists mom_feed_engage_value]} {
       set mom_feed_engage_value    [format "%.${dim}f" $mom_feed_engage_value]
       if {![EQ_is_zero $mom_feed_engage_value] } {
             MOM_output_literal "   FN 0: Q4=[format "%-25s %-0s" $mom_feed_engage_value ";engage_value"]"
             MOM_output_literal "   R4=[format "%-25s %-0s" $mom_feed_engage_value ";engage_value"]"
             MOM_output_literal "   #4=[format "%-25s %-0s" $mom_feed_engage_value "(engage_value)"]"
          set initial_engage $mom_feed_engage_value
    if {[info exists mom_feed_first_cut_value]} {
       set mom_feed_first_cut_value [format "%.${dim}f" $mom_feed_first_cut_value]
       if {![EQ_is_zero $mom_feed_first_cut_value] } {
             MOM_output_literal "   FN 0: Q5=[format "%-25s %-0s" $mom_feed_first_cut_value ";first_cut_value"]"
             MOM_output_literal "   R5=[format "%-25s %-0s" $mom_feed_first_cut_value ";first_cut_value"]"
             MOM_output_literal "   #5=[format "%-25s %-0s" $mom_feed_first_cut_value "(first_cut_value)"]"
          set initial_first_cut $mom_feed_first_cut_value
    if {[info exists mom_feed_rapid_value]} {
       set mom_feed_rapid_value     [format "%.${dim}f" $mom_feed_rapid_value]
       if {![EQ_is_zero $mom_feed_rapid_value] } {
             MOM_output_literal "   FN 0: Q6=[format "%-25s %-0s" $mom_feed_rapid_value ";rapid_value"]"
             MOM_output_literal "   R6=[format "%-25s %-0s" $mom_feed_rapid_value ";rapid_value"]"
             MOM_output_literal "   #6=[format "%-25s %-0s" $mom_feed_rapid_value "(rapid_value)"]"
          set initial_rapid $mom_feed_rapid_value
    if {[info exists mom_feed_retract_value]} {
       set mom_feed_retract_value   [format "%.${dim}f" $mom_feed_retract_value]
       if {![EQ_is_zero $mom_feed_retract_value] } {
             MOM_output_literal "   FN 0: Q7=[format "%-25s %-0s" $mom_feed_retract_value ";retract_value"]"
             MOM_output_literal "   R7=[format "%-25s %-0s" $mom_feed_retract_value ";retract_value"]"
             MOM_output_literal "   #7=[format "%-25s %-0s" $mom_feed_retract_value "(retract_value)"]"
          set initial_retract $mom_feed_retract_value
    if {[info exists mom_feed_return_value]} {
       set mom_feed_return_value    [format "%.${dim}f" $mom_feed_return_value]
       if {![EQ_is_zero $mom_feed_return_value] } {
             MOM_output_literal "   FN 0: Q8=[format "%-25s %-0s" $mom_feed_return_value ";return_value"]"
             MOM_output_literal "   R8=[format "%-25s %-0s" $mom_feed_return_value ";return_value"]"
             MOM_output_literal "   #8=[format "%-25s %-0s" $mom_feed_return_value "(return_value)"]"
          set initial_return $mom_feed_return_value
    if {[info exists mom_feed_stepover_value]} {
       set mom_feed_stepover_value  [format "%.${dim}f" $mom_feed_stepover_value]
       if {![EQ_is_zero $mom_feed_stepover_value] } {
             MOM_output_literal "   FN 0: Q9=[format "%-25s %-0s" $mom_feed_stepover_value ";stepover_value"]"
             MOM_output_literal "   R9=[format "%-25s %-0s" $mom_feed_stepover_value ";stepover_value"]"
             MOM_output_literal "   #9=[format "%-25s %-0s" $mom_feed_stepover_value "(stepover_value)"]"
          set initial_stepover $mom_feed_stepover_value
    if {[info exists mom_feed_traversal_value]} {
       set mom_feed_traversal_value [format "%.${dim}f" $mom_feed_traversal_value]
       if {![EQ_is_zero $mom_feed_traversal_value] } {
             MOM_output_literal "   FN 0: Q10=[format "%-24s %-0s" $mom_feed_traversal_value ";traversal_value"]"
             MOM_output_literal "   R10=[format "%-24s %-0s" $mom_feed_traversal_value ";traversal_value"]"
             MOM_output_literal "   #10=[format "%-24s %-0s" $mom_feed_traversal_value "(traversal_value)"]"
       } else {
             MOM_output_literal "   FN 0: Q10=[format "%-24s %-0s" Q11 ";no set traversal_value"]"
             MOM_output_literal "   R10=[format "%-24s %-0s" R11 ";no set traversal_value"]"
             MOM_output_literal "   #10=[format "%-24s %-0s" #11 "(no set traversal_value)"]"
       set initial_traversal $mom_feed_traversal_value
    set mom_kin_rapid_feed_rate  [format "%.${dim}f" $mom_kin_rapid_feed_rate]
       MOM_output_literal "   FN 0: Q11=[format "%-24s %-0s" $mom_kin_rapid_feed_rate ";system_rapid_value"]"
       MOM_output_literal "   R11=[format "%-24s %-0s" $mom_kin_rapid_feed_rate ";system_rapid_value"]"
       MOM_output_literal "   #11=[format "%-24s %-0s" $mom_kin_rapid_feed_rate "(system_rapid_value)"]"
    set initial_sys_rapid $mom_kin_rapid_feed_rate
放在:proc MOM_initial_move { } { ;#初始移动
发表于 2020-2-21 12:27:49 | 显示全部楼层
   global feed_value
   global controller
   global dim
   set feed_value $mom_feed_rate
   set feed_value [format "%.${dim}f" $feed_value]
      if {$feed_value == $mom_feed_approach_value} {
            set feed_value "Q1"
            set feed_value "=R1"
            set feed_value "#1"
      if {$feed_value == $mom_feed_cut_value} {
            set feed_value "Q2"
            set feed_value "=R2"
            set feed_value "#2"
       if {$feed_value == $mom_feed_departure_value} {
             set feed_value "Q3"
             set feed_value "=R3"
             set feed_value "#3"
       if {$feed_value == $mom_feed_engage_value} {
             set feed_value "Q4"
             set feed_value "=R4"
             set feed_value "#4"
       if {$feed_value == $mom_feed_first_cut_value} {
             set feed_value "Q5"
             set feed_value "=R5"
             set feed_value "#5"
       if {$feed_value == $mom_feed_rapid_value} {
             set feed_value "Q6"
             set feed_value "=R6"
             set feed_value "#6"
       if {$feed_value == $mom_feed_retract_value} {
             set feed_value "Q7"
             set feed_value "=R7"
             set feed_value "#7"
       if {$feed_value == $mom_feed_return_value} {
             set feed_value "Q8"
             set feed_value "=R8"
             set feed_value "#8"
       if {$feed_value == $mom_feed_stepover_value} {
             set feed_value "Q9"
             set feed_value "=R9"
             set feed_value "#9"
       if {$feed_value == $mom_feed_traversal_value} {
             set feed_value "Q10"
             set feed_value "=R10"
             set feed_value "#10"
    if {[info exists mom_kin_rapid_feed_rate]} {
       if {$feed_value == $mom_kin_rapid_feed_rate} {
             set feed_value "Q11"
             set feed_value "=R11"
             set feed_value "#11"
放在:proc PB_CMD_before_motion { } {
发表于 2020-2-21 12:30:38 | 显示全部楼层
以上代码,需要自己根据需要修改!
GMT+8, 2025-3-9 01:16
