查看: 2575|回复: 0
[分享] 函数ProPrintExecute该怎么用才能将工程图打印到硬盘里
发表于 2011-6-16 09:37:20 | 显示全部楼层 |阅读模式
有没有人搞二次开发工程图打印的?函数ProPrintExecute该怎么用才能将工程图打印到硬盘里并保存为jpg格式的图片?我的代码如下:ProPath path;
                ProPlotPaperSize size =
                        A4_SIZE_PLOT
                int width = 297;
                int height = 210;
                ProPrintSize papersize =
                        size,
                        (double)width,
                        (double)height
                int slew = 0;
                ProPrintPrinterOpts PrinterOpts =
                        "JPEG",
                        ///File related options
                        PRO_B_TRUE,
                        PRINT_SAVE_SINGLE_FILE,
                        //name,
                        PRO_B_FALSE,
                        ///Print command options
                        PRO_B_FALSE,
                        //path,
                        //path,
                        1,
                        ///Printer specific options
                        PRO_B_TRUE,
                        PRO_B_FALSE,
                        PRO_B_FALSE,
                        (double)slew,
                        PRO_B_FALSE
                ProPrintMdlOpts PrintMdlOpts =
                        &model,
                        3,
                        ///Options available only with solid objects
                        PRO_B_TRUE,
                        ///Options available only with drawing objects
                        PRO_B_TRUE,
                        PRO_B_TRUE,
                        PRO_B_TRUE,
                        PRO_B_FALSE,
                        //name,
                        PRINT_CURRENT_SHEET,
                int scale = 1,label_height=0;
                double ofset[2]={0,0}, clip_area[2][2]={{0.000000,0.000000},{1.000000,1.000000}};
                ProPrintPlacementOpts PlaceOpts =
                        (double)scale,
                        ofset[2],
                        PRO_B_FALSE,
                        ///options for clipping
                        PRO_B_TRUE,
                        PRO_B_TRUE,
                        PRO_B_TRUE,
                        ///options for label
                        PRO_B_FALSE,
                        NULL//(double)label_height
                ProPrintPrinterOptionsGet("JPEG",&rinterOpts);
                ProPrintMdlOptionsGet(&model,&rintMdlOpts);
                ProPrintPlacementOptionsGet(&laceOpts);
                err = ProPrintExecute(w_id,&rinterOpts,&rintMdlOpts,&laceOpts);
编译没有问题,但就是打印不出来文件,请问各位大侠,我的代码哪里出问题了?
GMT+8, 2025-12-17 18:15
