查看: 3828|回复: 11
[分享] 不错的ProE配置文件
发表于 2015-7-9 21:05:26 | 显示全部楼层 |阅读模式
template_solidpart C:\PTC\PTCWORK\Template\mmns_part_solid.prt
!零件模板使用的模板路径
template_designasm C:\PTC\PTCWORK\Template\mmns_asm_design.asm
!组件模板使用的模板路径
template_drawing C:\PTC\PTCWORK\Template\a4_prt_h.frm
drawing_setup_file C:\PTC\PTCWORK\drawing.dtl
pro_format_dir C:\PTC\PTCWORK\Template
!设置工程图格式文件路径
format_setup_file C:\PTC\PTCWORK\FORMAT.DTL
template_sheetmetalpart C:\PTC\PTCWORK\Template\mmns_part_sheetmetal.prt
!钣金模板使用的模板路径
!调用标准件
pro_library_dir C:\PTC\PTCWORK\MONLibs\
pro_catalog_dir C:\PTC\PTCWORK\MONLibs\
protkdat C:\PTC\PTCWORK\MONLibs\protk.dat
save_objects changed
pro_material_dir C:\PTC\PTCWORK\Materials
!设置材料库文件路径
!自定义符号
pro_symbol_dir C:\PTC\PTCWORK\symlib
!设置轨迹文件存放路径
trail_dir C:\PTC\PTCWORK\trail
!打印机
plotter ms_print_mgr
plotter_command windows_print_manager
pro_plot_config_dir C:\PTC\PTCWORK\dayun
!设置打印机打印样式文件路径
pen_table_file C:\PTC\PTCWORK\dayun\table.pnt
!设置打印线宽配置文件
raster_plot_dpi 100
use_8_plotter_pens yes
!设置使用8笔(影响打印)
menu_translation yes
!设置下拉菜单时为中英文双语菜单-yes
!单位、公差设置
template_mfgmold mmns_mfg_mold.mfg
!template_sheetmetalpart mmns_part_sheetmetal.prt
pro_unit_length UNIT_mm
pro_unit_mass UNIT_gram
ang_units ANG_DEG
tolerance_standard iso
linear_tol 1 0.04
linear_tol 2 0.01
linear_tol 3 0.005
linear_tol 4 0.0005
angular_tol 0 1
angular_tol 1 0.5
angular_tol 2 0.25
display_coord_sys_tags no
chamfer_45deg_dim_text iso/din
!显示、外观
orientation trimetric
tol_display yes
tol_mode nominal
maintain_limit_tol_nominal yes
hlr_for_quilts yes
ang_dim_in_screen yes
axis_display no
color yes
color_windows all_windows
datum_display yes
datum_point_display no
depthcue_always yes
dim_offscreen_limit 1.0
mesh_spline_surf no
number_user_colors 16
spin_with_part_entities yes
spin_with_silhouettes yes
! Assembly Mode
allow_package_children all
allow_redo_intersections no
allow_ref_scope_change yes
clr_print_plus_minus yes
comp_assemble_start package
comp_rollback_on_redef yes
default_ext_ref_scope all
display_in_adding_view default
fix_refs_to_intersections no
freeze_failed_assy_comp no
package_constraints update
scope_invalid_refs prohibit
shade_moving_comp yes
todays_date_note_format %yyyy-%mm-%dd
!出图日期(在工程图模版:&todays_date)
!焊接
weld_ui_standard iso
native_kbd_macros NO
open_simplified_rep_by_default NO
show_dim_sign no
!*                        选项配置                       *
!启动Pro/ENGINEER时,指定要载入的模型树配置文件
!mdl_tree_cfg_file d:\PTC\proeWildfire 5.0\text\fengyu.cfg
!指定系统保存regen_backup模型的目录
regen_backup_directory C:\PTC\PTCWORK\temp
!为新模型设置缺省的单位系统
pro_unit_sys mmns
!指定Pro/E浏览器主页的位置
!web_browser_homepage http://www.baidu.com
!启用为交换数据使用Associative Topology Bus
topobus_enable yes
!加载 AutobuildZ 应用程序
autobuildz_enabled no
!指定每次再生之前,系统是否要将当前模型备份到磁盘
regen_backup_using_disk yes
!对于每个Pro/E进程,用户必须设置主服务器/工作空间
!dm_remember_server no
!输入存储历史记录的天数
web_browser_history_days 0
!设置"文件">"打开"的缺省目录
file_open_default_folder working_directory
!在窗口标题中显示完整文件名和的文件路径
display_full_object_path yes
!为扩大反向箭头 (用于显示特征创建方向) 尺寸设置比例因子 (缺省值 = 1)
flip_arrow_scale 3
!当从一个窗口改变至另一个窗口时,自动重画绘图显示
auto_regen_views yes
!将图片文件嵌入绘图内部以用于预览
save_drawing_picture_file embed
!输出出图或2-D文件之前,为重复直线和收集相同笔色的直线设置检测数量
interface_quality 3
!当从Pro/E绘图中输出时,提供选择DWG文件版本的功能
!草绘器保存每个已执行功能的副本
sketcher_undo_stack_limit 100
!缺省是否显示基准轴
display_axes no
!缺省是否显示坐标系
display_coord_sys no
!缺省是否显示基准面
display_planes yes
!缺省是否显示基准点及其名称
display_points no
!缺省是否显示旋转中心符号
spin_center_display no
model_note_display no
!设置注释不显示
!缺省的曲面显示方式
display shade
!设置信息显示的缺省格式类型
info_output_format text
!设置在所有模型模式中显示非角度尺寸的缺省小数位数 (0-14)
default_dec_places 3
!指定绘图中显示的角度尺寸的小数位数
default_ang_dec_places 2
!计算两个零件或曲面之间的间隙时,设置系统精度显示
!允许用户在Pro/INTERFACE输入中使用模板模型。
intf_in_use_template_models yes
!输入数据是是否显示输入日志文件
intf3d_show_import_log no
!输入曲面时自动修复部分边界
fix_boundaries_on_import yes
!输出STEP文件时包含颜色外观
step_appearance_layers_groups yes
!在"精度"菜单的显示绝对精度定
enable_absolute_accuracy yes
!输入一个精确值来覆盖缺省下限。相对精度的最小值是1E-06
accuracy_lower_bound 0.000001
!在编辑菜单下显示移除功能(该功能可以直接去除圆角,强烈建议做模具的使用)
all_tmp_rmv_srf_feat yes
!2011年8月增加:
create_drawing_dims_only yes
!将在绘图中创建的所有新尺寸仅保存在绘图中
parenthesize_ref_dim yes
!所有参照尺寸除了具有表示其为参照尺寸的特殊注释之外,其他方面均与标准尺寸相同。可使用 parenthesize_ref_dim 配置选项并将其值设置为 yes,将这些尺寸包含在括号内。如果此选项被设置为 no,
set_trail_single_step yes
trail_delay 0.1
dim_inactive_components never
!在组件中激活一个零件,其它零件不为半透明状态
enable_tree_indep yes
!设置树模型定制是否允许从Pro/e窗口分离树模型窗口 。
floating_layer_tree yes
!设置从导航器查看层树对话框。如果用户要从导航器查看层树对话框,请设置为“是”。
reserved_menu_space 1.0
!保留右菜单的空间(1.0-4.0)。
msg_translation yes
!指定运行非英文版Pro/eENGINEER时信息显示的语种
spin_rate_zoom_sensitive NO
!在模型进行放在时,允许减慢旋转。
default_abs_accuracy .001
!定义缺省的绝对精度。
system_colors_file C:\PTC\PTCWORK\colormap\syscol.scl
!指定系统颜色文件,文件路径要正确。
text_height_factor 50
!活动的系统字体的大小。
open_window_maximized yes
!每次打开Pro/ENGINEER时以最大窗口方式打开。
allow_anatomic_features yes
!允许创建高级特征,包括耳、环形槽、唇等。
!allow_confirm_window YES
!退出Pro/ENGINEER时显示一个确认窗口。
default_draw_scale no
!设置工程图中缺省的绘图比例,即插入一般视图时默认为1比1,设为no时可自动适应图纸大小生成第一个视图的比例
general_undo_stack_limit 100
!设置缺省的“撤消/重做”条目数,缺省为50
prehighlight yes
!设置鼠标指针下方所选的项目是否被加亮
preserve_comp_color_in_preview yes
!放置元件期间,正在装配的元件是否保留其正常颜色。
sketcher_dec_places 2
!设置草绘中尺寸显示的缺省小数位数
sketcher_dimension_autolock yes
!自动锁定草绘中的强尺寸
visible_message_lines 2
!设置Pro/ENGINEER信息区域中缺省的可视信息行数。
tangent_edge_display no
!设置相切边不显示
bell no
关闭提示音
rename_drawings_with_object both
!设置保存副本时自动复制与零件或组件相关的工程图
mass_property_calculate automatic
!如果零件模型改变需要重新计算零件质量。若不想重新计算可以在config.pro设mass_property_calculate的值为 automatic,然后执行再生一次即可(设置质量自动计算)
step_export_format ap214_cd
step_appearance_layer_groups yes
!设置输出step格式文件时,保留原模型颜色
dxf_out_scale_views yes
!输出为DWG或DXF时不管工程图中的比例,自动重新缩放为1比1
pro_font_dir C:\WINDOWS\Fonts
!将该目录中的字体加载到绘图中
text_width_factor 0.7
!设置文本的高度和宽度的比例,按国标应使用长仿宋体,应为0.7。但此项设置对于windows系统自带的仿宋体无效。
sketcher_dim_of_revolve_axis yes
!草绘中对旋转轴创建的全部尺寸都将标注直径
line_style_standard std_iso
!设置工程图中文本的缺省颜色,比如标注的数值颜色、注释文字的颜色。
!std_iso为标注界线为黄色,但数值为绿色,注释文字也为绿色。
!同时控制详细视图、局部视图的边界线颜色为黄色,打印为细实线
sym_flip_rotated_text yes
!设置文本方向是否锁定方向不旋转,比如粗糙度的方向
broken_view_offset 3
!设置破断视图两破断线之间的距离
detail_circle_line_style phantomfont
!设置详细视图(局部放大图)的边界线的线型,影响打印的粗细
projection_type first_angle
!设置视图的投影方向为第一角法(国标要求用第一角法,日本等国用第三角法)
def_xhatch_break_around_text yes
!设置当文本出现在剖面线当中时,是否文本与剖面线分开(自动断开剖面线让出位置)
def_xhatch_break_margin_size 1
!设置当文本出现在剖面线当中时,文本与剖面线的隔开距离。
hlr_for_threads yes
thread_standard std_iso_imp_assy
!以上两项设置螺纹表示方法按国标形式表示,正面以3/4圆方式表示
!angdim_text_orientation horizontal
!设置标注角度尺寸时,角度的放置方式为水平
blank_zero_tolerance no
!设置公差值有一项为0时,是否去掉0。比如尺寸公差中有上偏差+0.02和下偏差0,如果设为yes则只显示+0.02,0不显示
prompt_on_exit no
!决定在退出PROE进程时,是否提示保存对象
pro_colormap_path C:\PTC\PTCWORK\colormap\color.map
!proe 颜色和外观映射文件
creo_less_restrictive_names yes
!creo1.0 m020中文命名设置
intf_out_layer part_layer
dxf_export_mapping_file   C:\PTC\PTCWORK\Dxf_export.pro
keep_model_in_open_window no
!*                 mapkey(映射键/快捷键)               *
mapkey $F2 @MAPKEY_LABEL设置工作目录;~ Command `ProCmdSessionChangeDir` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;
mapkey $F4 @MAPKEY_LABEL拭除未显示的文件;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_erase_not_disp`;
mapkey $F5 @MAPKEY_LABEL测量长度;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_length`;
mapkey $F6 @MAPKEY_LABEL测量距离;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_distance`;\
mapkey(continued) ~ Select `na_distance` `page_tab`1  `options`;
mapkey $F7 @MAPKEY_LABEL测量角度;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_angle`;
mapkey $F8 @MAPKEY_LABEL测量直径;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_na_measure_diameter`;
mapkey $F10 @MAPKEY_LABEL更新工程图;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_regen_cur`;
mapkey wf @MAPKEY_LABEL打开选中的零件;~ Activate `main_dlg_cur` `OpenModel`;
mapkey j @MAPKEY_LABEL装配零件;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdCompAssem.d_feat`;
mapkey up @MAPKEY_LABEL清理文件老版本和垃圾文件;@SYSTEMpurge;
mapkey wd @MAPKEY_LABEL指定要删除的垃圾文件后缀;\
mapkey(continued) @SYSTEMdel *.log.* *.err.* *.inf.* *.lst.* *.crc *.acc *.ger *.ers *.m_p \
mapkey(continued) *.bak *.bk1 *.bk2 std.out current_session.pro;
mapkey fe @MAPKEY_LABEL改文件名(零件);~ Activate `main_dlg_cur` `File.psh_rename`;
mapkey f3 @MAPKEY_LABEL改文件名(组件下选择零件);\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelRename.file`;\
mapkey(continued) ~ Activate `rename` `Select`;
mapkey g4 @MAPKEY_LABEL设定当前背景颜色为2001颜色;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_util_colors_sys`;\
mapkey(continued) ~ Activate `color_scheme` `UsePreWFColScheme`1 ;\
mapkey(continued) ~ Activate `color_scheme` `OK`;
mapkey g5 @MAPKEY_LABELG5 设定当前背景颜色为野火颜色;\
mapkey(continued) ~ Activate `color_scheme` `Reset`;~ Activate `color_scheme` `OK`;
mapkey g6 @MAPKEY_LABELG6 设定当前背景颜色为白色;;
mapkey g7 @MAPKEY_LABEL设定当前背景颜色为黑色;\
mapkey(continued) ~ Activate `color_scheme` `Scheme3`;~ Activate `color_scheme` `OK`;
mapkey gq @MAPKEY_LABEL打印当前的窗口;~ Activate `main_dlg_cur` `File.psh_print`;\
mapkey(continued) ~ Activate `print` `OK`;
mapkey dd @MAPKEY_LABEL尺寸-新参照;~ Command `ProCmdDwgCrStdNewRefDim`;\
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
mapkey(continued) ~ Command `ProCmdEditProperties`;
mapkey df @MAPKEY_LABEL参照尺寸;~ Command `ProCmdDwgCrRefStdNRDim`;
mapkey s @MAPKEY_LABEL删除;~ Command `ProCmdEditDelete` ;\
mapkey(continued) ~ Close `main_dlg_cur` `adbEdit_cb`;
mapkey ee @MAPKEY_LABEL附件;~ Command `ProCmdDwgModAtt`;
mapkey ew @MAPKEY_LABEL与对象相关;~ Command `ProCmdDwgRelToObj` ;\
mapkey eq @MAPKEY_LABEL与视图相关;~ Command `ProCmdDwgRelToView` ;\
mapkey ds @MAPKEY_LABEL注解;~ Command `ProCmdDwgCreateNote`;
mapkey dg @MAPKEY_LABEL几何公差;~ Command `ProCmdDwgCrGtolSpecTol`;
mapkey da @MAPKEY_LABEL断点;~ Command `ProCmdDwgDtlBreak`;
mapkey ww @MAPKEY_LABEL编辑定义;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node3`;\
mapkey(continued) ~ PopupOver `main_dlg_cur` `ActionMenu`1  `PHTLeft.AssyTree`;\
mapkey(continued) ~ Open `main_dlg_cur` `ActionMenu`;~ Close `main_dlg_cur` `ActionMenu`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Redefine`;
mapkey we @MAPKEY_LABEL编辑;\
mapkey(continued) ~ Activate `main_dlg_cur` `EditModify`;
mapkey bb @MAPKEY_LABEL球标;~ Command `ProCmdDwgTblBomBalloons` ;#MERGE;
mapkey bv @MAPKEY_LABEL重复区域;~ Command `ProCmdDwgTblRepeatRegion` ;#FILTERS;
mapkey vv @MAPKEY_LABEL创建普通视图;~ Command `ProCmdDwgViewGen`;
mapkey vc @MAPKEY_LABEL边显示;~ Command `ProCmdDwgEdgeDisplay` ;#ERASE LINE;
mapkey aa @MAPKEY_LABEL属性;\
mapkey dc @MAPKEY_LABEL定制符号;~ Command `ProCmdDwgCrSymInstCust` ;\
mapkey $F3 @MAPKEY_LABEL关闭当前文件;\
mapkey(continued) ~ Activate `main_dlg_cur` `Windows.psh_win_close`;
mapkey de @MAPKEY_LABEL工程图中显示轴线;~ Command `ProCmdDwgShowAllAnnots` ;\
mapkey(continued) ~ Select `show_model_annotations` `tab_dtl_types`1  `lay_datum`;\
mapkey(continued) ~ Trigger `show_model_annotations` `tbl_datum`2  `` ``;\
mapkey(continued) ~ Move `show_model_annotations` `show_model_annotations`2 32.450563 4.976220 \
mapkey(continued) ;~ Trigger `show_model_annotations` `tbl_datum`2  `` ``;
mapkey r @MAPKEY_LABEL再生模型;#REGENERATE;#AUTOMATIC;
mapkey ` @MAPKEY_LABEL草绘—直线;\
mapkey(continued) ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketLine.tbLine`;\
mapkey(continued) ~ Command `ProCmdSketLine` 1;
mapkey 1 @MAPKEY_LABEL草绘—中心线;;\
mapkey(continued) ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\
mapkey(continued) ~ Command `ProCmdSketCenterline` 1;
mapkey 2 @MAPKEY_LABEL草绘约束—标注;~ Command `ProCmdSketDimension` 1;
mapkey 3 @MAPKEY_LABEL草绘约束—重合;~ Command `ProCmdSketAlignConstr`;
mapkey 4 @MAPKEY_LABEL草绘—对称;\
mapkey(continued) ~ Activate `main_dlg_cur` `tbSketConstr` `ProCmdSketSymmetryConstr.tbSket`;\
mapkey(continued) ~ Command `ProCmdSketSymmetryConstr`;
mapkey 5 @MAPKEY_LABEL草绘—拐角;~ Command `ProCmdEditCorner` 1;
mapkey wq @MAPKEY_LABEL拉伸;~ Command `ProCmdFtExtrude` ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.extrev_1_placement.0`1 ;\
mapkey(continued) ~ Trigger `extrev_1_placement.3.0` `PH.section_select_list` `0`;\
mapkey(continued) ~ Trigger `extrev_1_placement.3.0` `PH.section_select_list` ``;\
mapkey(continued) ~ Activate `extrev_1_placement.3.0` `PH.Sketch`;
mapkey wa @MAPKEY_LABEL插入孔;~ Command `ProCmdHole` ;\
mapkey(continued) ~ Select `main_dlg_cur` `maindashInst0.ui_str_skt_std_type_rg`1  `Std`;
mapkey ff @MAPKEY_LABEL工程图打印;~ Command `ProCmdDwgPubSettings` ;\
mapkey(continued) ~ Select `print_config` `CascadeButton1`;\
mapkey(continued) ~ Close `print_config` `CascadeButton1`;\
mapkey(continued) ~ Activate `print_config` `windows_print_manager_A4`;\
mapkey fd @MAPKEY_LABEL工程图转换PDF;\
mapkey(continued) ~ Activate `main_dlg_cur` `page_Publish_control_btn`1 ;\
mapkey(continued) ~ Command `ProCmdDwgPubSetDeliverable`  `PDF`;\
mapkey(continued) ~ Command `ProCmdDwgPubSettings` ;\
mapkey(continued) ~ Move `intf_profile` `intf_profile`2 25.091364 3.434293 ;\
mapkey(continued) ~ Select `intf_profile` `pdf_export.pdf_color_depth`1  `pdf_mono`;\
mapkey(continued) ~ Activate `intf_profile` `pdf_export.pdf_pentable`1 ;\
mapkey(continued) ~ Activate `intf_profile` `pdf_export.pdf_launch_viewer`0 ;\
mapkey(continued) ~ Select `intf_profile` `pdf_export.PDFMainTab`1  `pdf_export.PDFContent`;\
mapkey(continued) ~ Select `intf_profile` `pdf_export.PDFMainTab`1  `pdf_export.PDFSecurity`;\
mapkey(continued) ~ Select `intf_profile` `pdf_export.PDFMainTab`1  \
mapkey(continued) `pdf_export.PDFDescription`;\
mapkey(continued) ~ Select `intf_profile` `pdf_export.PDFMainTab`1  `pdf_export.PDFFormat`;\
mapkey(continued) ~ Activate `intf_profile` `OkPshBtn`;~ Command `ProCmdDwgPubPublish`;
dxf_out_comments no
dwg_export_format 2000
mapkey fg @MAPKEY_LABEL工程图转换DWG;~ Command `ProCmdDwgPubSettings` ;\
mapkey(continued) ~ Activate `export_2d_dlg` `OK_Button`;~ Command `ProCmdDwgPubPublish`;
mapkey fg @MAPKEY_LABEL工程图转换DWG;\
mapkey(continued) ~ Command `ProCmdDwgPubSetDeliverable`  `DWG`;\
mapkey(continued) ~ Command `ProCmdDwgPubSettings` ;~ Activate `export_2d_dlg` `OK_Button`;\
mapkey(continued) ~ Command `ProCmdDwgPubPublish`;
!ff 工程图打印
mapkey ff @MAPKEY_LABEL工程图打印;\
mapkey(continued) ~ Command `ProCmdDwgPubSetDeliverable`  `Print/Plot`;\
mapkey(continued) ~ Command `ProCmdDwgPubSettings` ;~ Select `print_config` `CascadeButton1`;\
!$F1打开文件
mapkey $F1 @MAPKEY_LABEL打开文件;~ Command `ProCmdModelOpen` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Open `file_open` `Type`;~ Close `file_open` `Type`;\
mapkey(continued) ~ Select `file_open` `Type`1  `db_-1`;
!A3 打印A3纸
mapkey a3 @MAPKEY_LABEL打印A3纸;~ Command `ProCmdDwgPubSettings` ;\
mapkey(continued) ~ Activate `print_config` `windows_print_manager_A3`;\
mapkey(continued) ~ Select `print_config` `SheetsRadio`1  `All`;~ Activate `print_config` `OK`;\
!A4 打印A4纸
mapkey a4 @MAPKEY_LABEL打印A4纸;~ Command `ProCmdDwgPubSettings` ;\
! J 装配零件
mapkey j ~ Activate `main_dlg_cur` `ProCmdCompAssem.d_feat`;
! K 零件按缺省装配
mapkey k ~ Select `main_dlg_cur` `maindashInst0.constr_type_menu`1  \
mapkey(continued) `Default`;~ Activate `main_dlg_cur` `dashInst0.stdbtn_1`;
mapkey sa @MAPKEY_LABEL草绘中删除;~ Command `ProCmdEditOneByOne` 1 ;\
mapkey(continued) ~ Command `ProCmdEditDeleteSket`;
mapkey ss @MAPKEY_LABEL工程图中删除;~ Command `ProCmdEditDelete` ;\
mapkey wr @MAPKEY_LABEL组件中重新装配;\
mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree`1  `node47`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node47`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` \
mapkey(continued) `main_dlg_w2HTLeft.AssyTree:<NULL>`;\
mapkey(continued) ~ Activate `main_dlg_cur` `PHTLeft.AssyTree`1  `node9`;\
mapkey(continued) ~ Select `main_dlg_cur` `PHTLeft.AssyTree`1  `node9`;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node9`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Redefine`;\
mapkey(continued) ~ Activate `extrev_1_placement.1.0` `PH.Sketch`;
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Activate `rmb_popup` `Redefine`;
mapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Activate `rmb_popup` `Redefine`;\
mapkey(continued) ~ Activate `extrev_1_placement.2.0` `PH.Sketch`;
mapkey(continued) ~ Activate `main_dlg_cur` `page_Layout_control_btn`1 ;\
mapkey(continued) ~ Command `ProCmdEditProperties` ;\
mapkey(continued) ~ Select `drawing_view` `options_list`1  `Section`;
mapkey as @MAPKEY_LABEL布局-属性;\
发表于 2015-8-11 14:55:59 | 显示全部楼层
ajj,什么情况》》》
发表于 2015-8-16 12:54:57 | 显示全部楼层
配置都是自己搞的好些吧
发表于 2015-8-20 10:09:14 | 显示全部楼层
配置都是自己搞的好些吧
发表于 2015-9-7 16:52:31 | 显示全部楼层
配置都是自己搞的好些吧
发表于 2015-9-10 10:10:38 | 显示全部楼层
就这样啊 不值得哦
发表于 2015-9-16 10:57:28 | 显示全部楼层
dfaddddddddddddddddddddddddddddddddd
发表于 2015-9-16 11:55:44 | 显示全部楼层
配置都是自己搞的好些吧
发表于 2015-9-16 11:56:26 | 显示全部楼层
没有那么贵吧,有一角银子。我都没有银子。
发表于 2015-9-16 14:33:55 | 显示全部楼层
gfdgtyryhrfasgfdsfadfasffgdfgadfs
GMT+8, 2025-4-3 19:58
